05-06-2023, 12:05 AM | #1 |
slowest X1 driver ever
496
Rep 969
Drives: '23 X1 M Sport, '24 530i(soon)
BMW's nav map doesn't have my new 1-year-old house, so how do I set my home address?
I have already tried to find a solution from BMW Genius and salesman and they had no solution yet... but I want to ask here just in case someone knows how to fix this issue.
My new house was built a year ago. The street is brand new and Google and Apple didn't add it until last November. All house numbers on this street are correctly listed on both map services. After I received my X1 last week, the first thing that I wanted to do was to add my address as "Home" in BMW's nav map. Unfortunately, BMW's map only have a 500-foot section of the beginning of my street. If I add my house address 1167 xxxxxxxxx Road as my home address, it uses 1000 xxxxxxxxx Road as my home address. It's about 700 feet away from my actual home location. I thought it would be as easy as parking in my driveway, saving the location as a favorite or marked location, then letting it be my home address in BMW nav map. It doesn't allow that. Any ideas on how to get around that? Also, how to I submit a report to whoever provides BMW the map data so they can update it? Thanks! |
05-06-2023, 12:51 AM | #2 |
Rep 1
Unfortunately, I don't have a short-term solutions for your problem (still waiting for my car to be delivered ).
BMW uses HERE maps as a map provider. 1) Check if your street/address has already been added to HERE maps: https://wego.here.com/ 2) If not, then you can add it with HERE's Map Creator: https://mapcreator.here.com/ It takes a while for HERE to incorporate your changes into the main map. And it takes another while until BMW incorporate the changes into their map. This can even take several years, but by adding the address you make the first step here. While you are at it, make sure that your street and address is also present in OpenStreetMap, as the data of OpenStreetMap is used by many other services as well: https://www.openstreetmap.org/ If it's too complicated for you to add the address, feel free to send me a PM with the address and I'll add it for you. |
SpaceSilverX1496.00 |
05-06-2023, 11:02 AM | #3 | |
Rep 4,472
Drives: '23 X1 28i xDrive
05-06-2023, 11:13 AM | #4 |
Rep 1,817
Yeah we do the same, home is a few streets away from where we live and in the rough area for this very reason.
05-06-2023, 05:05 PM | #5 | |
496
Rep 969
my state used to allow you to use list a PO Box address on car registration and driver's license, but they stopped allowing it about 15 years ago. |
jejupods36.00 |
05-06-2023, 08:57 PM | #6 | |
Rep 4,472
PLUS, the OP's home address literally isn't available to program. So I assume he knows how to get home from a dummy address a mile away.... |
05-06-2023, 09:10 PM | #7 |
496
Rep 969
how does one steal a modern BMW and drive it away in the first place? (except when the key fob is lost or stolen)
05-07-2023, 04:10 AM | #9 | |
Rep 1,817
Those use a key relay by the way. |
05-07-2023, 08:59 AM | #10 | |
Rep 65
05-07-2023, 10:43 AM | #12 | |
Rep 4,472
https://www.nbcwashington.com/news/l...-bmws/3326468/ |
05-07-2023, 07:39 PM | #13 | |
496
Rep 969
