07-04-2014, 02:05 PM | #1 |
Rep 341
Satellite FSC coding
Hi guys.
I usually try not to open threads but I have hit a dead end on this one and searching has not produce a lot of results. So I've got my 6F FSC code to activate my SAT radio on my 2014 335i Navi only but it seems the SAT option does not show up under radio after I upgraded the FSC in my car. Here is my log after I upgraded the FSC. I have not used the B64Dec to decode FSC file since ESYS read it fine and I didnt get any errors. --> Read the state from "3" ECU(s) <-- DME2[DiagAddress=18(0x12)] VIN# RootCertStatus not available SigSCertStatus not available SWSigStatus accepted SWTApplications ---------- AppID 228(0xE4) UpgradeIndex 1(0x01) SWTType SWTclassic light FSCStatus not available FSCCertStatus not available ---------- AppID 157(0x9D) UpgradeIndex 1(0x01) SWTType SWTclassic light FSCStatus not available FSCCertStatus not available EPS[DiagAddress=48(0x30)] VIN# RootCertStatus not available SigSCertStatus not available SWSigStatus accepted SWTApplications ---------- AppID 131(0x83) UpgradeIndex 1(0x01) SWTType SWTclassic light FSCStatus accepted FSCCertStatus not available HU_NBT[DiagAddress=99(0x63)] VIN# RootCertStatus accepted SigSCertStatus accepted SWSigStatus accepted SWTApplications ---------- AppID 158(0x9E) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 160(0xA0) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 222(0xDE) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 111(0x6F) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted---------- AppID 159(0x9F) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 156(0x9C) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 229(0xE5) UpgradeIndex 1(0x01) SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 168(0xA8) UpgradeIndex 5(0x05) SWTType SWTshort FSCStatus accepted FSCCertStatus not available I followed these instructions which pretty straigh forward. Well, that is the basic idea, but only the tip of the iceberg. When you got your SAT Radio FSC Code, you should have received 3 files: e.g. xxxxxxx_006F0001.xml e.g. xxxxxxx_006F0001.der (FSC Code Certificate) e.g. xxxxxxx_006F0001.fsc (FSC Code) E-Sys => Options => Settings => FSC Tab => Certificate Field: Load FSC Code Certificate (e.g. xxxxxxx_006F0001.der) E-Sys => Comfort Mode => FSC => FSC Field: Load FSC Code (e.g. xxxxxxx_006F0001.fsc. The FSC Code file must first be Base 64 Decoded or else E-Sys can not read it. (Use B64Dec for Decoding - http://4mhz.de/b64dec.html). FA Field: Select "Read FA" to use cars current VO. Parameter Fields: (Example for Sat Radio FSC Code and CIC): Diagnostic Address (hex) = 63 (99 in Decimal for HU_CIC; I think the same for HU_NBT) Application Number (dec) = 111 (6F in Hexidecimal - In FSC File Name, e.g xxxxxxx_006F0001.fsc) Base Variant = HU_CIC (CIC module name, e.g. HU_CIC, HU_NBT, etc.) Upgrade Index = 1 (In FSC File Name, e.g xxxxxxx_006F0001.fsc)) Select "Upgrade FSC" to Import and Activate FSC Code. Select "Check FSC Status", and you should see: ---------- AppID 111 UpgradeIndex 1 SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- Based on reading of my FSC it clearly shows that 6F is accepted. I have done this last night and I was hoping that by today it would show up. Rebooting the NAVI didn't help. Anyways any help would be appreciate it. |
07-04-2014, 07:57 PM | #2 |
Rep 41,181
Drives: 2018 Alpina B6 650ix GC
Importing and Activating the 6F FSC Code is only one step. You still need to Code the car properly.
You need to modify FA and replace 693 PREPARATION SATELLITE TUNER with 655 SATELLITE TUNER, and then VO Vode Head Unit.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
07-04-2014, 11:02 PM | #3 |
Rep 341
Ahh, thank you Shawn. After your post i found the instructions on how to code FA. This is why i didn't want to post for such a simple thing.
07-04-2014, 11:06 PM | #4 |
Rep 41,181
No problem.
09-24-2017, 06:20 AM | #5 |
Rep 1
Do you also have satellite tuner fsc code?
09-24-2017, 08:26 AM | #6 |
Rep 41,181
PM sent. This is for North America Sat Radio (SiriusXM). Not for anything in Turkey.
04-23-2020, 11:18 PM | #8 |
Rep 41,181
You don't. It must be issued by BMW AG, except in case of NBT or NBT2 where all FSC OEM FSC Codes have been replaced with Aftermarket set of FSC Codes. PM sent.
