MOTIV Motorsport/PTF Hardware release
08-03-2014, 11:21 AM | #1 |
38
Rep 634
Hey guys, we are thrilled to finally make public the hardware we have been designing and testing of the last ~18 months.
MOTIV Direct drop in LPFP system upgrade. This system will be 100% plug and play. Simply remove your old bucket, drop in the new one(using factory connectors)and run an 8AN line using the routing of the factory hose and you are done. This design will change a little before going into full production. MOTIV PI fuel system. Makes use of Bosch fuel injectors being driven by the customers choice of options(AEM, proEFI etc.) In this configuration the fuel system can support upwards of 1000hp. PTF twin disc clutch setup. We are proud to present a twin disc setup we have been working with SPEC to produce and manufacture. Offering a torque rating of +900ftlbs but better drivability than some of the other higher output rated single clutch designs currently available. MOTIV single turbo Kit. This series of pictures shows the progression of the assembly of the manifold and final assembled product. You may be wondering why we went with a bottom mount short runner style manifold and the answer is this: it works the best. We went through designing and testing 7 manifold designs(some just small variations but others complete redesigns) over the course of over a year before finally selecting this design. The great thing about having a fully prepped and dedicated road course/time attack car is that we are able to simulate extended use and wear in a short amount of time. Using a top mount manifold design just simply never worked. Rather than the heat spooling the turbo and then evacuating it would simply radiate in the engine bay creating limp mode inducing oil temps in 2-3 laps and eventually causing valve cover gasket cracking/leaking and other soft part failure. Add to that the 500-600rpm delay in spool compared to using the same turbos in a bottom mount configuration it made the design choice easy. It is a short runner style manifold but far from just run of the mill stuff. Using relatively large ID runners we are able to maintain flow at higher engine speeds but still have unmatched spool. Using 100% CNC billet material and the best fabrication skills available to finalize and assemble to components means a manifold design that will never crack, leak, warp or otherwise fail. kits will be ready to ship 1st or 2nd week of November. 20 kits are being built in the first batch. For those of you that would like to get their kit as soon as they start to ship, as of NOW, you can go to our website in the Turbo Kit section and place either a Pre-order purchase or a purchase for the full kit. This will allow you to reserve the spot and guarantee your kit ships right away. Any questions please PM or email us at allen@protuningfreaks.com jake@protuningfreaks.com dzenno@protuningfreaks.com or sales@protuningfreaks.com Link to the store here: http://www.protuningfreaks.com/turbo-kits.html Last edited by Allen@MOTIV; 10-04-2014 at 10:04 AM.. |
08-03-2014, 12:04 PM | #5 |
Rep 1,834
Drives: 08 E90 335xi TiAg
Wow. Pretty stuff! Love the fabrication. Did I miss pricing?
08-03-2014, 12:28 PM | #7 | |
Rep 452
GIAC, Alpina TCU Flash, Ohlins, Brembo, Eisenmann, Quaife, Evolution Racewerks, Wagner Tuning, AFE, M3 suspension bits
08-03-2014, 12:47 PM | #9 |
Rep 2,567
I'm guessing the lowest power level kit will suffice for the 6AT transmission? =)
07 e92 335i - Retired
18 F80 M3CS - Retired 21 G20 330i M-Sport - Current |
08-03-2014, 12:59 PM | #10 |
Rep 80
08-03-2014, 01:13 PM | #11 |
Rep 578
Other than pricing I'd love to see some dyno's for all the options, overlayed against each other and against some of the twin scroll kits, Stage 2 stock frames to see how everything compares. Also weight savings on this kit vs stock frames and top mount kits.
Was there any testing or consideration on a twin scroll bottom mount? How does the twin disc compare to the Stage 3+ on the street?
2008 135i - MHD/JB4, MS DP's, AMS IC, UI CAI, CDV delete, M3 control arms/Links, RE Toe Link, ECS Trailing Arm, M3 rear SF & Trans bushings, SS brake lines, Michelin PSS.
08-03-2014, 01:21 PM | #12 | |
38
Rep 634
We have a couple potential volunteers to come in to verify fitment. Once that has been done we can go forward from there.
The smallest 600 kit is probably going to be primarily used by road course guys looking for 500whp(pump gas, of course) worth of linear power that won't instantly blow the tires off and be more predictable/reliable than stock frame options. |
08-03-2014, 01:29 PM | #13 | |
38
Rep 634
08-03-2014, 01:32 PM | #14 |
GoofBall
50
Rep 1,055
Ill be waiting . . . Also the fuel rail setup Once the tuning comes into play with a secondary fueling system that will be amazing. Pump gas 93 octane and power all over the place.
08-03-2014, 05:58 PM | #15 |
I'd hit it
1066
Rep 1,107
Someone needs to make an intake manifold. Without the cover, that thing is hideous lol
08-04-2014, 09:37 AM | #17 |
Rep 169
LPFP is safe to use e85 with, I assume?
IG @pobudz | '08 e92 335i - MOTIV 750 w/ PI & AEMMHD tuned, tial bov, ER cp, ADE "800HP" fmic, Corsa 3.5" catback, m3 suspension bits (F&R sway, F&R control arms), rogue toe arms, MOTIV motor mounts, UUC trans mounts and RTD shifter. H&R sports and Koni's, 17x9/17x10.5 Forgestar F14 w/ Mickeys. Quaife 3.08 LSD, M3 subframe and diff bushings. MOTIV Twin disk. Fuel-IT Stage 3+.
08-04-2014, 09:52 AM | #18 |
Slow.
3782
Rep 7,152
Drives: Single Turbo N54 on Meth!
So it will hold 400 more ft lbs of tq and be easier to drive? Not that the stg3+ is hard to drive at all but that is great news.
08-04-2014, 11:32 AM | #20 |
Rep 954
im so happy with this... anyone heard more on pricing for the fuel?
cp-e GTX3071R TT kit, cp-e quad exhaust, cp-e fuelbar, Stage 3 LPFP+lines, AEM EFI, Custom Meth kit, Apex EC7 18s w/R888 295s, Stoptech, M3 front, m-sport rear, cp-e difuser, Custom Headlights, CFS Radiator, Custom OC, 1000hp Lvl10 trans, DSS Axles, MFactory LSD, DEFIV lockdown kit, M3 refresh kit, KWv2's, cp-e project "4doorbmwpower"
08-04-2014, 04:12 PM | #21 | |
Rep 632
If I decide to ever go single this will be my kit!
2007 335i e90 6mt | Motiv 750 XR8267 | RB PCV | JB4 G5 | MHD Pump Flash | Walbro 255lph | VRSF CP & Tial BOV | NGK Plugs | Custom Side Exhaust | CxRacing FMIC | Spec 2+ & SSMFW | StopTech Drilled/Slotted Rotors | Hawk Performance Pads | DEFIV Lockdown kit | Mtec V3 | Apex PS7s | 35/15% Llumar ceramic
