BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) BMW X1 U11 FitCamX Rear Camera Install
      07-16-2023, 08:57 AM   #1
LindrelT
LindrelT's Avatar
70
Drives: 1971 '02, 1988 325is, 2020 X3
Thanks to others for pointing out the FitCamx product for our model... it is great! I got the front and rear kit and wanted to share some info on the rear cam install. The front cam is very slick, replacing the stock surround behind the rear view mirror. There is video on the vendor's site and instructions for it in the kit.
The rear you are on your own... until now. Have the tools shown available - plastic spudgers and some vinyl coated clothesline (fish) cable. The route is right along the seam where the headliner and vertical plastic pillar covers meet and between headliner and door gasket lip. The headliner is very forgiving and it is easy to push cable up in there fully.
It gets fun when you reach point "1". This is where ultimately where all the extras length of cable goes but also where you have to get to point "2". Pinch and pull out ends of the flex hose that goes into the lift gate. The rear cam cable comes apart near the end - you can't fish the rear camera thought the tube! Use the fish cable to get the route, tape camera cable to it and pull. Untape and fish next path (2 to 3, and 3 to 4), etc. Getting the cable between the points is the hardest part - you can't see and have to just push/twist wire. Pinch flex tube back into sheetmetal - it will be full of wires but goes in easily.
My rear camera has extra cable that will go back under panel above (below in pic) it and camera will be sticky mounted after my ceramic tint film goes on next week. This all (front and back) took about an hour and a half. Work slowly and gently with the prying and pushing.
Cheers!
BMWZ41914.00
PatL28.50
metapod30.00
vded6.00
      07-17-2023, 05:43 PM   #2
FlashMonkey929
FlashMonkey929's Avatar
1049
2003 BMW 330i ZHP  [0.00]
2023 BMW X1  [10.00]
This is very helpful, thank you!
2011 335i Alpine White Sedan PPK -sold-
2020 430i Estoril Coupe MSport -returned-
2023 X1 Portimao, Msport, Premium
2003 330i Imola Red ZHP 6 Speed
      07-26-2023, 01:58 PM   #3
LindrelT
LindrelT's Avatar
70
Part 2 of Guide - Rear camera install
OK, my Xpel XR Plus ceramic tint has been in a week so I can finish rear camera install. Just use the view on phone feature to position it and on it goes. Extra cable and the connector all fit into the trim panel — looks clean!
      11-09-2023, 04:09 PM   #4
Davz
Drives: BMW X1 U11. Z4 e85 2.5
Many thanks for the write up and pictures, I’m about to fit a front and rear dashcam with a power core dashcam battery situated in the boot/trunk. I was going to fit the wire for the front cam along the sill but now seeing your pics it looks to be much better to follow your route…..many thanks!
      11-10-2023, 06:13 AM   #5
richiro
Drives: 2024 BMW X1 M35i
was it difficult to pull the panels on the liftgate off to run the wires through the gromet/tubing?
      11-10-2023, 08:51 AM   #6
SpaceSilverX1
slowest X1 driver ever
494
Drives: '23 X1 M Sport, '24 530i(soon)
they were only held in place with screws and mostly clips. I used plastic pry tool to lift a corner and started pulling straight out. a little force was required. used one hand to hold the tailgate and pulled the panel away.
when running the wires, I used a little bit of lubricant on the wires so they could slide into and out of the tubes easily.
I was only running the wires for a GPS tracker and antenna into the tailgate, but it should be the same to run wires for dashcams.
the parts diagram below helped me figure out where to pull.
      11-10-2023, 12:49 PM   #7
a0krn
Drives: BMW X1 2023 x28i
I have a FITCAMX as well! Does your camera turn on and off when you’re parked? Mine records like 11 seconds every 3 min and sometimes an hour in between each recording stops exactly 11 seconds.
It’s using the normal adapter and parking mode is off.
      11-15-2023, 11:01 PM   #8
beemerboy
Drives: x1
Is the parking mode good with fitcam? Is there remote viewing of the dashcam via the phone app?
      12-11-2023, 07:48 PM   #9
jihong
Drives: 2015 328xi
Bump, interested in this as well!
      12-11-2023, 08:17 PM   #10
FlashMonkey929
1049
2023 BMW X1  [10.00]
I can't comment on parking mode, as I don't have a backup battery installed yet and I probably won't hard wire it. You can use the app to view footage, or live view if you want. The app is a bit clunkier than the one for my Thinkware cam in my other car. You do have to disconnect from CarPlay if you want to connect to the app though, which is a pain in the ass if your infotainment system is on because it keeps trying to connect to CarPlay and disconnecting the camera app. Honestly, I just keep a car reader in my car and just eject the card to grab the videos and then pop the card back in. Much faster that way.
      01-16-2024, 07:09 PM   #11
PatL
Drives: 2024 X1 28i
I can see how I would pull the wiring tubing at point 2 to insert the fish cable, but how do you get the fish cable to emerge at point 1?
Did you have to remove the headliner or the side plastic panel just below it?
How did you remove it? So far I was able to route the camera cable without pulling/removing anything up to the junction between the headliner and tha panel...
      01-16-2024, 09:11 PM   #12
metapod
Drives: U11 X1 28i xDrive
2023 BMW X1  [0.00]
What length of extra cable did you need to buy for the rear camera?
      01-18-2024, 11:14 AM   #13
LindrelT
LindrelT's Avatar
70
At point #1 you can open up the gap between the two parts of the headliner gently. Use the fish wire from point #2 and guide it back to #1. May help to have a second person looking/guiding. No need to do much removing of the trim/headliner, you are just tucking behind it. Good luck!
PatL28.50
      01-18-2024, 11:16 AM   #14
LindrelT
LindrelT's Avatar
70
The kit with rear camera will have a cable with more than enough length. You will have a couple of feet extra to tuck in behind the tailgate panel.
metapod30.00
      01-18-2024, 03:18 PM   #15
PatL
Drives: 2024 X1 28i
Yes! In fact, I pulled gently the back side panel and that gave me enough room to easily fish the camera cable. I pulled starting from the corner closest to the gate.
Picture should be rotated 90degrees to the right...
Next step is to pass the cable/junction behing the tailgate top plastic panel.
      01-18-2024, 11:51 PM   #16
PatL
Drives: 2024 X1 28i
I finally fished the camera cable through the tailgate top panel.
I had in fact to fish the fish cable itself because it is easier to go up through the cabling tubing hole and get the cable to emerge close to the glass.
I am a bit concerned about glueing the camera on the heating elements, so I might position it off center, in fact just above the connector in the picture below. I will try different positions before finalizing.
      04-03-2024, 11:08 AM   #17
DarkHelmet
Drives: BMW X1 M35i
Thanks LindrelT for the awesome write-up and photos!
And thanks FlashMonkey929 for the good idea re: keeping card reader in car to be able to view videos.
I know PatL mentioned some concern about mounting camera on the rear windshield heating elements - anyone notice any issues with doing this?
Thanks again!
      04-10-2024, 09:21 AM   #18
vded
vded's Avatar
Greece
Drives: BMW F20 (2015) 116i M-Pack
Does this camera offer parking surveillance?
I would like to record when the car is parked.
      04-10-2024, 09:44 AM   #19
PatL
Drives: 2024 X1 28i
The company sells a parking mode kit which essentially is a set of cable to power the camera from the fuse box.
This cam doesn't have radar/motion detection to turn on recording when necessary when it is parked, so it would record continuously. The downside is the continuous draw on the battery
Maybe there is a way to add an auxiliary battery.
You should contact the company.
vded6.00
