04-25-2024, 08:48 AM | #1 |
Rep 278
Car Wash De-ionized kit - what works?
Considering a de-ionized car wash kit for the final rinse to greatly reduce water spots.
I'd like something mobile on a cart preferably - ease of moving around is my intent. I haven't found much out there except the two below, they aren't cheap, nor are replacing the filters/resin which concerns me on how long they will truly last until the filter/resin is depleted. I like that they both have a TDS meter/sensor. What have others found that work? https://www.amazon.com/CR-Spotless-D...zcF9hdGY&psc=1 https://www.amazon.com/Filterelated-...63b24bcb5&th=1 |
04-25-2024, 06:04 PM | #2 |
Rep 1,105
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2012 BMW 335i [5.25]
2012 BMW 335is [5.00] 2008 Infiniti QX56 [0.00] 1967 Chevrolet Corv ... [10.00] 2001 M Roadster [10.00] 2022 BMW 540i [0.75] 2009 528i [9.50] |
Several months ago I watched a video on the CR Spotless. The video came from a YT channel of a VLogger regarding his RV. He was very happy with it as it simplified the chore of washing his 40' RV. No longer has to worry about water spots. He claimed something like 50 washes before having to replace the filter.
If I can find the link I will post it here. |
chris7197366.50 |
04-26-2024, 11:07 AM | #4 |
Rep 620
Build your own for about half the price.
https://www.amazon.com/MewMore-Sedim...%2C161&sr=1-12 https://www.amazon.com/Hydronix-EC-4...d_i=B01CFOFW0Q https://www.amazon.com/HM-Digital-DM...147506&sr=8-11 Various connectors and adapters can be found at your local home improvement store. Go as fancy as you want: https://www.reddit.com/r/AutoDetaili...sher_spotless/ |
04-29-2024, 09:12 AM | #5 |
Rep 278
The Adam's Polish one and CR Spotless look good.
I tested my TDS this weekend with a tester off Amazon. The one thing I'm confused about is my TDS with just cold water was around maybe 150ish, but with hot water was around 550ish. I'd have thought hot water would be lower?? I have a water softener installed at my house and a whole house filter (which likely is already shot after a couple months of use).... |
04-29-2024, 10:53 AM | #6 | |
Rep 3,621
On topic, you could consider a small RO setup for $100 or less, i.e. for a fish tank. It won't flow fast enough to rinse the car of course but it could generate a few gallons that go in something like a hand-held sprayer? Not as great an option obviously but depending on space available or how much you really feel like spending it might be an option. |
04-29-2024, 12:34 PM | #7 |
Rep 361
Drives: 2021 M340i xDrive
Great post. When I finally add a DI setup, I'll wash/foam with non-DI water and then rinse with DI to help save on filters.
Navin_Johnson12.00 |
04-29-2024, 06:23 PM | #8 |
Rep 128
An idea that'll save you money, but will be a bit of a hassle:
Buy a few 5 gallon jugs of mineral free water from grocery store and a cheap sump pump. Final rinse can't use more than 5-10 gallons right? Am I missing something? |
05-02-2024, 06:28 PM | #11 | |
Rep 1,372
You end up buying any of them?
2021 Jeep Grand Cherokee SRT Black 2006 Ford Mustang GT Convertible (car-show car) |
05-02-2024, 06:45 PM | #12 |
Rep 1,064
Overall life of the resin will greatly depend on the quality of your water from spigot. I've ran a DI-W20 for several years now on my pressure washer setup with a bypass and additional carbon/sediment pre-filters. I tend to need new resin every year washing 1 car once a week.
I've also been chemically refreshing my resin instead of buying new but there are times I've been lazy and just bought. It's a process but costs <$15. The best way to get the most life is to run an RO membrane and have a reservoir since it has low GPM output but I've yet to look further into this seriously. My understanding is your get 10x (if not more) life out of the resin. |
05-02-2024, 06:57 PM | #13 |
Rep 3,825
CR Spotless with the downtube conversion kit and buy the resin in bulk. Considerably longer resin life because of the efficiency. It's the most economical way to get spot free water at home without spending thousands. Do not use the resin cartridges, that gets old (and expensive) FAST.
https://rv-mods.com/store/DIC20-conv...kit-p105868881 |
Dochere236.50 |
05-02-2024, 07:20 PM | #14 | |
Rep 1,064
One of the tubes from this kit also kept coming loose after a few months and my water was leaving spotting on and off which would require disassembly and fixing which sucks in itself. Had to buy new o ring to fix. |
Dochere236.50 |
05-03-2024, 08:57 AM | #15 |
Rep 405
I have small, low flow reverse osmosis water filter. I use that to fill up 40 liter bucket and when I'm ready to do final rinse, I just release my pressure washer intake hose from wall tap and put it in a bucket full of RO water. Added benefit is that it also flushes pressure washer internals from dissolved solids. My little RO filter is almost 10 years old and still produces water with EC 0.02ms.
tracer bullet2502.00 icj_45e109.50 |
05-07-2024, 02:55 PM | #16 | |
I like to eat eat eat apples and bananas
11
Rep 12
Dochere236.50 |
05-07-2024, 02:56 PM | #17 | |
11
Rep 12
05-07-2024, 04:02 PM | #18 |
Rep 278
Wow. Confusing me now. I like simple. None of this sounds all that simple just to rinse off my car and then replenish the resin simply and cost effective.
I like the discussion - keep it going, but hoping someone provides a good solution and how all this stuff is done, completely new to this concept!!! |
05-07-2024, 04:11 PM | #19 |
Rep 278
What version in-line filter did you use? - garden hose acceptable is what I'd need.
05-07-2024, 04:19 PM | #20 | |
11
Rep 12
https://www.amazon.com/Geekpure-10-I...1zcF9tdGY&th=1 |
05-07-2024, 04:21 PM | #21 | |
11
Rep 12
