BIMMERPOST Universal Forums Off-Topic Discussions Board Small engine repair advice needed.
      07-16-2016, 11:57 PM   #1
DSB335d
Drives: '11 335d DSB/oyster&black/navi
I have a 16hp v-twin lawnmower. Choke linkage works, throttle linkage works also. Spark plugs are new. Engine will not idle or stay running with air filter/box in place. If I cover the carburetor nearly completely and start it, it will run with the choke closed. I can increase the throttle up and down; again only with the carb nearly completely covered. Also at mid-full throttle the governor moves erratically "hunts".
I pulled the carb off and there was some gunk in the float bowl, I cleaned that out and made sure the throttle and choke butterfly's were clean and moved freely.
It seems like I'm not getting enough fuel. With nearly no air entering the carb it will stay running, as soon as you unblock the carb or slightly open the choke (even with the carb blocked) the engine dies.
My guess at this point is that the main mixture "jet" may have a blockage, therefore not delivering enough fuel.
Anyway thanks for your time/advice.
      07-17-2016, 12:02 AM   #2
ASBSECU E93
Know's a guy that know's a guy...
ASBSECU E93's Avatar
5645
Drives: 2010 335d; 2008 135i
Buy a bottle of fuel additive, add a couple ounces to a tank.
Originally Posted by Lups View Post
She stood there. Pointed a finger at me and laughed at me. That damn bitch.
Poop shit, shit and poop. I'm mildly angry now.
      07-17-2016, 12:26 AM   #3
Umi|all|day
Umi|all|day's Avatar
74
Drives: 2010 SS M3 E92
Replace the rod bearings
      07-17-2016, 01:14 AM   #4
shoei
Drives: MW Vespa w/pink racing stripes
Are you sure it's not the dreaded HPFP failure?
(Oh gawd, I remember when 65% of the forum was dedicated to that in 2007-2008)
      07-17-2016, 02:21 AM   #5
ASBSECU E93
5645
That's because you're old....GRANDPA!!
      07-17-2016, 02:22 AM   #6
shoei
How are you calling me or anyone grandpa??!!
      07-17-2016, 08:59 AM   #7
RickFLM4
RickFLM4's Avatar
Drives: M4
If you can't get it working properly try Southern Lawn Equipment near the fairgrounds. They seem to do a good job when my generator needs work.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
      07-17-2016, 09:44 AM   #8
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
Sounds like it could be an air/fuel ratio issue, and therefore a carburetor issue. It could be that air is being introduced through a bad seal, o-ring or gasket... Or you are flooding or starving gas due to needles being shot, o-rings messed up or gumming up elsewhere. Since you already took apart the float sand noted gunk, I assume it's not that new, but you are comfortable doing things like that.
Carburators are finicky and if you prefer to take care of it yourself, I would just suggest getting a carburetor rebuild kit from the manufacturer. Otherwise, most small engine repair places do pick-up and drop-off service.
      07-17-2016, 09:57 AM   #9
jtodd_fl
2nd Asst to Dept Undersecretary
jtodd_fl's Avatar
6707
Drives: People crazy
2015 F82 M4  [9.00]
2016 F87 M2  [0.00]
2011 E92 M3  [0.00]
Did you leave gas in it for a bit without the anti-gunk stuff. Those who don't live in FL don't realize how quickly the ethanol can congeal down here. I use ethanol free gas for my equipment.
I had to do a rebuild on one of mine, but it was a much smaller engine (a pressure sprayer).
This space for rent.
      07-17-2016, 10:13 PM   #10
P1
P1's Avatar
11727
Drives: 2004 3/4 ton Duramax
My Echo was doing the same thing, and I took it in to get it fixed. It was literally less than $20. Not worth even doing it yourself, unless you simply want to tinker around with it.
      07-17-2016, 10:26 PM   #11
Mr Tonka
is probably out riding.
Mr Tonka's Avatar
Drives: Something Italian
If you're going to use a small engine, make it a 12 cylinder.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
http://www.m3post.com/forums/signaturepics/sigpic59612_1.gif
      07-18-2016, 01:50 AM   #12
jtodd_fl
jtodd_fl's Avatar
6707
2015 F82 M4  [9.00]
2016 F87 M2  [0.00]
2011 E92 M3  [0.00]
That's sweet. Yours? What is it from? I don't think I've ever seen a car model with a "functional" engine.
      07-18-2016, 09:32 AM   #13
Maestro
Drives: 2007 335i Sedan, 2021 X3
I seen this problem, the issue is the gas, most small engines carbs are not design to deal with the ethanol and the other crap they put in the gas today. You need to treat the gas before you put it into your small engines. With that said, doing a complete rebuild and then tuning the carb most likely will solve the problem. I personally been able to find a new carb online for under $20 since most all the US companies who make and sell small engines today have their carbs made in China.
Today I am treating my gas for all my small engines and recently have been replacing the carbs due poor running issues that have developed over the years.
      07-18-2016, 09:35 AM   #14
Maestro
http://theawesomer.com/worlds-smalle...engine/136285/
      07-18-2016, 10:03 AM   #15
ASBSECU E93
5645
OP - when using injector cleaner, it is CRITICAL to remember to only use a small amount or you will damage the internals. Most of the additives are meant for 15+ gallon tanks of fuel, so make sure you are prepared to run a full tank of fuel completely out with the additive if you go this route.
I don't think it's a fuel/air issue. I had a similar issue with a Commercial pressure washer that had sit for about 2 years, the additive solution worked fine.
      07-18-2016, 10:11 AM   #16
RJ_
Baby-faced Assassin
RJ_'s Avatar
Drives: when car isn't broke.
The extent of my small engine repair knowledge involves disassembling the intake tract as far as reasonable, followed by generous application of carb cleaner in every orifice until it runs clear, then reassemble.
Little stuff like fuel filters, fuel lines, and o-rings can all be replaced with the spare change you have in your cupholder.
Maybe you have a weak spark that's getting blown out? These usually have very simple ignitions, so maybe freshen up the electrical contacts too.
      07-18-2016, 10:19 AM   #17
ASBSECU E93
5645
Not a lot of science with these engines either. Trial and error has taught me, start with easiest or least expensive/invasive fix first, then work through more difficult/expensive repairs via process of elimination.
      07-18-2016, 01:01 PM   #18
Mr Tonka
Mr Tonka's Avatar
I use it to power my ePenor.
      07-18-2016, 01:04 PM   #19
jtodd_fl
jtodd_fl's Avatar
6707
2015 F82 M4  [9.00]
2016 F87 M2  [0.00]
2011 E92 M3  [0.00]
And just a V12 works? I woulda thought you'd need that Caddy's 16 cylinder, yo.
      07-18-2016, 01:11 PM   #20
Mr Tonka
Mr Tonka's Avatar
What, do you think i'm Biorin or something?
      07-18-2016, 02:22 PM   #21
John 070
Drives: 335i cpe
a 16 HP lawnmower....why not hire peasants to not only fix it, but mow the lawn as well? My dad had a 17 HP Kubota, and put it this way, it was bigger than a 328i. We let the peasants deal with it...
      07-18-2016, 05:23 PM   #22
ASBSECU E93
5645
^John - HUGE difference in a 16 hp lawn tractor, and a 17 hp Kubota (Diesel) tractor....just saying
