02-17-2024, 10:07 PM | #1 |
Rep 2,381
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
DIY: IND Distribution Roundels and Emblems (Gloss Black)
Hi All,
I finally got around to installing my IND Distribution painted Front and Rear Roundels and Wheel Center Caps as well as rear emblems. The change may seem minor but it makes a huge difference IMHO. Additionally, I added some vinyl overlays to the Roundels to change up the blue to black from Metro Restyling. I know others have posted some other very cool roundel options but I have always loved these with just the minor changes over stock. I threw together 3 DIY vids for these for those who are interested and will write out some steps for each below. It is also worth noting that both of these guides should work for most other BMW models. Here are some post installation photos as well: Front/ Rear Roundels: 1. Clean off the roundel 2. Put strips of painters tape around the roundel, tucking as much as possible underneath 3. It will take some time but work your way all the way around, when you are done none of the car's paint should be visible around the roundel 4. Using a heat gun or hair dryer, heat up the roundel 5. Use pry tools to gently work your way behind the roundel and work it loose 6. Keep in mind that there are 2 legs at the 3 and 9 o'clock positions that you will have to work around 7. Once popped out, use adhesive remover and some elbow grease to clean off the surface under the roundel 8. Peel the adhesive backing off of the new roundel 9. Guide those 2 legs into the holes on the car and push in 10. Put some pressure to make sure the adhesive makes good contact Wheel Center Caps: 1. Clean the center caps, they should be as clean as possible for this 2. With painters tape or clear packing tape, place a few long strips across the cap, making sure to seal it well against the center cap itself 3. using your nail, push the tape into the crevice around the center cap to create a nice tight seal 4. Life the edges of the tape off the wheel as much as possible while leaving them with as much contact as possible on the center cap 5. Grab all ends of the tape and pull evenly and straight out, the cap should pop right out 6. Pop the new center cap in Emblems: 1. Clean up the areas around the emblems to have a clean surface 2. With painters tape outline the emblems closely in order to give yourself a template to install the replacements 3. Use a heat gun or hair dryer to heat up the emblems 4. Use fishing line to work your way across the back of the emblem and remove them, add more heat as needed as you go 5. Once the emblem is off, remove whatever adhesive you are able to, this works much better with some heat 6. Use some adhesive remover and a microfiber to work off the rest of the adhesive 7. Clean off the area with a bit of soap and water to remove the adhesive remover 8. Clean that off with some water and dry the area 9. Apply the new emblems using your template tape 10. You may either place one character at a time or use some tape over top of the emblem to transfer it over (if it is lined up already) **NOTE**: I did this install on a very wet and rainy day which is not ideal of the adhesive, I suggest doing this in a garage or on an more suitable day.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 Last edited by abirmaher; 02-19-2024 at 10:16 AM.. |
02-18-2024, 12:25 AM | #2 |
I Shoot People For Money
1055
Rep 1,921
Drives: 2023 Portimao MSport X1
For the trunk and hood roundels I just got some nylon floss and a plastic pick and pushed it behind from above the pegs and another length from below the pegs. Had them go as close the center as possible and then grabbed both lengths and pulled outward. I thought about taping it off, but 🤷🏻‍♂️
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold- 2020 430i Estoril Coupe MSport -returned- 2023 X1 Portimao, Msport, Premium 2003 330i Imola Red ZHP 6 Speed |
02-18-2024, 07:47 AM | #4 |
Rep 2,381
They’re sitting in the garage, that’s next
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
02-18-2024, 07:48 AM | #5 | |
Rep 2,381
Follow my builds:
02-18-2024, 08:09 AM | #6 | |
Rep 2,381
Follow my builds:
02-18-2024, 09:06 AM | #8 |
Rep 133
Love the black roundels. They make the car look so much cleaner.
Personally I would debadge tho. I debadged mine and love the outcome. I much prefer not having “//M” given that this isn’t an M car. Next will be black roundels for me |
02-18-2024, 11:19 AM | #9 | |
Rep 233
02-18-2024, 12:17 PM | #10 | |
Rep 2,381
Follow my builds:
02-18-2024, 08:56 PM | #13 |
Rep 2,381
I’m going with black. We’ll see how it comes out. Will post about that soon.
Follow my builds:
02-18-2024, 09:38 PM | #14 | |
1055
Rep 1,921
02-19-2024, 09:33 AM | #15 |
Rep 2,381
Usually here too... sadly I picked the rainiest day to do this one... not recommended
Follow my builds:
FlashMonkey9291054.50 |
02-20-2024, 10:06 PM | #16 |
Rep 12
Black IND badges
I put the black IND badges on my silver M35i. They stand out so much better than the factory "chrome" badges on the hatch. I also bought black M badges for each of the front fenders since BMW deleted them for the US market.
abirmaher843.50 |
02-21-2024, 05:55 AM | #17 | |
Rep 2,381
I decided to go the opposite route and try to hide the badges on the black paint.
Follow my builds:
