BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) ID9 - Feedback / Updates / Bugs
      08-05-2023, 05:16 PM   #67
U11sirgawain
U11sirgawain's Avatar
Spain
92
Drives: bmw x1 3.0e u11
Originally Posted by Tomduck View Post
From 8 you can only (in the future) update to 8.5, never 9. Only cRs shipped with 9 can be 9 and onwards as it’s a different head unit
Not even to 8.5
As per BMW AG press releases, 8.5 upgrade will be only for.bigger models, fitted with the rotary controller.
U11 are not in current BMW plans for 8.5 upgrades.
Ex320i, ex325ix, ex850i, ex530dTouring
      08-06-2023, 03:56 PM   #68
NeilOHaraBYO
Drives: BMW X1 PHEV
Originally Posted by U11sirgawain View Post
Not even to 8.5
That seems to be correct the XXX! will have idrive 8 or 9.
Mine was built in June, 25e phev and is running idrive 8 but how do I know which head unit I have.
Is there a chance it's fitted with the latest head unit H5 and can be updated to 9 at a later date?
How can you tell which head unit you have?
      08-07-2023, 02:13 AM   #69
Tomduck
Tomduck's Avatar
401
Drives: U11 X1 18d Msport
This is the latest head unit WAVElow_IDChighf
So if you look at your “Notes” app right at tbe bottom you should see the attached and if it says IDC that indicates the latest head unit apparently (so i’m told).
      08-07-2023, 03:19 PM   #70
U11sirgawain
Spain
92
For those of us drooling about 8.5
https://www.bimmerpost.com/forums/sh...php?p=30378874
      08-07-2023, 03:19 PM   #71
NeilOHaraBYO
Drives: BMW X1 PHEV
I can't find the "Notes" app in mine.
      08-07-2023, 04:55 PM   #72
MontyB1
Drives: BMW X3
MAPMAN48 You seem pretty angry at life as well as the car for some reason. No car is perfect and some seem to find ID9 to be fine others are struggling. Not sure BMW wants its customers to have a bad experience far from it. We have had niggles with the car but no major issues with our ID8 PHEV others again not so lucky.
The car is new and ID9 needs more work but it’s not terrible just a bit beta ish, is that good in a car no but BMW really aren’t sitting there laughing.
      08-07-2023, 06:39 PM   #73
FlashMonkey929
FlashMonkey929's Avatar
1049
2003 BMW 330i ZHP  [0.00]
2023 BMW X1  [10.00]
In iDrive 8, I went to system settings>regulatory notes>headunit and found this:
2011 335i Alpine White Sedan PPK -sold-
2020 430i Estoril Coupe MSport -returned-
2023 X1 Portimao, Msport, Premium
2003 330i Imola Red ZHP 6 Speed
      08-07-2023, 10:37 PM   #74
vikas
Drives: BMW X1
Can't agree more.. there is no reason to keep blaming BMW on every aspect.. whatever they are doing as per their roadmap is ultimately for betterment of their products and consumer experience.
      08-16-2023, 10:03 AM   #75
zauriel
zauriel's Avatar
Italy
66
Drives: BMW F20 LCI - BMW U11 late 23
  [0.00]
  [0.00]
Originally Posted by vikas View Post
I genuinely feel, all BMW X1s (U11 series) would be either upgraded to ID8.5 or ID9 in coming months..
As X1s built before March, 2023 have MGU22/MGU22H head units which are compatible with id8.5 and X1s built after March or July,23 (depending on region) have IDC23 units which are id9 compatible.
Based on the hardware support, we have a reason to rejoice
Are you sure there are currently MGU22 X1s out there?
That would be great news as the MGU22 is the HU compatible with 8.5.
IMO, i fear all ID8 X1s will be stuck with ID8;
      08-17-2023, 02:01 AM   #76
zauriel
zauriel's Avatar
Italy
66
  [0.00]
  [0.00]
Originally Posted by MAPMAN48 View Post
p.s. Does anybody know what the blob of red is between the "6" and "7" on the RPM thingy (i can't call it a dial cos it isn't), just noticed it. Wonder if it is serious. The engine coolant temp thingy is at bottom-right out of picture.
Are you referring to this line?
It's called "red line" and it's there to indicate the unsafe RPMs zone for your engine, meaning that you shouldn't be revving at those RPMs or you may risk some engine failures.
In the past it was something to really keep in account, especially downshifting on a manual transmission; nowadays most engines and transmissions will automatically kill the ignition if you reach the red zone.
The red line has been on RPM gauges since the dawn of motoring, are you sure your previous cars didn't have it?
p.s. Does anybody know why BMW have abbreviated miles to "mi" when everbody else uses "ml" bit like "SUV" and "SAV" I suppose.
I guess they did so in order to adhere to the international standard of units. ml stands for milliliter and folks at BMW for sure didn't want that kind of confusion. Quoting from Wikipedia:
Abbreviation
The mile has been variously abbreviated in English—with and without a trailing period—as "mi", "M", "ml", and "m".[4] The American National Institute of Standards and Technology now uses and recommends "mi" to avoid confusion with the SI metre (m) and millilitre (ml).[5] However, derived units such as miles per hour or miles per gallon continue to be abbreviated as "mph" and "mpg" rather than "mi/h" and "mi/gal". In the United Kingdom, road signs use "m" as the abbreviation for mile though height and width restrictions also use "m" as the symbol for the metre, which may be displayed alongside feet and inches.[6] The BBC style holds that "there is no acceptable abbreviation for 'miles'" and so it should be spelled out when used in describing areas.[7]
      08-17-2023, 05:15 AM   #77
vikas
Drives: BMW X1
Yes, from hardware point of view.. all U11 X1s are either id8.5 or id9 compatible.. however, it still depends on BMW if they choose not to update the software on all existing delivered cars.
In my opinion, there is no reason they should not!
      08-17-2023, 05:37 AM   #78
zauriel
zauriel's Avatar
Italy
66
  [0.00]
  [0.00]
This is very interesting. Mine is entering production in October, I hope I will get at least 8.5 as an update in the future…
      08-17-2023, 06:26 AM   #79
vikas
Drives: BMW X1
If it's still not produced, it would be most likely IDC23 unit which is ID9 compatible.
As mine is July, 2023 production with ID9 hardware.
      08-29-2023, 02:42 AM   #80
MontyB1
Drives: BMW X3
Now I know I'm commenting in this ID9 thread but many also have issues with ID8.
But it seems VERY few updates if any at the moment are filtering through to cars. We had a .point release so a fix of something it didn't really say what but there hasn't been a major update on ID8 or ID9 at all yet for the X1.
I wonder when the next one is imminent as there are a good few bugs that need ironing out. Maybe with the tech in the car they should move to a much quick update cycle to match the tech. Not fair for many to have entire features missing let along bugs that could easily be solved with some code fairly minor changes.
      08-29-2023, 08:28 AM   #81
redlion8
Drives: Volvo XC40
This is something I’ve been wondering recently - BMW had been following a 4 monthly release cycle (the last being march) I was told there would be a IDrive9 update in July (which tracks with the release cycle) however it’s failed to materialise - I did go back to my dealer to get an update but was since ignored…
      08-29-2023, 12:15 PM   #82
MontyB1
Drives: BMW X3
Yeah agreed would have thought to have seen a larger update sooner. Maybe they are still working to iron out more bugs pre wider distribution in November for ID9, but for ID8 that also has the odd issue I'd hope to see more on that as well.
Its odd my ID7 is solid as a rock I don't think I've spotted a single issue though it's not as sophisticated for some things but on the whole a more consistent experience.
      08-29-2023, 06:56 PM   #83
gpbayarea
Drives: Subaru Outback
My x1 was at the dealer last week for the GPS drift issue and they updated ID8 from 3/2023 to 7/2023, so there’s an update out there. Probably won’t be available OTA for a few more months, but dealers can update.
MontyB11421.00
      08-29-2023, 09:02 PM   #84
Rpesacs
Rpesacs's Avatar
Drives: 2023 X1 Msport
  [0.00]
Does anyone know if the x1’s built after July 1st have the MGU 21 or 22 head unit in the US?
      08-30-2023, 02:52 AM   #85
MontyB1
Drives: BMW X3
Good to know a fuller update is on the way. Has it fixed anything other than the drift that you had issues with before?
      08-31-2023, 08:00 PM   #86
lame_name
lame_name's Avatar
Drives: 2023 BMW X1 xDrive28i
2023 BMW x1  [10.00]
My 7/2023 production x1 has MGU21
      08-31-2023, 08:10 PM   #87
gpbayarea
I honestly haven’t really had any other issues. The throttle feels a bit more responsive and smooth. Map colors have changed a bit. Fonts are slightly different. Otherwise haven’t noticed any meaningful changes.
      08-31-2023, 09:44 PM   #88
COOLGREANY
COOLGREANY's Avatar
Drives: 24 xDrive28i Space Silver
How did you end up with ID9 if you're in the USA? I thought ID9 wasn't available on USA models until MY24.
