Turbo Cooldown - How long should you wait to turn off the car?
12-13-2007, 11:02 AM | #1 |
Rep 964
Hey folks,
This is my first boosted car, but seeing that I can't find anyone locally to install a remote starter w/ a turbo timer to shut off the car, how long should you realistically wait to cool down the turbo's to shut off the car safely? If I turn off the car immediately, I keep hearing these ticking sounds like metal is starting to compress very fast and going brittle and what not.... don't know how else to explain it. Thanks.
12-13-2007, 11:04 AM | #2 |
560
Rep 6,169
It was a built in electric pump to cool down the turbos...so u don't need a turbo timer...the sound ur hearing is normal cool down procedure
MKIV 6spd 1000hp Club |
12-13-2007, 11:07 AM | #3 |
BMW TECH
9
Rep 104
Drives: 2008 328I SEDAN - 2008 BMW 750
That loud ticking your hearing is more likely comming from your exhaust system as it cools it will make that noise - it should go away after a while - it did the same thing on my car.
There is no turbo cool down needed - car has a electric water pump that will run when car is off (as stated above) there is no cool down needed.
Current Vehicles - 2007 335i Sedan & 2005 X5 3.0
Past Vehicles - 2002 525I, 2003 325 Loaded, 2006 330I CURRENT MODS: PROCEDE V.2 - DYNOTUNE DIGITAL BOOST GUAGE - K&N AIR FILTER- INTERMEDIATE CAT DELETE - LOGIC HVI - |
