I Gave V2 what it needed and WOW
12-13-2007, 08:26 AM | #1 |
Rep 321
I know every countries Dyno's read differently and correct values differently but the main thing when measuring power is measuring on the same dyno and with the same conditions.
I have attached my first Dyno's that i took with V1.47 95 RON fuel no air filter, we measure in KW and NM. 290kw and 570NM. The KW Graph shows run 1 my old run with 1.47 and run 2 is V2.Today i did another dyno run and gave the V2 exactly what it needed more air "K&N Air filter" and more octane, only 102 RON fuel in tank. Max power up to 309 KW an Torque flew threw the roof at 670NM at 96% settings. These numbers are corrected for sea level. I asked the guys not to correct but they said that they couldnt change the dyno setting as they had other cars ready to be tested. All i have to say is wow the car neeeeeeded the air filter at this high altitude and its loving the high octane!!!!! To SHIV " My appologies for driving you mad over having a slow car" |
12-13-2007, 08:45 AM | #2 | |
Rep 4,481
- Eugen |
12-13-2007, 08:57 AM | #3 | |
Rep 321
wil confirm tomorrow but i doubt they are @ the wheels far to high numbers. But at the very least i know there was an increase. With 1.47 that was the only mod now i have K&N air filter and running 102 RON octane. |
12-13-2007, 09:15 AM | #4 |
PMOTH
Rep 38
Subtract 12% and his dyno will be inline with everything else we've been seeing for the last few weeks. I do wish his numbers were uncorrected though. That dyno is most likely overcorrecting his power and torque.
12-13-2007, 10:08 AM | #5 | |
Rep 321
Im going past there tomorrow ill ask if they can print me uncorrected numbers i also would like to compare to everyone else on the forum and by them correcting them you cant compare apples with peaches. But at least when i compare it to my last dyno there was a drastic increase and to me thats what matters... |
12-13-2007, 10:12 AM | #6 | |
Rep 4,481
- Eugen |
12-13-2007, 10:16 AM | #7 |
Several N54 cars, V1,3, V2.0.2, and V3.1
12
Rep 778
Looks that you were right. V1.47 had more power low down (at 2000rmp) even without the K&N and race gas. It would be interesting to see if you are able to get the same low down figures with V2 without the K&N and race fuel but by having the 100% settings instead. Or did you say before that 100% was not any better than 96%?
(P.S. The figures as such are seriously inflated as they should not be corrected, but it does not matter since we are interested in the difference) |
12-13-2007, 10:49 AM | #8 | |
Rep 321
Being at this high altitude 96% or 100% setting made no difference on my boost as the turbos where overspinning. |
12-13-2007, 11:19 AM | #9 |
The Tarmac Terrorist
958
Rep 29,345
Drives: 997.2 GT3
they WHP or crank?
997.2 GT3
12-13-2007, 02:35 PM | #10 |
Rep 948
No way it was at the wheels. 495 wheel ft. lbs of torque? Nah.
Previous notables:
'05 S2000 | '07 335i | '09 ISF | '08 911 Turbo | '09 911 C2 | '15 Cayman | '15 RCF | '17 MX-5 RF | '17 C7 Corvette |
