BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) X1 Aftermarket wheels
      03-31-2024, 12:35 PM   #45
BimmerViews
Drives: X1
Originally Posted by bmwZ View Post
Hi,
I just wonder if somebody else is thinking of mounting aftermarket wheels on their new X1?
Have anybody seen pictures of an U11 X1 with 20" aftermarket wheel?
I have an IX1 in order and have bought 20" glossy black wheels with low offset. So they will stick out some more than oem wheels.
The specs is:
Front: 8,5" ET40
Rear: 9" ET35
I have not decided if I will go for a wider rear tyre. So I bought two different dimensions for the rear, 245/40-20 and 275/35-20. I have to test on the car which will fit the best. Since this is a EV I have to think about the extra consumption the wide rears will give as well. My IX1 waiting for shipment at the port here in Norway, so hoping for delivery soon
Attachment 3084563
UPDATE:
Finally my IX1 arrived and I couldn't wait, so I test fitted my summer wheels at the workshop. It's still snow here in Norway, so I have to wait two month for driving on them.
Wheels are still within the fenders
Where did you buy the wheels
      04-02-2024, 05:31 PM   #46
GX
Drives: 2021 X1 2022 X2 2023X1
Hi All, Im using a 971 wheel, and tires are 225/40/R19...what tire pressure should i use? Thanks in advance
      04-02-2024, 11:31 PM   #47
FZI89
FZI89's Avatar
Austria
433
Drives: BMW iX1, U11
Check the sticker on the driver side door. Has all the info there
GX1.50
      04-24-2024, 01:23 PM   #48
chriscross
Drives: BMW X6M 2024, Mustang MACH 1
Hi all, just ordered the U11 M35i for my wife and there was no all black wheel option available. We decided to buy an all black aftermarket 20" set separatelly and BMW will mount them on before pick-up.
We like the black Borbet BY wheel, but I'm not sure it'll fit the U11 X1 M35i. The 5x112 wholes seem to be right, the width and size 8x20 also checks out, but then the ET45 and some number 72,5 differs a bit from the OEM 20" wheels (ET46 and 66,6).
Can anyone decipher this for me, is the wheel going to fit? I wanted to put the 245/40 R20 all around.
Cheers!
      04-24-2024, 02:14 PM   #49
JAYtheVET
JAYtheVET's Avatar
21
Drives: '23 X1 X23d MSport
Cheers!
I bought the exact same wheels for my 2023 23d. In Germany you aren't allowed to mount the wheel if it doesn't fit perfectly. I'm going to fit them either this weekend or next weekend depending on the weather outlook.
I'll post a pic when I can so you can see exactly how they will look.
How long are you willing to wait? Earliest day I'm willing to mount them is Friday.
      04-24-2024, 11:23 PM   #50
chriscross
That would be awesome, thanks! We just ordered the car, so time is on my side.
I'm in Austria and they have similar rules for aftermarket parts...but this wheel seems so close to the OEM that I think it should fit well. The ET is 1mm less, so whatever...the only thing is the 66,6 vs 72,5 number. I saw some adapters being sold...not sure it's the way to go.
      04-25-2024, 12:36 AM   #51
FlashMonkey929
FlashMonkey929's Avatar
1056
2003 BMW 330i ZHP  [0.00]
2023 BMW X1  [10.00]
That would be the center bore diameter. My BBS wheels needed the correct size ring to be installed so that the wheels would center properly on the hub. You could get by without them if you’re really careful when tightening the lug bolts (I’ve done it in the past), but if the wheel isn’t perfectly centered when you tighten everything down you’ll feel it when you drive.
2011 335i Alpine White Sedan PPK -sold-
2020 430i Estoril Coupe MSport -returned-
2023 X1 Portimao, Msport, Premium
2003 330i Imola Red ZHP 6 Speed
      04-25-2024, 08:18 AM   #52
richiro
Drives: 2024 BMW X1 M35i
Cheers!
You can buy adapter rings that go inside the center hole(bore) of the rim. They likely have them on Amazon, I was able to find aluminum 73 to 66.6 rings, shouldn’t be too difficult to find
      04-25-2024, 04:29 PM   #53
Spdrush
Drives: 2024 X1 M35i
Good thread. I was able to find an M135i with summer tires and 20" wheels. I will need 19" snows in the fall.
Question what difference in handling is present with wider tires or larger offsets. Is there a performance gain in is this only cosmetic.
      04-25-2024, 06:49 PM   #54
FlashMonkey929
1056
2023 BMW X1  [10.00]
For summer tires, the tire tread and compound make a bigger difference, unless you're talking a massive change in tire size. Larger offsets are usually done for either cosmetic reasons or for clearance against hitting other components.
For winter tires I can't comment as I will never need them where I live.
      04-25-2024, 07:54 PM   #55
NotARobot
Drives: BMW X1
Originally Posted by bluecrabby View Post
I wonder if they make this badge for BMWs?
How about this?
      04-26-2024, 04:24 PM   #56
JAYtheVET
JAYtheVET's Avatar
21
So...I've added the XY's
Here yoName:  20240426_160834_resized.jpg
Size:  362.3 KBu go.
