BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) Enable Data Privacy to use Remote 3D view
      05-31-2023, 01:55 AM   #1
lotus1818
Drives: 23 Cape Green/Red Black X1
Got that 'Enable Data Privacy to use Remote 3D view' message again when I tried to take picture of my vehicle remotely with the cell phone, but at this time I could not because the vehicle is in the shop.
I have enabled the data privacy the first time when I picked up the vehicle from the dealership, then I remember I had to enable it again later on when I tried to take remote picture, now it asked again before it lets me take remote picture. It is so annoying and you will never know the privacy data is disabled until you need to take remote picture.
I wonder if anyone has the same experience that we have to enable the data privacy again and again..
      05-31-2023, 04:06 AM   #2
Tunners
Tunners's Avatar
Drives: BMW X1 (U11) 30e M Sport
Not had that message in the 3 months I have had the car. I enabled all in the iDrive privacy settings when I collected the car.
      05-31-2023, 07:59 AM   #3
FlashMonkey929
I Shoot People For Money
FlashMonkey929's Avatar
1212
Drives: 2023 Portimao MSport X1
2003 BMW 330i ZHP  [0.00]
2023 BMW X1  [10.00]
Mine worked from the start, though I don't remember the exact process I used for setting up the car profile.
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold-
2020 430i Estoril Coupe MSport -returned-
2023 X1 Portimao, Msport, Premium
2003 330i Imola Red ZHP 6 Speed
      05-31-2023, 08:13 AM   #4
lotus1818
yes, mine was also working from the start after I had enabled the data privacy and I thought it would stay that way, but I think the update process may have something to do with the disabling of the privacy and I needed to enable it again. It is just annoying when you needed to take picture and found out you couldn't.
      05-31-2023, 08:14 AM   #5
FlashMonkey929
1212
2023 BMW X1  [10.00]
I've had 2 updates so far and haven't had to re-enable anything, mine still works as usual.
      05-31-2023, 11:40 AM   #6
gpbayarea
Drives: Subaru Outback
I had to enable for each profile user on the car. So if the garage is using guest profile as the last logged in user, that might be the issue?
      05-31-2023, 02:27 PM   #7
tex2670
tex2670's Avatar
Drives: '23 X1 28i xDrive
Each one of the software updates I've run did change some random setting back to factory default (auto high beams; welcome screen sounds); but I don't have this feature,
      07-24-2024, 01:22 AM   #8
Lutrinio
Drives: X1
Got my car (idrive9). Can’t get it to work. The 3D version works just fine but can’t get the internal one to work. See pic
All settings seem to be enabled (drive 9 is a mess compared to 8)!
Can anyone advice if they managed to fix it
      07-24-2024, 04:07 AM   #9
FZI89
FZI89's Avatar
Austria
685
Drives: BMW iX1, U11
I have the opposite problem (iDrive 8)
Remote inside view works, remote 3D not even an option for me to select
      07-24-2024, 05:25 AM   #10
Lutrinio
Drives: X1
Ok. I haven’t tested yet but contrary to what the message say( check the car), there is a session in the app which might do the trick.
You will find that menu under vehicle setting on the app.
I didn’t have everything okayed. And inside view was pending so I suspect enabling that will do the trick.
I will test it later ( it says that the option will become available after the first drive)
      07-24-2024, 05:29 AM   #11
FZI89
FZI89's Avatar
Austria
685
Yep! I’ve done all of that before. Still no option for remote 3D view. Even went to my local bmw dealer and they are as useless as always.
Sometimes I really feel we know more about the cars than they do.
      07-24-2024, 05:44 AM   #12
Lutrinio
Drives: X1
Glad to hear it wasn’t just me. Speaking to the genius it’s like talking to my mum. They literally know nothing
FZI89684.50
      07-24-2024, 06:31 AM   #13
FZI89
FZI89's Avatar
Austria
685
They’re very incompetent. And they really don’t care when you’re complaining about they’re entry-level models. If you drive a 5er or above, they start to care a little more
      07-24-2024, 06:40 AM   #14
Hartside
Drives: X1 U11 30e MSport
In the car, I had to tick every option on the privacy screen and then it worked.
      07-24-2024, 07:37 AM   #15
MMandov
Drives: iX1 eDrive20
That's country (EU) specific. Same for me in Bulgaria: you can only view 3D and videos if they are a result of alarm event.
      07-24-2024, 08:42 AM   #16
FZI89
FZI89's Avatar
Austria
685
This makes sense. With all the EU laws, I can imagine remote 3D view would be a problem
      07-27-2024, 01:16 PM   #17
crowdedhouse
crowdedhouse's Avatar
72
Drives: 2024 JCW Countryman ALL4
I'm not sure if it's any help as I have a Countryman and it took me a while to find the setting. It was under Vehicle/Data Privacy/(MINI) Permissions (leftmost on the screen). The initial screen did not open to these.
Seven Worlds Will Collide
      07-31-2024, 01:18 PM   #18
dkan94
Drives: BMW X1
Were you able to get this fixed? I'm having the same issues where remote outside view works fine but i can't get the remote inside view to work. It gives me the same data privacy setting popup and i cant find what to change in the vehicle settings through the MyBMW app or the car digital privacy settings. Thanks!
      07-31-2024, 01:22 PM   #19
Lutrinio
Drives: X1
Yes. Had to change the privacy settings on the app however I first turn them all off. Restarted idrive and then turns everything back on and restarted again. After an actual drive it started to work
      08-19-2024, 02:16 PM   #20
FZI89
FZI89's Avatar
Austria
685
Just a heads up: found this in the FAQ section of the Austrian BMW website (translated):
“With the Remote 3D View, you can see a three-dimensional snapshot of your BMW from the outside and the vehicle environment in the My BMW app. Due to legal regulations, Remote 3D View is currently only available in these delivery countries: Australia, Belgium, Brazil, Germany, Estonia, France, Hong Kong, Ireland, Italy, Japan, Latvia, Lithuania, Luxembourg, Malaysia, Mexico, New Zealand, Netherlands, Poland, Portugal, Russia, Switzerland, Spain, Singapore, South Africa, South Korea, Taiwan, Thailand, United Kingdom, and USA and Canada.”
DiS18.00
