BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) Exhaust Flap Fuse
      09-15-2023, 03:38 PM   #1
philsterxtz
Drives: 2023 BMW x1
Exhaust Flap Fuse
Hey guys,
Looking to disable exhaust flaps ... is there a dedicated fuse to pull?
Thanks!
X1m35i3.00
      04-03-2024, 04:31 AM   #2
X1m35i
X1m35i's Avatar
Drives: Bmw X1 M35i
Originally Posted by philsterxtz View Post
Hey guys,
Thanks!
Also looking for this fuse
Anyone knows?
      04-03-2024, 10:06 AM   #3
JAYtheVET
JAYtheVET's Avatar
20
Drives: '23 X1 X23d MSport
Anyone knows?
Put the car in Sport mode and disconnect the electrical connector to the exhaust valve. It should stay open then. Works with most other BMW's.
I would need to see the fuse diagram otherwise. Usually there is either a sticker in the fuse box or in the manual...I can't find the manual in pdf form on the interwebs yet.
X1m35i3.00
      04-03-2024, 10:11 AM   #4
X1m35i
X1m35i's Avatar
Drives: Bmw X1 M35i
I have the diagram
How can i send it to you?
I send a picture can you see good?
      04-03-2024, 10:14 AM   #5
X1m35i
X1m35i's Avatar
Drives: Bmw X1 M35i
And here is another pictures whit some more fuse numbers, also from my x1
      04-03-2024, 01:08 PM   #6
JAYtheVET
JAYtheVET's Avatar
20
I can't find the symbol for the exhaust valve controller. I'm sure they have omitted it from the chart or have not listed it anywhere due to the noise pollution laws in Europe.
The most common "fix" and my recommendation is a much easier way to do it. Buy blank plug caps and pull the electrical connector on the valve controller.
Turn on the car, select sport setting when the car is warm which opens the valves, look in the tailpipe to make sure the valve is open, pull the plug (should be just behind the muffler, you can't miss it), put the blank cap on the plug and secure it to the module.
You should be good to go. I'll ask some mechanics if they know the fuse and let you know when I have an answer because I can't tell from the fuse chart.
X1m35i3.00
      04-03-2024, 01:13 PM   #7
X1m35i
X1m35i's Avatar
Drives: Bmw X1 M35i
Thank you
I did this, but it must be 2 Persons.
The valves just opens when u give gas(trottle) if you dont, it closes immediately.One person must give trottle, and when it opens you must unplug the wires
      04-03-2024, 01:34 PM   #8
JAYtheVET
JAYtheVET's Avatar
20
Thank you
Or you can use a stick to push it open.
      05-13-2024, 01:40 PM   #9
TheNLVYuman
Retired USA
Drives: 2023 BMW X3 & X1 M Sports
I was told that the Exhaust Flap Fuse is #52, a 7.5 Amp Fuse. However, nobody knows the EXACT location of the fuse panel.
      05-13-2024, 02:08 PM   #10
BMWZ4
BMWZ4's Avatar
1914
Drives: '23 X1/'23 Allroad Progressiv
Ah...the old golf tee trick. I haven't heard about that hack in ages lol
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
      05-13-2024, 03:58 PM   #11
COOLGREANY
COOLGREANY's Avatar
Drives: 24 xDrive28i Space Silver
There's one fuse panel under a trap door under the passenger dash and another on the driver's side footwell near the OBD connector.
Can't tell you which one has fuse you want without seeing the specific fuse map for that particular vehicle.
