BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) X1 Aftermarket wheels
      02-10-2023, 09:53 PM   #23
FlashMonkey929
FlashMonkey929's Avatar
1024
2003 BMW 330i ZHP  [0.00]
2023 BMW X1  [10.00]
Originally Posted by PlasticEngine View Post
wow... that company makes me laugh... they only make wheel locks for BMW 2002 from 40+ years ago???
Probably because OEM wheels use wheel bolts, not lug nuts. I just gave the first thing that popped up on google. But there are other companies out there.
Here's another site, you can email them and ask which ones fit the X1:
https://www.ecstuning.com/Search/Sit...h/wheel_locks/
2011 335i Alpine White Sedan PPK -sold-
2020 430i Estoril Coupe MSport -returned-
2023 X1 Portimao, Msport, Premium
2003 330i Imola Red ZHP 6 Speed
      06-04-2023, 06:52 AM   #24
FZI89
FZI89's Avatar
Austria
419
Drives: BMW iX1, U11
Originally Posted by bmwZ View Post
Hi,
I just wonder if somebody else is thinking of mounting aftermarket wheels on their new X1?
Have anybody seen pictures of an U11 X1 with 20" aftermarket wheel?
I have an IX1 in order and have bought 20" glossy black wheels with low offset. So they will stick out some more than oem wheels.
The specs is:
Front: 8,5" ET40
Rear: 9" ET35
I have not decided if I will go for a wider rear tyre. So I bought two different dimensions for the rear, 245/40-20 and 275/35-20. I have to test on the car which will fit the best. Since this is a EV I have to think about the extra consumption the wide rears will give as well. My IX1 waiting for shipment at the port here in Norway, so hoping for delivery soon
Attachment 3084563
UPDATE:
Finally my IX1 arrived and I couldn't wait, so I test fitted my summer wheels at the workshop. It's still snow here in Norway, so I have to wait two month for driving on them.
Wheels are still within the fenders
They look great!
Some questions for you: Have you managed to drive with these? How are you liking them? Any hit on the range?
And finally, are these the Z-Performance ZP2.1?
Thanks!
      09-09-2023, 02:37 AM   #25
hawaiiguy
Drives: '23 X1 MSport
Does anyone live close to TIRE RACK headquarters in South Bend, Indiana? So they can take the x1 to their headquarters for fitting purposes as their email response to me say they likely will have not have rims available on the site until after the winter season...
Re: Question for Sales From www.tirerack.com - ##RE-212749##
Yahoo
Inbox
Tire Rack Sales <saleshd@tirerack.com>
To:
Fri, Sep 8 at 10:15 AM
Unfortunately we wont have any info on wheels we carry that fit until the car is sent here for the engineers to measure. Going into the winter season, that may not happen until the beginning of next year unless a local customer with the vehicle brings theirs in to pull that information from the car.
Description : [EXTERNAL EMAIL] DO NOT CLICK links or attachments unless you recognize the sender and know the content is safe.
Below is the result of your feedback form. It was submitted by
on Thu Sep 07 03:23:15 EDT 2023, app10-ign_retail1
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36 Edg/116.0.1938.69
Question: re: rims for a 2023 bmw x1 28i (none available at present for sale)
Hello, when will Tire rack have a supply of rims in the 19 inch sizes? I am looking for an all black colored wheel rim 19x8 or 19 x 8.5.
Please let me know if anyone knows as to when it will be posted on the website..
thank you so much !
      09-09-2023, 03:20 AM   #26
FlashMonkey929
1024
2023 BMW X1  [10.00]
Yahoo
Inbox
To:
thank you so much !
Fitment should be similar to the F48 X1 from what I've read. I currently am running 19x8.5 BBS RGR's ET32 and they are flush with the top of the fender with plenty of clearance with the suspension. In keeping with the preprogrammed accepted sizes in the TPMS system, a 245/45/19 tire is the ideal size. I personally don't buy from Tire Rack unless I have to, their shipping to Hawaii is pretty steep. Amazon Prime ships tires though! Got my Hankook Ventus V12 evo2's from them last month.
      09-09-2023, 01:30 PM   #27
M_litened
Drives: BMW X1 m35i
A quick question I have, and I think there's some debate over this in another thread, but did any of you who did swap out for aftermarket wheels, upgrade your lug bolts as well?
      09-09-2023, 04:41 PM   #28
FlashMonkey929
1024
2023 BMW X1  [10.00]
I swapped to a stud conversion and lug nuts. OEM thread pitch is 14x1.25, I got a conversion stud set that changes the wheel mounting side to 12x1.5 since there are much more readily available lug nuts in that size. They’re also longer than stock length so I had the option to run spacers if needed, and I got some Project Kics open end lug nuts with a floating seat to help with ease of centering and reduce wear on the paint of the lug seat.
      09-09-2023, 09:24 PM   #29
SeattleX1
SeattleBMW
99
Drives: Porsche911 BMWM2
In the case of a wheel swap, the most significant variable to trigger the need to renew lug nuts is the type of seating used in the wheel that is replacing the original. Ie if your Oem set up uses conical seats (as in the case of the X1) and your replacement wheels use ball seats, then change the lugs. If you plan on using spacers to make up for an offset issue, then change the lug length commensurate with the spacer width.
      09-10-2023, 03:57 PM   #30
SpaceSilverX1
slowest X1 driver ever
491
Drives: '23 X1 M Sport, '24 530i(soon)
in that case, will the new aftermarket wheels need to be torqued to the same specs as the original BMW wheels of the same size?
      09-10-2023, 11:18 PM   #31
SeattleX1
SeattleBMW
99
I recall running some forged HREs on one car and called them on torque settings (as they were forged)….the tech said go ahead and use manufacturer specs as I was using exactly the same lugs. I’ve applied that answer in every case including when I change the lugs and not had any issues.
      09-11-2023, 12:39 AM   #32
FlashMonkey929
1024
2023 BMW X1  [10.00]
Yup, I was told the same thing. They said if the mounting hardware says different, then that may be another story, but generally factory specs are fine.
      12-11-2023, 01:27 AM   #33
dboey
Drives: Mercedes AMG C43
Do you have a photo of your X1 running 19 X 8.5 ET32 wheels, Thanks.
      12-11-2023, 03:14 AM   #34
FlashMonkey929
1024
2023 BMW X1  [10.00]
Here you go. I posted them in one of the threads but it’s probably buried somewhere.
timesone184.50
      03-22-2024, 12:27 AM   #35
BimmerViews
Drives: X1
Hi,
The specs is:
Front: 8,5" ET40
Rear: 9" ET35
Attachment 3084563
UPDATE:
Where did you get these wheels?
      03-25-2024, 04:15 AM   #36
GX
Drives: 2021 X1 2022 X2 2023X1
Just wanted to ask, was this a change from 18" to 20"? Any issues?
      03-25-2024, 04:23 AM   #37
FlashMonkey929
1024
2023 BMW X1  [10.00]
You shouldn't have any issues as long as you stay with the proper sized tire diameter.
      03-27-2024, 09:46 PM   #38
GX
Sorry, are the offsets the same for all OEM wheels?
      03-27-2024, 09:50 PM   #39
FlashMonkey929
1024
2023 BMW X1  [10.00]
No, they are not, they vary from model to model. For the U11 X1 I believe they are all the same, however if you want the wheel to be more flush or more inset into the wheel arch you'll have to do your own calculations on what will fit. There are many helpful articles online if you google "calculating wheel offset"
GX1.50
      03-29-2024, 09:22 PM   #40
GX
I saw a wheel that has IS27...i was researching and i think in a post it said that this is the off set. Will this work with the U11? Thank you
      03-30-2024, 02:24 AM   #41
FlashMonkey929
1024
2023 BMW X1  [10.00]
What are the other specs of the wheels? Diameter and width are important. An offset of 27 will technically fit, but will protrude from the wheel arches slightly. But if the wheel diameter is too wide you may have clearance issues with the suspension, that’s why the full specs of the wheels are important.
      03-30-2024, 08:09 AM   #42
GX
Thank you so much for helping....the wheels are all 8J x19 H2, IS 27. tires are 225/R/40/19. Thank you
      03-30-2024, 08:13 AM   #43
FlashMonkey929
1024
2023 BMW X1  [10.00]
They’ll mount on the X1, but they will protrude from the fenders a bit I think.
      03-30-2024, 08:40 AM   #44
GX
Thank you
