BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) X1 Headlights, a downgrade from 3 Series?
      03-27-2024, 09:44 AM   #1
BrooklynM240i
Drives: M240i 2024: X1 M35i '24 -Sold
First time using my new X1 M35i in the dark last night and the headlights don't seem to be on a par with my previous 2020 G20 3 Series?
That car had laserlights which are epic, and adaptive headlights with high beam assist.
My X1 doesn't have the throw of the 3 series, ok they aren't laser lights so perhaps that's to be expected.
The real issue is that the high beam assist doesn't seem to do anything even though the icon is lit up on the dashboard. At no point did the main beam activate during my 50 mile drive even though it should have at several opportunities. Manually using main beam over-rides this but when returning to normal beam, the assist function is deactivated and can only be turned on again through the touchscreen menu which seems so counter intuitive compared to a 4 year old model.
The second part is that the adaptive headlights don't seem to do anything. My 3 series had the lights dancing all over the road and kept high beam on for a significant amount of time, tracking the lights away from oncoming traffic and cars in front as it should do. What is going on?
robe03373.00
      03-27-2024, 11:47 AM   #2
Kosymodo
Kosymodo's Avatar
Drives: iX1 xDrive30 M Sport
This isn't the case in my iX1 (ID8), but yours might be different if ID9? I can override main beam assist, and when returning it to low beam the assist function resumes
Again, not the case in mine. I find the adaptive headlights to work very well. Definitely noticeable when the 'blocks' of light engage/disengage
This video shows exactly how mine behave -
timesone184.50
      03-27-2024, 05:39 PM   #3
MontyB1
Drives: BMW X3
Certainly see the adaptive lights working and main beam being great. It’s faster reacting than the system on the 3 series X3 from my experience and more accurate.
timesone184.50
      03-27-2024, 05:51 PM   #4
timesone
timesone's Avatar
Drives: 2023 BMW X1
Mine work fine (much quicker adaptive response than my F87 M2) and I definitely don’t see any downgrade from my 2024 X4 on twisty back roads
      03-27-2024, 06:46 PM   #5
richiro
Drives: 2024 BMW X1 M35i
Have to agree, had an x3 loaner for a month and when I finally got my car back I noticed the lights don’t throw nearly ss much light or seem as adaptive as the x3.
The loaner didn’t have laser lights but the standard bmw led on those definitely throw more light and illuminate better.
      03-29-2024, 01:02 PM   #6
HumbleBy
Drives: Mercedes C300 & BMW iX1
There is a Swedish car magazine who tests and analyses headlights and their performance.
The 1, 3 and X1 series fall into a category of quite poor main beam performance.
It seems to be very "hit and miss" with BMW in general in terms of headlight performance.
We have an iX1 coming soon, and hope at least the low beam is acceptable.
      03-29-2024, 04:51 PM   #7
Fahren German
Fahren German's Avatar
Drives: 335i RWD 6MT
The IIHS headlights test rated the X1 as good. Here’s what they said:
Low beams
On the straightaway, visibility was good on both sides of the road. On curves, visibility was good in all 4 tests.
The low beams never exceeded glare limits.
High beams
On the straightaway, visibility was fair on both sides of the road. On curves, visibility was fair in all 4 tests.
High-beam assist compensates for some limitations of this vehicle's low beams on the straightaway, on both left curves and on both right curves.
      04-04-2024, 03:59 AM   #8
Tazz
Drives: BMW X7 M50d (2019), BMW X1 20i
My x1 headlights are better than our x7 with laser lights in terms of adaptive performance, but the laserlights are much brighter, and since the laser lights require the lights to physcially move, there are a lot more drivers that flash our x7 rather than the x1. the only problem is that both systems blind truckies if their lights cant be seen (since they sight higher than gaurd-rails or on hills). I currently found no idadequacies with the bmw lights, but i wonder why dont they move from left on left turns and right on right turns cause it concentrates all the light right infront of you
