07-16-2023, 08:57 AM | #1 |
Rep 49
BMW X1 U11 FitCamX Rear Camera Install
Thanks to others for pointing out the FitCamx product for our model... it is great! I got the front and rear kit and wanted to share some info on the rear cam install. The front cam is very slick, replacing the stock surround behind the rear view mirror. There is video on the vendor's site and instructions for it in the kit.
The rear you are on your own... until now. Have the tools shown available - plastic spudgers and some vinyl coated clothesline (fish) cable. The route is right along the seam where the headliner and vertical plastic pillar covers meet and between headliner and door gasket lip. The headliner is very forgiving and it is easy to push cable up in there fully. It gets fun when you reach point "1". This is where ultimately where all the extras length of cable goes but also where you have to get to point "2". Pinch and pull out ends of the flex hose that goes into the lift gate. The rear cam cable comes apart near the end - you can't fish the rear camera thought the tube! Use the fish cable to get the route, tape camera cable to it and pull. Untape and fish next path (2 to 3, and 3 to 4), etc. Getting the cable between the points is the hardest part - you can't see and have to just push/twist wire. Pinch flex tube back into sheetmetal - it will be full of wires but goes in easily. My rear camera has extra cable that will go back under panel above (below in pic) it and camera will be sticky mounted after my ceramic tint film goes on next week. This all (front and back) took about an hour and a half. Work slowly and gently with the prying and pushing. Cheers! |
07-17-2023, 05:43 PM | #2 |
I Shoot People For Money
1053
Rep 1,921
Drives: 2023 Portimao MSport X1
This is very helpful, thank you!
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold- 2020 430i Estoril Coupe MSport -returned- 2023 X1 Portimao, Msport, Premium 2003 330i Imola Red ZHP 6 Speed |
07-26-2023, 01:58 PM | #3 |
Rep 49
Part 2 of Guide - Rear camera install
OK, my Xpel XR Plus ceramic tint has been in a week so I can finish rear camera install. Just use the view on phone feature to position it and on it goes. Extra cable and the connector all fit into the trim panel — looks clean!
FlashMonkey9291053.00 |
11-09-2023, 04:09 PM | #4 |
Rep 8
Many thanks for the write up and pictures, I’m about to fit a front and rear dashcam with a power core dashcam battery situated in the boot/trunk. I was going to fit the wire for the front cam along the sill but now seeing your pics it looks to be much better to follow your route…..many thanks!
11-10-2023, 08:51 AM | #6 | |
slowest X1 driver ever
495
Rep 969
Drives: '23 X1 M Sport, '24 530i(soon)
when running the wires, I used a little bit of lubricant on the wires so they could slide into and out of the tubes easily. I was only running the wires for a GPS tracker and antenna into the tailgate, but it should be the same to run wires for dashcams. the parts diagram below helped me figure out where to pull. |
11-10-2023, 12:49 PM | #7 |
Rep 48
I have a FITCAMX as well! Does your camera turn on and off when you’re parked? Mine records like 11 seconds every 3 min and sometimes an hour in between each recording stops exactly 11 seconds.
It’s using the normal adapter and parking mode is off. |
12-11-2023, 07:48 PM | #9 |
Rep 126
12-11-2023, 08:17 PM | #10 |
1053
Rep 1,921
I can't comment on parking mode, as I don't have a backup battery installed yet and I probably won't hard wire it. You can use the app to view footage, or live view if you want. The app is a bit clunkier than the one for my Thinkware cam in my other car. You do have to disconnect from CarPlay if you want to connect to the app though, which is a pain in the ass if your infotainment system is on because it keeps trying to connect to CarPlay and disconnecting the camera app. Honestly, I just keep a car reader in my car and just eject the card to grab the videos and then pop the card back in. Much faster that way.
01-16-2024, 07:09 PM | #11 |
Rep 71
I can see how I would pull the wiring tubing at point 2 to insert the fish cable, but how do you get the fish cable to emerge at point 1?
Did you have to remove the headliner or the side plastic panel just below it? How did you remove it? So far I was able to route the camera cable without pulling/removing anything up to the junction between the headliner and tha panel... |
01-16-2024, 09:11 PM | #12 |
Rep 54
Drives: U11 X1 28i xDrive
What length of extra cable did you need to buy for the rear camera?
01-18-2024, 11:14 AM | #13 | |
Rep 49
PatL28.50 |
01-18-2024, 03:18 PM | #15 | |
Rep 71
Picture should be rotated 90degrees to the right... Next step is to pass the cable/junction behing the tailgate top plastic panel. |
01-18-2024, 11:51 PM | #16 |
Rep 71
I finally fished the camera cable through the tailgate top panel.
I had in fact to fish the fish cable itself because it is easier to go up through the cabling tubing hole and get the cable to emerge close to the glass. I am a bit concerned about glueing the camera on the heating elements, so I might position it off center, in fact just above the connector in the picture below. I will try different positions before finalizing. |
04-03-2024, 11:08 AM | #17 |
Rep 20
Thanks LindrelT for the awesome write-up and photos!
And thanks FlashMonkey929 for the good idea re: keeping card reader in car to be able to view videos. I know PatL mentioned some concern about mounting camera on the rear windshield heating elements - anyone notice any issues with doing this? Thanks again! |
04-10-2024, 09:21 AM | #18 |
Rep 20
Does this camera offer parking surveillance?
I would like to record when the car is parked.
BMW F20 (2015) 116i M-Pack
04-10-2024, 09:44 AM | #19 | |
Rep 71
This cam doesn't have radar/motion detection to turn on recording when necessary when it is parked, so it would record continuously. The downside is the continuous draw on the battery Maybe there is a way to add an auxiliary battery. You should contact the company. |
vded6.00 |
