Shredded Serpentine belt and mystery Oil Filter Housing Leak
08-04-2014, 10:15 AM | #1 |
Rep 398
Drives: 15 Porsche 911 GT3
So last Wednesday I got a red battery light followed by a complete loss of power steering about a mile later. Come to find out I had a shredded serpentine belt. I was able to repair the belt and install new pulleys. But now I have a mystery oil leak at the front of the oil filter housing thats coming from near the oil cooler feed/return lines. I can literally watch the oil start to slowly seap out when I turn on the engine. Is it possible that the front section of the oil filter housing is cracked? I can't tighten the oil feed/return lines any tighter. (PERHAPS I over torqued them??) It seems to be leaking out of the right line (not sure if thats the feed or return when looking at the front of the engine) that connects into the H-Clip of the other oil feed/return line.
BACK STORY: A week or so prior to that I replaced both gaskets on the oil filter housing due to what I thought was a leak between them. I believe this was the cause of the serpentine belt shredding prematurely due to the oil and gunk getting on the pulleys and rapidly deteriorating them. Advice from you guys is welcome! Thanks for your help.
2021 Marina Bay Blue X5M Comp
2015 Porsche 911 GT3 *SOLD* 2017 Yas Marina Blue M3 *SOLD* 2009 E92 335i M-Sport - Space Grey Metallic *SOLD* 2011 Lexus IS-F Last edited by 4cfd bmr; 08-05-2014 at 11:36 AM.. Reason: Adding pictures |
08-05-2014, 12:33 AM | #2 |
I sweat pheromones
206
Rep 2,103
Sorry man. That does suck.
I wonder if the shredded belt smacked one of the lines. It could have caused damage between the hose and metal connection. *shrug* Just another possibility. Subscribed for images. |
08-05-2014, 11:37 AM | #3 |
Rep 398
Updated first post with pics
2015 Porsche 911 GT3 *SOLD* 2017 Yas Marina Blue M3 *SOLD* 2009 E92 335i M-Sport - Space Grey Metallic *SOLD* 2011 Lexus IS-F |
08-07-2014, 12:12 PM | #4 |
Rep 398
Bump for some help....
Anyone know if there are supposed to be O-Ring Gaskets/Washers that go in between where the feed/return lines attach to the Oil Filter and Thermostat Housing? On realoem.com it doesn't look like it.
08-07-2014, 12:29 PM | #5 |
Rep 2,373
Each oil cooler line has an oring. Also-every shredded belt I've seen on these engines sucks belt into the engine. Be sure to remove the crank pulley and inspect.
08-07-2014, 12:30 PM | #6 | |
Rep 1,643
2007 E92 335i MT
08-18-2014, 09:52 AM | #7 | ||
Rep 398
Tags |
oil cooler 335i cooling housing, oil feed/return line, oil filter housing, oil leak, serpentine belt |
