BMW X1 and X2 forums (U11/U10) General BMW X1 and X2 Discussion (U11 / U10) (2023+) DIY - How To Change Your U11 X1 Oil
      02-06-2024, 09:24 PM   #45
SpaceSilver.X1
world's slowest BMW driver
1498
Drives: U11, G60, W211, AZ20
Originally Posted by metapod View Post
Press start engine button three times
Gauge cluster screen should say diagnostic mode
Press and hold gear button on steering wheel for about 15 seconds (bonus: hold it down for 20 seconds for a secret menu)
Oil change reset option should pop up first, press and hold gear button for 3 seconds. (There's also a few other options you can cycle through)
Now you don't need to speak patois
oh, come one... please tell me what other secret options are in that diagnostics menu! I'm out of town for the next week(and maybe half). In fact, I'm at the airport waiting for my flight to board right now.
Thanks!
      02-08-2024, 04:55 PM   #46
DestinationMoon!
Drives: Bmw X1 U11
Did my first change today at 1300 miles. I will state for the record that I hate, hate that I can't use the mity vac on my late model BMW. And now that they stuck the filter back underneath like it's 1960 makes a bad situation worse.
The ramps work ok, but using them is a little nerve wracking. Oddly, I was able to get up them fairly smoothly, but down was pretty jerky. I've never thought the Transmission on this car was jerky like others report. But backing off smoothly was not on the cards.
The instructions were great and everything went fine. It's just messier and more trouble than our other car
      02-08-2024, 09:48 PM   #47
metapod
Drives: U11 X1 28i xDrive
2023 BMW X1  [0.00]
Is there a recommended oil that you can buy at a normal store? I used to use mobil 1 0w-20 on my F30. Buying expensive oil on the Internet seems not so great.
      02-08-2024, 10:38 PM   #48
DestinationMoon!
Drives: Bmw X1 U11
6 quarts Valvoline Euro, or 5 liters Top TEC 6600 on Amazon are around 50 bucks
metapod30.00
      02-10-2024, 11:33 AM   #49
COOLGREANY
Riding BMWs since 1977
COOLGREANY's Avatar
129
Drives: 24 xDrive28i Space Silver
Mine also just turned 1300 miles so will probably do mine soon. I think I have those same ramps.
Did you access the oil filter cover from the front or side? Was there any clearance to add jack stands in addition to the ramps?
I assume doing an oil change ourselves while under warranty doesn't invalidate the warranty in any way?
2024 X1 xDrive28i (Space Silver), 2014 BMW X1 (E84) (sold), 2010 MINI Cooper S Clubman, 2011 BMW R1200GS Motorcycle and various BMW motorcycles since 1977
      02-10-2024, 11:54 PM   #50
DestinationMoon!
Drives: Bmw X1 U11
Access from the front. The panels are only about 18 inches in. Never really think about stands. Use the parking brake for sure
I guess that's up to your dealer. I keep a record whenever I do a change.
Never had an issue with several cars. If you lease that might be a different story
      04-13-2024, 05:11 PM   #51
COOLGREANY
COOLGREANY's Avatar
129
Finally got around to changing my oil and filter today at 3380 miles. In addition to the steps above, I used large binder clips to keep the access door flaps open to keep them out of the way. One caution, the drain plug washer was still attached to the housing instead of being removed with the drain plug.
I didn't have a 1/2 drive extension for the 32mm socket so had to run to Autozone before I could remove the oil filter housing. Just had a little trouble getting the filter housing threads started before tightening.
I only refilled with the 5 litres (5.28 quarts). More oil came out then I put in so it's probably a little short of full capacity but it's measuring full according to the vehicle info. I'd feel better if we had a dip stick as a backup confirmation to the system reading.
Thanks again for trailblazing this for us.
