02-02-2023, 12:20 PM | #2 |
Rep 158
You might find some useful information in this thread:
https://u11.bimmerpost.com/forums/sh....php?t=1978733 |
02-02-2023, 12:51 PM | #3 |
Rep 5,112
I had both installed by my local tech guy. Installed a front/rear Thinkware cam and RJ11 jack for the Unidens R3 detector...don't ask me which fuse he tapped though...I wasn't watching whilst he did the install ($155 install fee for both)
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
02-02-2023, 01:58 PM | #4 |
Rep 112
Just FYI, saw your build, and since you have Parking Assistance Plus you should also have the Drive Recorder in the apps menu.
Not totally a replacement for a dash cam, but you can set it up to trigger all four cameras around the vehicle to record for up to 40 seconds (20 before the trigger and 20 after) in the event of an impact/accident. |
bcdx9358.00 |
02-02-2023, 04:59 PM | #5 | |
I Shoot People For Money
1049
Rep 1,917
Drives: 2023 Portimao MSport X1
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold- 2020 430i Estoril Coupe MSport -returned- 2023 X1 Portimao, Msport, Premium 2003 330i Imola Red ZHP 6 Speed |
02-02-2023, 05:30 PM | #6 | |
Rep 126
02-02-2023, 10:30 PM | #7 |
Rep 119
Thanks to you guys for the info.
I have a question about theft camera. Do I have to arm the vehicle every time I parked the vehicle? I noticed the option is only for once. If I forgot to manually arm the vehicle in the ID8, I guess the recorder won't be triggered. I wish it was automatic with the parking of the vehicle. |
02-03-2023, 03:37 AM | #8 | |
1049
Rep 1,917
02-03-2023, 04:52 AM | #9 | |
Rep 119
Anyway, my question earlier was about the use of the theft camera. Do I have to remember to go to ID8 to turn on the theft camera every time I parked the vehicle if I want to arm the vehicle ? Can I turn it on with the My BMW app while away from the vehicle or set it to arm the vehicle automatically after I left and locked the vehicle ? |
tex26702424.50 |
02-03-2023, 04:54 AM | #10 | |
1049
Rep 1,917
02-03-2023, 08:25 AM | #11 |
Rep 5,112
If you're hoping for some sort of accident recording, it's not as efficient as a dashcam set-up as Cayenne pointed out. You may be disappointed in the results, if/when needed. Dashcams are super cheap these days. The built-in interior cam might be handy snagging a pic of the thief though...but the exterior cams...meh
02-03-2023, 08:44 PM | #12 |
Rep 19
I'm planning to install Thinkware U1000 dual channel dashcam on my iX1 when I get it.
Shame BMW doesn't have Sentry mode similar to Tesla's as it's the only feature I love about their cars. |
02-03-2023, 11:44 PM | #13 | |
1049
Rep 1,917
02-04-2023, 09:13 AM | #14 | |
Rep 5,112
In any case, as noted, dashcams are cheap these days. Go for it or don't.
FlashMonkey9291048.50 |
02-05-2023, 09:51 AM | #15 |
Rep 7
Fuse tap for Dashcam
Hi, I took the cover off under the glovebox to reveal the fuses (UK Spc so RH drive, LH glovebox for those of you outside UK.) I considered using the dimming mirror solution but did not want to trust the wire tap and voltage converter shown elsewhere in this thread.
Anyway, nowhere to find the fusecard online/dealer or in the car so i did it by trial and error, see attached the picture shows where i picked up a spare slot next to the yellow fuse alongside the blue square relay. This is power off when the car is locked/alarm armed/asleep but powered at all other times. The cable was run tucked easily into the roof lining then across the a pillar joint to the roof lining and down under the door seal. All neat and invisible, no disassembly apart from the dashboard left side panel, it’s push fit so easy to remove. With the end panel off and the fuse cover lowered the route is easy and straight through to the fuse box. All done in about 20 mins. Hope this helps some of you. Last edited by hulln000; 02-05-2023 at 02:10 PM.. Reason: Adding detail |
02-05-2023, 11:09 AM | #16 | |
Rep 158
Thanks for sharing. You help me a lot.
02-06-2023, 05:06 AM | #17 | |
1049
Rep 1,917
BMWZ41914.00 |
02-06-2023, 07:58 AM | #18 |
Rep 5,112
Excellent examples where built-in cams might not have done the trick. I hadn't thought of those. Dashcams are pretty small these days. The ones I have installed on both vehicles are tucked in behind the mirror...can't see them from the driver's seat so they don't impede the view in any way.
02-06-2023, 08:19 AM | #19 | |
1049
Rep 1,917
I have a Thinkware F200 with front and rear cams I used in my f32, and it was pretty okay. I imagine running the wires to the rear window may be a pain though.
02-06-2023, 08:38 AM | #20 | |
Rep 5,112
Also, don't get sucked into these 4k cams...not worth the extra cost. 1080p is plenty good for capturing vids. If you're happy with the F200, then stick with that or Blackvue 500 series....sometimes good is good enough!
02-06-2023, 08:53 AM | #21 | |
1049
Rep 1,917
I've got about $100 in rewards and the F200 Pro is on sale for $189 at Best Buy right now so I may end up picking it up sooner than later.
BMWZ41914.00 |
02-06-2023, 08:26 PM | #22 | |
Rep 126
You stated it's "power off when the car is locked/alarm armed/sleep." Does that mean the dashcam turns off when you lock the car? I would want it to still record if someone bumps/hits/vandalizes the car when it's parked somewhere. |
hulln0007.50 |
