07-06-2014, 03:17 PM | #1 |
Rep 333
Tire pressure
The dealership or VPC, not sure which one, set my tire pressure at 28/35. However, I see the recommended tire pressure on the side of the door says 32/38.
The front tires look a little under inflated when I asked my GF to test drive it. Is it because it's summer the pressure should be lowered to compensate for the high temp? or should I stick to the factory recommendation and add some air? |
07-06-2014, 03:37 PM | #2 |
Rep 602
This may sound slightly cynical, but the tire pressure may not have even been adjusted after arriving. Mine was low as well. I set it at the recco'd and its been great. They can loose a pound or so after some weeks--depending on the wheel config--so set it correctly, drive it, and then re-check once a month. Lower inflation is hard on tire wear.
07-07-2014, 09:29 AM | #3 |
Rep 584
tire pressure depends on weather and cold and hot tire.
CurrentNone! RETIRED [15' GLA250][14' M235i F22 AW-ED 06/16/14][12' 335i F30 AW-ED 05/01/11 PCD 07/01/11] [11' M3 E93 MW-ED 08/13/09 PCD 10/14/09] [09' 135i E82 AW] [07' 335i E90 SB]
[ED Photo 12'] [ED Photo 11'] [ED Photo 09'] [PCD Photo 09'] |
07-07-2014, 09:31 AM | #4 | |
Rep 8,942
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
07-07-2014, 12:02 PM | #5 |
Rep 333
so the recommended pressure settings are for warm tires?
edit: According to TireRack, the tire pressure recommended in your vehicle's owner's manual or tire information placard is the vehicle's recommended cold tire inflation pressure. Last edited by lichenlt; 07-07-2014 at 12:07 PM.. |
07-07-2014, 12:05 PM | #6 |
What goes here?
454
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
The pressures on the door jamb are for when the tires are cold.
When I picked up the car I had one of the front tires reading 53 psi (!!), 2 reading 43psi and 1 reading 38psi when hot.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
07-07-2014, 12:18 PM | #9 | |
Rep 8,942
2022 Macan S
07-11-2014, 11:04 PM | #12 |
Rep 84
07-11-2014, 11:33 PM | #13 |
Rep 757
07-12-2014, 08:08 AM | #15 |
Rep 809
Drives: 2014 228i Msport
I use a mixture of 78% nitrogen, 20% oxygen and some other trace gases. Has been working real well for me for over 45 years
http://www.edmunds.com/car-care/shou...-nitrogen.html
A peasant and proud of it
Save The Manuals!!! |
07-12-2014, 08:17 AM | #16 |
Rep 5,579
Do the cars come from the factory nitrogen filled?
Do you think gas station or garage air-compressors contain too much moisture? Does that moisture corrode tire pressure transmitters or interior wheel metal, I think TireRack said even tire wound steel belts can corrode frm moisture. |
07-12-2014, 09:22 AM | #17 |
Rep 5,262
I think they came with just air.... the advantage is that N2 has bigger molecules so it's harder for them to escape or leak....
imagine like filling it with golf balls against tennis balls... difference is just about 0.3 times so not really huge.... |
07-12-2014, 10:35 AM | #18 | |
Rep 757
07-12-2014, 10:36 AM | #19 |
Rep 757
Yup. Doesn't leak as fast which sounds nice to me.
07-12-2014, 10:38 AM | #20 | |
Rep 757
07-12-2014, 07:34 PM | #21 |
Rep 4,128
Drives: M235i & G30 540i
Nitrogen in tires are a waste of money. The difference is so small that it does not warrant the cost or the inconvenience of refilling.
Yeah yeah yeah it's supposed to keep the air pressure more stable than air. There have been multiple tests out there to prove both sides so not worth it in my opinion.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
