Serpentine belt shredded
07-25-2014, 09:58 AM | #1 |
Rep 61
Hey guys, yesterday as I was driving to work my serpentine shredded into pieces. It happened as I shifted from 2nd to 3rd at around 4k. I drove the car back slowly for 5 miles. I have the car up on the lift now and don't see any leaks or damage to any of the pulleys. 2 weeks ago i had a pretty bad oil leak from the oil filter housing which i fixed. I don't know if the belt being wet by the oil had anything to do with it shredding? When taking off the shredded belt there was a piece of the belt hanging loosely behind the crank pulley which I pulled off. I don't believe anything went into the crank but i want to be sure before putting the new belt on. Is there any way I could tell if parts of the belt went inside the crank or would I have felt or heard something when driving it back? Would I have to take the crank pulley out to check? I would appreciate any comments or advice. thanks
07-25-2014, 10:11 AM | #2 |
Rep 228
Drives: 2013 E92 Melbourne M3
I don't know much about cars but it does seem likely that the oil ruined your belt. Oil and rubber do not get along well at all (assuming the belt had rubber in it, because I don't know)
07-25-2014, 10:39 AM | #3 |
Rep 574
Common problem and you're lucky the engine wasn't hungry for serpentine belt today.
On a related note, anybody have an opinion on the ECS Tuning belt/pulley kit vs OEM? |
07-25-2014, 10:40 AM | #4 |
Rep 1,518
I would still remove the crank pulley and take a look and see if any belt has made its way inside the pan. Mine was a bit worst and ended up requiring a new short block
mweisdorfer1908.50 |
07-25-2014, 11:22 AM | #5 |
Rep 259
Just used that kit a few weeks ago and everything seemed to be of good quality. I have no complaints plus it saved me $100.
2007 335xi 6AT | Cobb Stage1+ | BMS DCI | VRSF 7" IC | FA 500 400#F/600#R | ARC8 17x9 et30 | RE-11a 255/40/17
Parting out car. For sale thread here: http://www.e90post.com/forums/showthread.php?t=1167583 |
07-25-2014, 12:37 PM | #6 |
Rep 3,961
DO NOT DO THIS or you have to retime the motor!
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
07-25-2014, 01:19 PM | #7 | |
Rep 753
07-25-2014, 02:13 PM | #8 |
Rep 165
First I would check and make sure all the pulleys are tight. Same thing happened to me and I went through 3 serpentine belts. It turned out the power steering pulley bolts were super loose. I used loctite on all bolts, replaced tensioner and belt. Its all been good so far.
2015 F80 M3 DCT : JB4 : Gintani DP : METH : BMS INTAKES : Upgraded Turbos : GTS DCT Flash
11' Z4 35i Procede REV 3 SOLD 2007 e90 335i 6MT:Procede REV 3: Raceland 2.5": VRSF 7":VRSF CHARGE pipe: Walbaro 255 inline: ACT 6 Puck: 100% e85 Garage: 2015 M3 : 2007 M5 : 2016 X1 : 2003 X5 |
07-25-2014, 02:50 PM | #9 |
Rep 1,909
Plenty of info on this thread - its a known issue till Nov 2007 MY or something (sorry dont recall the exact month) - Whats your MY
In a nutshell, the power steering pulley hits the subframe and belt shreds, check for metal loss or scuffs around the PS pulley area ... You're v lucky if it didnt get into crankcase, my neighbor's got in twice (luckily he had CPO warranty, got new head, it bent valves coz the timing chain jumped - he said timing chain is right behind the crank pulley and makes a V with the inlet and Exhaust camshafts uptop) |
07-25-2014, 02:56 PM | #10 |
Rep 3,961
It happens on newer years also and does not involve the subframe issue most of the time. The tensioner fails or the idle pully is worn. I have also seen the tensioner bolts stretch making it run on an angle. I have also seen an N55 motor with the belt wrapped around the crank.
07-31-2014, 03:27 PM | #11 |
Rep 398
Drives: 15 Porsche 911 GT3
Just had this exact same thing happen to me yesterday! I'm also hoping that the crank gasket didn't allow the shredded pieces to puncture it.
I just replaced my OFH gaskets as well and I still have a leak somewhere up on that side of the engine. Got 82K on my car and i'm hoping it was just age + oil and the belt prematurely wearing out the belt that made it shred and that i'm not heading for another shredded belt again soon.
2021 Marina Bay Blue X5M Comp
2015 Porsche 911 GT3 *SOLD* 2017 Yas Marina Blue M3 *SOLD* 2009 E92 335i M-Sport - Space Grey Metallic *SOLD* 2011 Lexus IS-F |
10-05-2014, 07:13 PM | #13 |
Rep 278
Please can somebody quickly share with me a diagram with how the serpentine belt is run on the N55? I am searching but not seeing any for the N55. Thanks
10-08-2014, 12:29 PM | #14 |
Rep 278
(JB4 stage 2, in my garage)Now CoBB V3 , VRSF 3.5" Stainless Steal catless DP, 7" VRSF FMIC with upgraded lower CP.
10-08-2014, 01:35 PM | #15 |
Rep 28
For those of you who are wondering about the ECS pulley/belt kit, don't worry about the quality or fitment. I bought recently bought the non-BMW kit fand installed it this weekend, no issues! Small differences were the Continental stamping on the belt and one of the internal bearings had an abbreviated part number (from the BMW part number). I guess it makes sense, BMW acts as the prime on the whole product but outsources most of the sub assemblies to companies that make components for a living (i.e. Continental, etc.)
Silver 2007 335xi
10-08-2014, 01:52 PM | #16 | |
Rep 278
10-08-2014, 03:52 PM | #17 |
Rep 753
The ecs kit I found it cheaper ordering it St fcp euro. Same parts same brand even the continental belt. Th quality was great. I have been running it for about 3 months now. No issues.
10-08-2014, 04:21 PM | #18 |
Rep 28
Totalelectronics ;
I know my tensioner had two pulleys. I also couldn't find a good drawing until I searched on the N54 Tech site. Take a look here and page all the way down:http://www.n54tech.com/forums/showthread.php?t=11957 Dave
Silver 2007 335xi
10-08-2014, 06:07 PM | #19 | |
Rep 278
Need help URGENt Oil Pressure Control Valve
But now it seems my troubles are not over. When the belt broke it hit the Oil Pressure Control Valve and broke the electrical connect clean off. I tried wiring it back but it seems its still malfunctioning as the car keeps over heating after just 10 mins of throttling. See item 1 in the diagram. If anyone happen to have one selling could you PM me please? Thanks
05-13-2019, 06:49 AM | #20 |
Rep 1,272
05-14-2019, 08:38 AM | #21 | |
Rep 6,968
Drives: 2007 Black/Black 335i e90
I don't think he meant the crank bolt, which yes would require you to set the timing, but it's s major b@tch to get off to begin with. |
OTO335i146.50 |
05-14-2019, 08:41 AM | #22 | |
Rep 6,968
Also, how old is your current belt & pulleys? Next, how old are your current engine mounts? |
