06-22-2023, 05:36 PM | #1 |
Rep 186
Drives: E90 M3, U11 X1
DIY - How To Change Your U11 X1 Oil
Since I haven't seen a thread for this I figured to make one as I did mine today at right under 4,000 miles. Time to get that break-in oil out and put some fresh lube in. Note that this is for the xDrive28i and won't apply for the rumored 35i.
Tools: - T55 hex bit - 1-1/4" or 32mm socket - 17mm socket Supplies: - 6 quarts BMW LL-17 FE+ or LL-12 FE approved oil, either 0w-20 or 0w-30 - Filter kit - BMW p/n 11428570590 Optional: - Extensions - Wide flat head screwdriver The job: - Easy stuff. About 20 minutes. Always get your engine to operating temperature first. Raise your X1 up by however means. I lifted by the front jacking points and did notice more oil drained versus while parallel. - Open the two covers underneath by swiveling the plastic tabs. You can easily by hand or use the flat head. They'll be a bit stiff the first time so bend a crease to encourage them stay down. - Loosen the oil pan bolt with your 17mm and let drain until mostly done. Next move onto the oil filter. Pull the encased wiring out from the clip, otherwise it will be in the way. Use the T55 next to remove the bottom plug from the filter canister. Once drained remove the canister with your 1-1/4" / 32mm. - The filter pulls right out of the canister. Replace it and the large o-ring on the threads included in the kit. Put a light layer of oil on the o-ring. The filter has a plastic clip, make sure the new one pops into the canister. Pro-tip; before closing either drain, put a splash of new oil in up top to push out remnants. When re-installing the canister it's easier to push it in by hand until seated, then tighten to 25nm. Lightly coat the o-ring on the new canister plug, tighten to 5nm. Don't forget to put that wire back in the clip. Lastly, install the drain bolt with new crush washer. Torque spec currently unknown, but snug it until you feel the washer do it's job. Close up the 2 covers. - Fill with 5 and 1/4 quarts oil. A little under is always better than a little over. This got me right at the full mark according to the level sensor. Always check your level after. - Mildly celebrate saving some money versus the dealer doing it for you. |
9
FlashMonkey9291036.50 beefgroovy18.50 LindrelT70.00 COOLGREANY129.00 donnus20.50 SpaceSilver.X11497.50 Daril12.50 A1eksey22.50 ccs36824.00 |
06-23-2023, 03:53 AM | #3 |
I Shoot People For Money
1037
Rep 1,910
Drives: 2023 Portimao MSport X1
My car with M Sport doesn't have quite enough clearance to get under the car without ramps or jack stands, my belly gets in the way lol. My previous BMW's have always had access covers like that for the drain plugs though.
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold- 2020 430i Estoril Coupe MSport -returned- 2023 X1 Portimao, Msport, Premium 2003 330i Imola Red ZHP 6 Speed |
06-23-2023, 04:00 AM | #4 |
slowest X1 driver ever
491
Rep 969
Drives: '23 X1 M Sport, '24 530i(soon)
haven't really looked under the bonnet after two months with my X1.(xDrive28i) also have not looked underneath the car, but now I envy my next-next-next-next-door neighbor. he had the builder put in a opening under the garage floor(almost exactly like a Jiffy Lube). when he changes the oil on his cars, he just walk down there with no need for rams or jacks.
I know there is no physical dipstick, but where is the oil filler cap? Come to think of it, where is the brake fluid reservoir and coolant expansion tank?(or how does one check the levels or conditions of those two?) Thanks! |
06-23-2023, 04:15 AM | #5 | |
1037
Rep 1,910
06-23-2023, 09:50 AM | #6 |
491
Rep 969
I went and poked... somehow I was unable to locate where the coolant and brake fluid reservoris were. (hard to believe, as I'm a very good poker.... having already taken off and reinstalled every interior panel, including front and rear doors, trunk, space under spare wheel and even removed the front passenger and rear seat... was doing some poking to see what my options were for aftermarket stereo)
06-23-2023, 10:30 AM | #7 |
Rep 17
Brake reservoir
The brake reservoir is on the driver side close to the firewall and is hidden by the large plastic cover.
Haven't found the coolant reservoir yet. |
06-24-2023, 02:04 PM | #8 |
491
Rep 969
12-25-2023, 06:02 PM | #10 | |
Rep 17
12-26-2023, 04:16 PM | #11 | |
world's slowest BMW driver
1498
Rep 1,003
Drives: U11, G60, W211, AZ20
I asked the question 6 months ago. I did eventually find almost everything that I was looking for. However, I'm still looking for the blinker fluid reservoir, but I think it only needs to be checked every 2 years? |
Mini Mize179.50 rocketman99102.50 |
12-28-2023, 03:20 PM | #12 | |
1498
Rep 1,003
12-28-2023, 04:38 PM | #13 | |
1498
Rep 1,003
12-28-2023, 04:59 PM | #14 | |
1498
Rep 1,003
I will no doubt get flamed for saying the following, but it is what I truly believe, so I'm just going to say this once. The American Revolution was a mistake and it should never have happened. If it's not too late, perhaps we can reunite as one nation, federation, or some other form of union.(along with Canada, if possible) |
12-29-2023, 02:46 AM | #15 |
Rep 84
I prefer this method..
1. Acknowledge oil change warning in app 2. Schedule service appointment 3. Let BMW do it.. Well I am in japan and have no real large driveway or garage and it is in the 3 year service package.
2023 X1 Xdrive 20i MSport - April Delivery
2020 MB GLA 200D 2017 X1 Sdrive 18i |
12-29-2023, 01:32 PM | #16 |
1498
Rep 1,003
take them to your local recycling centres?
for example: https://www.nlwa.gov.uk/reducereuser...sed-engine-oil I change my own oil/filter on my other cars.(both uses around 8.5 liters of oil for each oil change, so they do add up pretty quickly) I usually wait until I have several gallons before I take them to the recycling place a couple of miles away. Most of my local auto parts stores also accept used engine oil for recycling, even if I didn't buy the oil from them originally.(because they prefer that I go there and end up buying something else after I'm done dumping the used oil) |
01-03-2024, 06:46 PM | #17 |
Rep 169
I can't believe I have to ask this but I spent 15 minutes looking for the usual top mounted oil filter housing \ cap and couldn't find it..... Even removed the plastic engine cover that snaps onto the engine
Where the hell is the oil filter? Edit RE reading the instructions, I can't Believe they stuck the filter underneath! I've owned several European cars and all had the filter access from the top. WTF? That sucks! Last edited by DestinationMoon!; 01-03-2024 at 06:57 PM.. |
01-03-2024, 06:54 PM | #18 |
1037
Rep 1,910
It’s underneath the car.
01-03-2024, 08:33 PM | #19 | |
1498
Rep 1,003
on the other hand, my BMW dealer only charges $89 for basic oil/filter change, after the three free years of oil changes ends, so I'll probably just let them do it? (unless $89 is not a good price, but I haven't really looked into it) |
01-03-2024, 09:09 PM | #20 |
Rep 169
50 dollars for 89 dollars is a good price at a car dealer :-)
I have 3 years free but it's a 5 hour RT to the dealer..... And the fact that you can't check to see that the job was even done makes me want to do it myself. Trust but verify is my motto nowadays |
01-05-2024, 09:57 PM | #22 |
1498
Rep 1,003
I mentioned this in another thread about oil changes. Perhaps when the time comes, I'll do this on my X1.
--- - - - However, one method that I use on cars without engine oil dipstick is to use a large 4-quart measuring cup. I only use it for engine oil so as to avoid contaminating the new oil. I drained the engine oil, replaced the oil and screwed everything back in. I measured how much oil oil came out. It was 8.12 quarts. I cleaned the measuring cup and measured 8.12 quarts of clean new engine oil. Poured it all into the engine. (note, I also soaked the new oil filter in the new engine oil prior to installing it to account for the old oil in the old oil filter that I just removed) Last edited by SpaceSilver.X1; 01-08-2024 at 12:42 PM.. |
