NEED HELP WITH 18 psi max on cobb. Stage 1 agressive
07-29-2014, 12:32 AM | #1 |
Rep 615
Hi guys I am curious and I know a log is the answer so if I had one I would post but I don't. Certain times I'll do a wot and the cobb will say max boost 18.1 or 16 plus...., I'm running cobb stage 1 agressive. I feel terrible but I want to know if the spike is a boost leak or a potential issue. Perhaps without the log you can't say but what are some of the issues.
07-29-2014, 03:54 AM | #3 |
Rep 615
3rd gear pull is a lose your license speed and they are on summer hunt right now downtown Victoria etc.... I haven't had time to get to the out skirts to get some rd way.... I just noticed the odd over boost max lately when flooring 1-2 into 3.... It's crazy how fast and what stretch of clear rd you need to do a 3rd gear pull from 2-2500rpm...
07-29-2014, 07:03 AM | #5 | |
Rep 80
A 3rd gear pull to 90ish is very quick and easy. Hit an on-ramp and let 'er rip. I have the Stage 1 Aggressive map loaded and I spike anywhere from 15-15.5 and settle at 14.5. The logs would definitely tell your story. Be safe. |
07-29-2014, 07:45 AM | #6 |
Rep 615
Figured I needed logs lol... I'll try.. Not sure about the states but anything over 40km is called excessive speeding in bc Canada the limit is 80km 3rd gear is around 140km plus I think... Lol . I know crazy but they have gone big time stupid in canada on speeding you get caught twice your licence goes by by for a year.
http://www.pssg.gov.bc.ca/osmv/road-safety/speed.htm |
07-29-2014, 10:30 AM | #8 |
Rep 1,084
Logging a proper 3rd gear pull only takes a few seconds.
If you are worried go out extremely late when the tollway is dead. I used to do all my logging at like 4 AM on Sunday morning. |
07-29-2014, 04:42 PM | #9 |
I'd hit it
1066
Rep 1,107
I thought everyone did that in Mexico? It's not that far... about a 20 min drive from Massachusetts.
07-29-2014, 05:21 PM | #11 |
Rep 1,652
Drives: '10 AW/CR e92 6mt 335i
Well since it's on the same topic. Is there suppose to be a hard max? Im on 2+ FMIC Sport and you can see I hit 16-17psi for a split second on two diff logs:
http://datazap.me/u/e92enthusiast1/c...data=3-4-16-17 http://datazap.me/u/e92enthusiast1/c...0&data=3-16-17 Should i have concerns like OP?
COBB AP Stg 2+ FMIC Aggressive | VRSF 3" Catless DP | COBB FMIC | BMS DCI | CP-e Metal Charge Pipe | 370+ whp/435+ lb.ft torque
07-29-2014, 06:06 PM | #12 | |
38
Rep 634
The TMAP sensor(where the DME pulls boost from) is located before the throttle plate and whenever there is some throttle trimming going on it will create an artificially high boost reading. Your boost spike readings are occurring during these events. All in all your logs look good. |
07-29-2014, 06:50 PM | #13 |
Rep 615
I'll pull a log I know .... Hit 20.2 psi max today so I put it to sport map instead of aggressive. I need a FMIC bad .. Temps are around 154 peak and 120 just resting... Car feels slow.. Anyhow thanks guys I will post a log a soon as I can
07-29-2014, 10:42 PM | #15 |
Rep 175
Drives: 2011 335i 6MT
Listen to allen. Throttle closures will cause these spikes, your engine never actually sees this much boost.
This question has been asked like a million times people, do you not read about how your car works before modifying it?
Daily: 2012 CTS-V Sedan 6MT
Fun: 2014 Porsche 911 PDK More Fun: 2001 AP1 Honda S2000 White on red Family/Offroad: 2020 Lexus LX 570 w/ 34" tires Sold: 2011 335i 6MT, 2007 WRX Limited - STI swap, TD06-20GXT, E85 |
07-30-2014, 05:59 AM | #18 |
Rep 2,387
Definitely throttle closures as others have said.
But wanted to point out you do not need to do WOT runs to redline or lose your license to log data and see this happening. Good exercise regardless just to get familiar with software plus you'll see the boost spikes. Just drive around normally and see what you get. |
07-30-2014, 11:21 AM | #19 |
3442
Rep 79,211
It's probably a boost spike from throttle closure.
Boost is measured pre throttle body so any throttle closure will induce an inflated boost pressure reading but your engine is not actually seeing those boost pressure. If one wants to see the actual boost the engine is seeing you need a reading from inside the intake manifold and / or the throttle must be open 100%. |
07-30-2014, 12:10 PM | #20 |
Rep 615
Cheers guys makes sense ... I'm heading up island tomorrow where I can do a bunch of logs near cowichan river ..... I'll have sport map logs and aggressive .... That way we can see how things look.
07-30-2014, 12:13 PM | #21 |
Rep 615
Something is wrong as sport is way faster feeling than agressive.. I have 94oct fuel in Victoria bc with no ethonal but I hear USA gas is much better in regards to octane... Perhaps agressive is to much after a bit of heat soak for my fuel here... Car feels like it is retarding itself which in past logs I posted I think some of you had mentioned... Do octane boosters work????
07-30-2014, 12:35 PM | #22 | |
Rep 2,875
Sometimes more isn't always better....
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
