Oil Filter Removal Tool
08-01-2014, 07:17 AM | #1 |
Rep 3,201
Drives: E92 325i MSport Coupe
Hi chaps. Wanting to buy an oil filter removal tool like this:
I bought one online (16 flats 86mm wide) which appeared from my research to be the correct size for my engine (N53 6-cylinder). However when it arrived, it was just too small to fit over the filter housing cap. I now find there are tools on the web of 86mm, 87mm and 88mm and I don't know which I need. Based on measurement of the distance between flats, 86mm should be right...but it clearly isn't. So do any of you have one of these wrenches already? If so, could you tell me the width between flats pls? Cheers.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
08-01-2014, 07:45 AM | #2 |
Rep 8,115
Doesn't the filter cap have a 32mm hex-head on it?
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
08-01-2014, 08:00 AM | #3 |
Rep 3,201
Nope. Completely smooth, like this:
08-01-2014, 08:36 AM | #4 |
Rep 290
Same size as for n54? Can't find my bloody tape measure I think it's around 88mm. I purchased the proper bmw tool for it less than 10 quid and worth having the 100% correct size. It has 16 flats but until I can find a measure sorry that's all I can tell u.
Bmw part no 83 30 0 493 936 if it helps you find out more info Last edited by kev335i; 08-01-2014 at 08:41 AM.. |
08-01-2014, 08:41 AM | #6 |
Rep 3,201
Sourced from a BMW dealer at that price?
08-01-2014, 08:47 AM | #7 |
Rep 290
Yep bmw Cooper can't recall if they had to order it or not and yes surprised me how cheap it was.
Edit I can now remember it wasn't in stock but only took a day to get. the sales guy also stated at the time they use swan necks rather than the proper tool as the torque specs are so low on them. Last edited by kev335i; 08-01-2014 at 10:20 AM.. |
08-01-2014, 12:03 PM | #8 |
Rep 3,201
Thanks. No it wasn't out of shape and the only marking on the inside was '16', which I took to be 16 flats. Maybe it's poor quality control and not made to spec...
08-01-2014, 01:32 PM | #9 |
Rep 1,445
I got mine off eBay and it fits all N type petrol engines.And I use it on a variety of vehicles.Had a look and mine is marked 86/16 which I ordered off eBay for BMW N engines
08-02-2014, 03:12 AM | #10 |
Rep 3,201
Thanks. Any links to current eBay listings?
