05-05-2024, 01:34 PM | #1 |
Rep 44
2024 G80 M3 midpipe break
Hi,
Yesterday night, when I was driving on i95 in Florida, unfortunately there is a rolling black object get under my car. And it hit on the bottom. Today I am trying to picture what is damage with my phone on a selfie pole. And I found a big break hole in the midpipe..... I claimed the geico insurance and made an appointment at one dealer. Do any one know what is the solution next? What can I expect for this situation? Will the dealer service repair the pipe or change it? I am feeling so sad such a bad luck... |
05-05-2024, 01:49 PM | #2 |
Rep 553
Drives: 2022 G83 M4
Wow that's unfortunate. While some exhaust repair shops might cut and weld in a new pipe, I would expect bmw to replace and quite frankly I'd want it replaced anyway especially on such a new car. Would be a great opportunity to switch out to an aftermarket midpipe if you want but keeping it OEM they'll replace it. I'd definitely have them check it over with a fine tooth comb to make sure no other damage exists. If you hit something hard enough to puncture your midpipe I'd be surprised if there isn't other damage
2022 G83 M4 Convertible Isle of Man Green on Tartufo Instagram:kermit_g83
2020 GLE 450 Emerald Green on Macchiato Beige - wife and baby mobile 2016 M3 TB on SS - gone but not forgotten |
URmyArtemis38.50 |
05-05-2024, 01:56 PM | #3 | |
Rep 44
Needsdecaf6937.50 2011ninja3418.50 |
05-05-2024, 02:18 PM | #4 |
Rep 1,334
Drives: 2024 BMW M4 Base
I think you’d be better to pay for the repair out of pocket. The exhaust is one piece from the factory and Im betting the dealer will want to replace the entire exhaust. I’m betting a factory exhaust will be 3K or more. I would have a local exhaust shop patch it and call it done. A patch will cost a couple hundred bucks at a local exhaust shop. If you claim it under insurance you’ll be out your deductible and likely a 20-30% increase in your rates.
Some may insist the exhaust be replaced and I get it. I understand wanting your car to be perfect. |
05-05-2024, 03:58 PM | #5 | |
Rep 553
Drives: 2022 G83 M4
05-05-2024, 04:12 PM | #6 |
Rep 2,762
Drives: 2024 M4 Convertible
My advice is don't even bother with this repair. Take this opportunity to swap the midpipe to an AA or MAD single unresonated midpipe. You'll get a much better sound and it'll solve your problem at the same time without having to go through insurance.
URmyArtemis38.50 Needsdecaf6937.50 PVC166.50 mathys215.00 Han4mi120.50 Lupeskew659.00 s58549.50 Dnshift158.00 |
05-05-2024, 04:26 PM | #7 |
Rep 499
Those tubes are thick - VERY lucky that nothing else was hurt.
Does insurance claim trigger a carfax on the car??? Another reason to not report it. I would get a new midpipe/agree w/ others. If you don't want that - simple repair. I'd still like to see the bottom of car on lift to check for other issues/damage. |
URmyArtemis38.50 |
05-05-2024, 04:27 PM | #8 | |
Rep 2,762
URmyArtemis38.50 M4Lou457.00 |
05-05-2024, 04:28 PM | #9 |
Rep 1,000
Drives: 2024 M4 Comp X-Drive
That’s too bad but you are very lucky nothing else was damaged!
I’d look at a cheap take off stock mid pipe from someone that put on an aftermarket one or go with aftermarket mid pipe yourself.
2024 Dravit Grey M4 Competition X-Drive
URmyArtemis38.50 |
05-05-2024, 06:32 PM | #10 |
Rep 1,636
Just buy an x-pipe from Dinan or another manufacturer and replace it. You will be happy with the sound. Lucky the oil cooler was not damaged.
URmyArtemis38.50 |
05-05-2024, 10:33 PM | #11 |
Rep 1,042
Hard to say exactly where that is on the exhaust, but it’s all one piece after the crossover pipe, so if it’s after that, it’s the entire exhaust that will need to be replaced. If you were going to do an exhaust on it anyway, this would be an opportune time.
05-05-2024, 10:59 PM | #12 |
///M ♥ Recycled Dinosaurs
3216
Rep 1,782
Drives: BMW M4, BMW X5 45e
You’d think. I had pothole damage on an older BMW once that got filed as collision (over $10k for steering rack, some suspension bits, two wheels for “completeness”, realignment, equivalent loaner and a month to repair at the dealer). OP may get lucky but I wouldn’t count on it.
2022 BMW ///M4 Comp M xDrive (Enzian, Kyalami - insta | youtube | bp featured: Delivery + 963M + 2x Enzian!) | 2021 BMW X5 45e (Carbon Black Metallic, Ivory White)
BMW CCA LIFETIME MEMBER | Past cars: 2016 BMW 435i Gran Coupe (Carbon Black Metallic, Oyster White - Euro-delivery) |
05-06-2024, 12:17 PM | #13 |
Rep 44
Hi guys, thank you all for your ideas! I picked up the car from the dealer and after the inspection, they confirm that the exhaust midpipe is the only damage that matters. There are other scratches on the black plastic cover near the midpipe, that will be not a issue. So I still have some luck in this unfortunate incident. I decide to change the midpipe with aftermarket modifications. But I know this part little. Besides AA and MAD midpipes, is there any other good choices with reasonable price? Currently my budget is under $2k usd. I am not a loud exhaust enthusiast. My manual modified BRZ is loud enough LOL actually that is too noisy. I probably do not want to make my manual M3 noisy...
05-06-2024, 01:05 PM | #14 |
Rep 553
Drives: 2022 G83 M4
A number of good options out there. AA is one of the more popular ones, Valvetronic makes an equal length one, MAD is slightly newer but also popular. I have Eisenmann but solely because I have the full Eisenmann exhaust setup.
A number of good options around your price point
URmyArtemis38.50 |
05-06-2024, 01:34 PM | #15 | |
Rep 44
I know that the install will require cuts on the factory pipe, I am not sure if a regular repair shop can do that. How can I look for the shops that have this kind of experience modify M3/4? For the parts, do people regularly buy it from the shop do the modify or buy it directly from online? Thank you so much! |
05-06-2024, 01:56 PM | #16 | |
Rep 2,762
As far as installation, you'll want to find a shop that's worked on BMWs so they know the installation process, but it's fairly simple. They drop the whole thing (just bolts), cut the pipe off, and reattach new one with clamps and bolts. It shouldn't be more than a 2-3 hour install. There's plenty of options in the FL area. If you're in South FL, you can probably even get Active to install it themselves since they're based in Miami. |
URmyArtemis38.50 |
05-06-2024, 02:10 PM | #17 | |
Rep 44
Berzerker3099.50 |
05-06-2024, 02:12 PM | #18 | |
Rep 2,762
Make sure you add an SST valve controller to get better control over the valves too |
URmyArtemis38.50 yocubed1084.00 |
05-06-2024, 02:14 PM | #19 | |
Rep 44
05-07-2024, 06:41 PM | #20 |
Rep 338
just get the evolution racewerkes midpipe. made in the US. cheaper than every other option, and better made too.
URmyArtemis38.50 |
05-10-2024, 10:10 AM | #22 |
DROP TABLE EVs;
550
Rep 300
My opinion would be to go aftermarket at this point.
I took delivery of my g80 at the end of 2022, and by the time of the break-in service I noticed my exhaust tips from the factory were not all completely in alignment. The service rep agreed, and said they could replace the muffler. I asked if they could replace the whole exhaust, since it's one unit after the cat that includes the muffler. The service rep said they can't replace the whole unit, since it's so large it comes in pieces from Germany. The one from the factory on the car is one piece, but a replacement would be several pieces for shipping and bolted together, requiring cutting of the original before installation. I decided to not go through with the replacement because the stock unit would be cut up, and rather just live with the slight mis-alignment. So basically, this is all to say they will likely not be able to replace the broken piece with a like-for-like replacement.
@g80mt on Instagram - 2023 BMW M3 6MT in Individual San Marino Blue / Tartufo
Past BMWs: 2013 BMW 128i 6MT M-Sport Slicktop, 2016 BMW 340i 6MT M-Sport Join BMWCCA today and become eligible for members only events, discounts, and the new car rebate of up to $1000! Feel free to use me as a referral (with member #553730) which enters me for a performance school day (I should probably be better at driving, anyway). |
URmyArtemis38.50 |
