08-11-2023, 05:41 PM | #1 |
Rep 1,959
DCT Update
Hi,
Anyone care to chime in if their dual clutch lag for accelerating has improved with miles on the odo? Curious if things are smoother? |
08-11-2023, 06:34 PM | #2 |
I Shoot People For Money
1049
Rep 1,917
Drives: 2023 Portimao MSport X1
I noticed mine improved enough to notice after I took my car in to the dealer for the airbag recall, but it's still there. It's not as bad as before, on takeoffs when trying to merge into traffic quickly from a complete stop it's still like the pedal is dead for a second before it goes. Not all the time, but just enough to make it unpredictable.
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold- 2020 430i Estoril Coupe MSport -returned- 2023 X1 Portimao, Msport, Premium 2003 330i Imola Red ZHP 6 Speed |
08-11-2023, 06:47 PM | #4 |
Rep 4,472
Drives: '23 X1 28i xDrive
I wouldn't say that it's improved; but my driving style has adapted better to keep it from intruding.
08-12-2023, 11:58 AM | #5 |
Rep 337
I found it to be marginally better once I hit 2,500. Still wicked annoying though. If I know I'm going into a left turn where traffic usually has to stop to let me in, I'll put it in sport mode ahead of time to counter the lag.
Seems that shouldn't have to be that way with a BMW, but here we are. |
AmisWill19.50 |
08-12-2023, 12:07 PM | #6 | |
Rep 18
Drives: 2023 X1 xDrive28i
08-12-2023, 12:19 PM | #8 |
Rep 18
Got it thanks. I’ve seen some suggest creating a link in the menu to turn off the auto start/stop every time you drive, without having to navigate through the menu. Having if off seems to help reduce the lag from a full stop. I understand sport mode automatically turns it off too.
Kromans1177.00 |
08-12-2023, 12:30 PM | #9 | |
slowest X1 driver ever
494
Rep 969
Drives: '23 X1 M Sport, '24 530i(soon)
AmisWill19.50 |
08-12-2023, 05:33 PM | #10 |
Rep 25
Haha, that's funny but people need to calm down and realize that's how DCT gearboxes work. I have another car for 4 years with double clutch and just got used to how it works. You just have to react a bit different from a stop and it's decent.
08-12-2023, 08:23 PM | #11 | |
Rep 1,959
I had an x1 loaner and couldn’t figure out how to reduce any of the lag. This x1 had 3000 miles on it so I assume broken in? |
08-12-2023, 09:59 PM | #12 |
1049
Rep 1,917
It’s not the transmission itself, it’s the programming for the throttle that’s causing the lag. Put it in sport mode and the lag disappears.
AmisWill19.50 |
08-13-2023, 12:47 AM | #13 | |
1049
Rep 1,917
HOWEVER, since servicing my car for the airbag recall at the dealership, I've noticed that the lag is diminished a little, but still not gone. I'm not sure what they did, as the idrive software is the same and no notes were on my invoice detailing any changes they made. But it's definitely a bit better than before.
AmisWill19.50 JupiterOne38.00 |
08-13-2023, 01:08 AM | #14 | |
Rep 18
08-13-2023, 02:22 AM | #15 |
Rep 25
The hole thing is related to the gearbox and much less to the start stop function as this basically just adds delay. DCT gearboxes are basically automated manual transmission, there is a physical engagement of a clutch at gear changes and what most important here when going at a stop, going out of gear. When you stop, start, stop at low speed the gearbox gets a bit confused as it doesn't know whether it should be so this hesitations produces the lag. That's why be it in sport mode just reduces these times and what happens here as well for short time it still holds the clutch in gear and the breaks holds the car from not rolling. For short amounts this shouldn't be an issue but doing it all the time just puts an extra wear on the breaks / clutch plates etc. Not sure how much, but it's there. Some would say software wise they should make this happen faster, while the gearbox is quite fast at engaging, you would play basically catchup between input and output and in the end just jump what the gearbox is doing and become really jerky.
But just to overcome this, I got used to it, trying to understand what is happening so at a light, in a roundabout just try to anticipate for a fraction of a second and press slightly the throttle. By the time you wanna go, the car is in gear, and no lag will happen. This is my experience with a 5yr old Mercedes, but from my quick test drive with a sDrive X1 18d ( basically the same tech as you get in the states, without mild hybrid) wasn't that much of an issue, as I said, I got used to it and that's why. Eveny though it didn't bother me, I ordered a PHEV as the EV doesn't have this issues at all, it's instant and while driving it's not noticeable anymore. However, in Sport when both engines are pulling, if you kick it, you can notice the electrical engine pulling instantly and the gearbox catching up in a matter of seconds, as there is a mechanical connection there that needs to engage |
U11sirgawain91.50 |
08-13-2023, 05:43 AM | #16 | |
1049
Rep 1,917
08-13-2023, 06:33 AM | #17 | |
Rep 3,825
08-13-2023, 07:23 AM | #18 | |
Rep 1,815
I’d often have to take the foot off the brake and you could feel the clutch engage to anticipate the need to accelerate when the lights changes. However somethings they might change and the need to move quickly made for a hard and what felt like sometimes violent engagement of the clutch. You would prod the throttle and the clutch in the gearbox would engage with an uncomfortable jolt and then quick progress. BMW has chosen not to have that jolt which causes the delay in nothingness until the clutch engages. It doesn’t help the driving experience at all but many DCT suffer from the same issues to one degree or another. The US engine / drivetrain seems to exacerbate this issue. Maybe they spent more time optimising the EU starter / engine combos it seems only the engineers will know. |
08-13-2023, 07:34 AM | #19 | |
1049
Rep 1,917
08-13-2023, 08:38 AM | #20 |
Rep 1,959
08-13-2023, 08:46 AM | #21 | |
Rep 1,959
I’m curious if it’s just planned for the next model Year. Would you buy the x1 now knowing it’s doing this? In other words to the group; knowing what you know now- would you skip x1 and go to x3? I love driving and my test drives all have been with lag. X3 zf seems so much better- but then the x3 is an old design. I like the x1 layout and size . And value prop. So much for 40,000 really. A 30i x3 is around 54,000. Maybe if it bothers me this much- I should go old school x3 |
08-13-2023, 11:10 AM | #22 | ||
Rep 25
Cars for a while now use Drive by Wire, so even if the engine could rev up faster it would not allow to go there until the gear is engaged otherwise you would feel jerky . The reaction time drops with sport mode but not sure if keeping it like that solves the problem. |
