05-06-2023, 12:16 AM | #1 |
slowest X1 driver ever
496
Rep 969
Drives: '23 X1 M Sport, '24 530i(soon)
pressed engine start/stop button accidentally while the car was still moving at 5mph
While I was slowly moving towards a tight parking spot with a light post in front, I wanted to press the parking camera button in order to see the front and avoid hitting the light post.
The car was still doing just under 5mph while I reached over and hit the button. Unfortunately, I hit the engine start/stop button instead of the camera button(which was next to it) It immediately sent the car into a somewhat violent jolt and then it stopped. The screen showed a warning message that said something about the car automatically shifting into neutral. Not sure of the exact wording of that message because it went away in less than 1 second while the car went into a screeching halt and the engine stopped. The car was just half way into the spot at that point. I restarted the engine and slowly moved forward. Did my stupid mistake cause some kind of damage? |
05-06-2023, 03:08 AM | #2 |
Rep 194
I doubt you caused any damage. The rapid sequence of events would most likely be: 1) shift into neutral 2) engine off 3) parking brake applied 4) gearbox shift into park
When you stop the car in a normal situation and then press the engine start/stop button, the above is what happens. I have no idea at what speed threshold it is set to not do what happened to you, and I don't want to find out either! Related, I did find out by accident that the emergency auto-brake does work too, which also stops the car quite violently - I was reversing into a familiar spot and yes, the reversing beepers were getting more and more desperate in their tone as I approached something that even if I touched it would not damage the car, namely tall, soft grass. Anyway, I continued as this particular parking spot is not very long and I needed to use every bit of space. Next thing I know, the car decides I don't know what I'm doing and slams the brakes on and stops the engine! Even at a crawling speed, it took me by surprise! Last edited by Duncs1961; 05-06-2023 at 10:58 AM.. |
05-06-2023, 04:31 AM | #3 | |
Rep 1,818
05-06-2023, 10:10 AM | #4 | |
496
Rep 969
When I pull forward in my X1, the parking sensor or cameras really, really freak out when the PVC pipe is detected. There's a lot of resistance in the brakes. If I let go of the brake and just very slowly move forward, the car applies emergency braking almost violently when the front bumper is about 6 inches from touching that PVC pipe. speaking of parking sensors, cameras or whatever the X1 uses to automatically find an open parking space and park itself. This morning, I was stopped at a traffic light. It was a 6-lane road crossing a 4-lane road. I was in the left-turn lane with my left turn signal on. I was the 2nd car waiting to turn and there were probably 6 or 8 cars behind me as well. As soon as the left green arrow came on, I started driving and followed the car ahead of me to perform the left turn. Right in the center the intersection, I heard a beep and the screen showed me a message saying that it found a parking spot and asked me if I wanted to REVERSE into that spot.(!!!!!) Obviously it was an error, because I was sure that my town did not start letting people park in the middle of a busy intersection. I ignored the message and continued on my way. |
05-06-2023, 11:03 AM | #5 | |
Rep 194
05-06-2023, 04:49 PM | #6 |
496
Rep 969
in the interest of science, while going through that intersection again about an hour ago, I turned around and performed the same turn at the exact same spot. It did it again!!! The only thing remotely resembles a parking spot is the grassy center medium. The reverse parking message came up as soon as I drove past it during the left turn.
I'll try to bring my gorillapod mount and use my phone to record it when I go there again on Monday after work. (so I have something to show the BMW tech in case this keeps happening) |
05-07-2023, 12:22 PM | #7 | |
Rep 78
Same happened to me 3 times for last 2 months. Car stop playing music and start talking / asking if i want to park reversely when I am driving already on a road. Took couple of seconds to understand impossibility and shutting up. A bug. |
05-07-2023, 12:29 PM | #8 | |
Rep 78
05-07-2023, 07:37 PM | #10 |
496
Rep 969
I bought a new car with factory navigation system for the first time 24 years ago. That was before even smartphones came on the scene with Apple Maps or Google Maps. I kind of stopped using paper maps since then. Fairly certain that I don't know how to read paper maps anymore.
Parking assistance is one feature that I will try not to use, except in difficult situations. I do not want to come back in 20 years and say "I don't know how to parallel park cars thanks to technology!" |
