05-08-2023, 07:57 PM | #1 |
Rep 5
Drives: BMW X1 2023
2023 X1: harsh ride, run flat tires
I'm a bit concerned about the harsh ride, and was researching tires installed on my vehicle.
It looks like tires that came with my 2023 X1 (Continental ProContact™ GX) are run flat tires. I thought the X1 came with non run flat tires when I purchased it. At least that's what the configurator on BMW's website said. Also, I have a spare tire in the trunk. Could this be a production error? Did anyone else have similar issue? Whom should I talk to if I want to replace them with run flat tires? Could you please give me some advice? |
05-08-2023, 08:55 PM | #2 |
Rep 81
Check your order confirmation. Mine states clearly on my order that it's for Non-RFT tires. I'd bring it up with your dealer and get them to fix it, if this is the case - one of the upsides of the X1 is the non run flats, so I'm going to be annoyed if they try to sneak them onto mine lol.
There was another poster here a while ago saying they got RFT's on their X1, but I can't find the post and I'm not sure what (if any) outcome there was. |
05-08-2023, 09:17 PM | #3 |
Rep 71
I've got the same tires on mine and the order clearly calls out "all-season non-run-flat tires" so I'll check on Friday when we go in for our post delivery follow up. This is on 19" wheel BTW.
05-08-2023, 10:08 PM | #4 |
I Shoot People For Money
1056
Rep 1,922
Drives: 2023 Portimao MSport X1
So I have the Continental ProContact GX tires in 225/55 R18 on my X1, and they are non-runflat. There is a similar model of tire from Continental called the ProContact GX SSR that IS a run flat tire. I’m almost positive that mike are not run flat tires, especially with how easy I see the sidewall flexing. There are also no markings to indicate on the tire that it’s a run flat.
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold- 2020 430i Estoril Coupe MSport -returned- 2023 X1 Portimao, Msport, Premium 2003 330i Imola Red ZHP 6 Speed |
05-08-2023, 10:09 PM | #5 | |
1056
Rep 1,922
jejupods36.00 |
05-09-2023, 03:05 AM | #6 | |
Rep 5
Drives: BMW X1 2023
05-09-2023, 03:15 AM | #7 |
Rep 16
While there is no industry standard code, there are different letters used by manufacturers to signify a run flat tyre. These are as follows:
Bridgestone run flat tyres – ROF or RFT or RSC Continental run flat tyres – SSR Dunlop run flat tyres – DSST or ROF Goodyear run flat tyres – EMT or ROF Michelin run flat tyres – ZP |
jejupods36.00 |
05-09-2023, 06:15 AM | #8 |
Rep 71
Based on everything I've seen on the Continental site the plain GX tires (vs. the GX SSR) are non-run-flats. There was even a question posted regarding the 2 versions and the answer said not to mix the 2.
As far as the harsh ride goes, be sure to check your pressures as mine were a bit over-inflated by the dealer. However, even after adjusting the pressure the ride is still on what I'd call the firm side. |
FlashMonkey9291056.00 |
05-09-2023, 06:34 AM | #9 |
1056
Rep 1,922
I’m going to say you don’t have run flat tires and you’re just feeling the suspension.
05-09-2023, 01:05 PM | #10 | |
slowest X1 driver ever
496
Rep 969
Drives: '23 X1 M Sport, '24 530i(soon)
My X1 with M Sport suspension have Pirelli P Zero All Season 225/55/18 tires. The ride is noticeably "harsher" than the X-Line standard suspension with 19-inch Continental all season tires on the X1 demo car at the dealership. Since 18-inch tires are usually more comfortable than 19-inch tires, I also assume that the "harshness" that I'm feeling can be attributed to the M Sport suspension. That's only compounded by the very bad roads in my area, which they still have not fixed after years. Somehow it's so bad that the BMW navigation maps frequently have pop-up messages that warn me about uneven road surface ahead. However, just to be clear, I'm not really that bothered by this harshness. My other car had 225/40/18 tires so I'm used to it by now. |
05-09-2023, 01:27 PM | #11 | |
1056
Rep 1,922
05-09-2023, 01:38 PM | #12 |
Rep 4,478
Drives: '23 X1 28i xDrive
That has nothing to do with the car sensing road conditions. That's based on data in the nav system, like RR crossings and speed humps. It will tell you there's an "uneven surface" even on a road you've never been on before.
05-10-2023, 12:37 AM | #13 | |
Rep 5
Drives: BMW X1 2023
05-10-2023, 12:47 AM | #14 | |
1056
Rep 1,922
05-10-2023, 07:41 AM | #15 | |
Rep 71
I just got done with a chat session with Continental and they confirmed that the tires without the SSR designation are non-run-flat.
05-10-2023, 08:47 AM | #16 | |
496
Rep 969
Do you have the regular suspension or the M Sport suspension? |
05-10-2023, 06:44 PM | #17 |
Rep 39
I have the same question. I picked up my X1 on 4/21. During the up-sell at the dealership, I was told that the tire warranty was particularly important because I had run-flat tires. I said I didn't think that they were, and that my order specs indicated they were non-run-flat. The guy left for a few minutes, came back, and said that yes, they were run-flat. I let the issue drop at the time.
Fast forward a few weeks and I still think the guy was wrong. Mine are Continental EcoContact 6Q 245/40 R20. No sign of SSR anywhere. I also have a spare. I guess my best bet is to confirm with Continental but it's kind of annoying that my dealership may be passing on bad information. As an aside, I don't have any issues with ride quality. Just the bad info/labeling/identification on the tires. |
05-11-2023, 08:41 AM | #18 | |
Rep 4,478
You don't have to confirm with Continental. Just look at your tires, and if they don't say "SSR" like the pic above (or "RFT", or "ZP"), then they aren't RFTs. |
05-11-2023, 09:03 AM | #19 | |
496
Rep 969
of course, the "financing" part is 85% upsell. I was also given the sales presentation for 30 minutes. He also said that RFT tires were expensive and that I should at least buy that coverage. When I pointed out that the current X1 came with non-RFT, he admitted that he knew that, but was only reading from a script in his mind. |
05-11-2023, 09:26 AM | #20 | |
Rep 4,478
By the way, they scared me into getting wheel & tire coverage on my 3-Series with RFTs. Even with 3 nails, I still came out behind.... |
05-11-2023, 10:17 AM | #22 |
496
Rep 969
I've only been driving my new X1 for 14 days, but my guess is that the M Sport suspension on my X1 is the reason that the suspension feels stiff.(which is a good thing, obviously) I'm used to cars with stiffer and sometimes lowered suspension, so I don't really consider it to be "harsh"...
Having said that, I think the P Zero All Season 18-inch tires are harder than other 18-inch all season tires such as Hankook Continental.(but softer than the Bridgestones) |
