Is my car using a lot of oil?
07-30-2014, 12:52 PM | #1 |
Rep 1,100
Last night my car gave the "low oil" warning light on my dash.
The last time i topped off a quart was Feb 26 when it also gave the "low oil" warning. Is that normal to top off the oil in 5 months period? I am by no means an aggressive driver but I will go WOT on several occasions for fun. My car has 46xxx miles on the clock.
2010 335i Coupe- Monaco Blue Metallic
07-30-2014, 03:42 PM | #5 |
Rep 1,093
unless you buy budget brand that is excessive. 5-6K for high quality oil is plenty.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
07-30-2014, 07:10 PM | #6 |
Rep 719
+1
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
07-30-2014, 10:27 PM | #8 |
Rep 578
Drives: 2009 335i xDrive coupe
I never burn through oil. Never get a low oil light. I change my oil every 6,000 miles. Mobil One Full Synthetic European blend and BMW oil filters.
Mtech/M3Skirts/335isDiffusor/BBSrgr/PSS/OFT/Alpina/LCItails/LuceAngelEyes/OsramXenarc/ZKWRlenses/
FlowmasterHFC/vibrant/VRSFdp’s/Helix/Mr5CAI/M3rearBushings/M3StrutBrace/RearSway/UUCfrontSway/Meyle/ KoniTCKlineAdjFront&Rear/EibachPro/ECSbrakeLines/ECS2pieceRotors/Akebono |
07-30-2014, 10:45 PM | #9 |
Rep 722
That is not alot of oil for that amount of time and it is very common for our cars to burn a little oil between changes. Just monitor your oil levels and if it appears to be burning more than usual it is likely you may have a leak somewhere.
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
07-31-2014, 10:00 AM | #10 |
3442
Rep 79,211
How many miles before you had to add oil? 1 Quart every 1000 miles would be a lot of oil, as an example.
Changing oil every 3000 miles on synthetic oil is throwing money away. Non synthetic oil can go 4000-5000 miles easily. If you are unsure get an oil analysis, you'd be surprised how many people change their oil too often sometimes with the 3000 miles rule. Synthetics have no problem going 7,500 miles at a minimum to 12,000 miles. Most of the time the 12,000 mile rule is a bit much because you likely end up burning some oil by then. I found 7500 miles to be happy medium for all synthetics but the oil itself could actually go a lot longer. I personally dont even put 10,000 miles a year on my car so I just end up changing it once a year. |
07-31-2014, 10:53 AM | #12 |
Rep 744
I burn at least a quart in 5k. Sometimes 2. I target about 5k oci, but will only add 1 quart max per interval so if I get to the point of needing to add a 2nd quart I go ahead and do the oil and filter change. My car has consumed oil like this since day 1... I do drive it like I style it everyday though.
07-31-2014, 08:04 PM | #14 |
Rep 1,093
That damn oil gasket. Gets you every time....
07-31-2014, 09:04 PM | #15 |
Rep 744
Not sure if you're talking at me. My oil filter housing gasket was leaking a little bit a while back, but I changed both gaskets and cleaned up all the oil residue. Engine bay and undercarriage are clean. Like I said, been consuming about this much oil since the car had 6 miles on at. I was concerned at first and took it to dealer several times asking them to investigate. They never found anything and I eventually decided I don't care. Never any drops (undertray removed years ago) not much ever in catch can, occasional puff of smoke out the catless exhaust but not much... it is what it is...
07-31-2014, 09:19 PM | #16 |
Rep 272
Drives: 2008 128i
Literally laughed out loud.
Afe Scoops and CAI, PBX, BMS Paddleshift upgrade, 261M's Powder Coated Gunmetal, 225/255 Michelin PSS, (BMW Performance: BBK, Illuminated Door Sills, Shifter Knob and Boot, E-Brake Handle, Steering Wheel, Front Strut Bar), E93 FSB, E92 RSB, M3 Rear Subframe Bushings, M3 Front Control Arms, HPA coilover kit (Koni Adjustables and Swift Springs), Steel Brake Hoses, Black Kidneys, Smoked LED side markers, Blacklines, Msport lip spoiler...
08-01-2014, 04:37 PM | #18 | |
Rep 150
08-01-2014, 05:20 PM | #19 |
Rep 1,044
as a reference I would go thru a quart about every 4-5k when I have a vcg and ofhg leak. after the dealer fixed both I went 10k until I got my oil changed and the oil gauge went from max to half way, so my car doesn't use much oil between changes now.
08-02-2014, 12:20 PM | #21 | |
Rep 1,100
Based on what other people are saying it looks like my oil consumption is pretty standard. Adding a quarter every 5000+ miles. THanks guys!
