plug for tuned car
08-07-2014, 03:33 PM | #2 |
Rep 277
Just the regular ones that would be coming with the car. Just going to have to replace more often.
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF Catless DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch |
08-08-2014, 12:35 PM | #4 |
BimmerPost Supporting Vendor
24503
Rep 191,503
The regular bosch ones will do fine
08-08-2014, 12:53 PM | #5 |
Rep 315
Use the OEM Bosch plugs. They handle all the additional power well with the only affect being shorter lives - they'll require replacement every 20-25k miles.
Any plug for a tuned 335i will require those short change intervals anyways. Part #: 12 12 0 037 244
07 335i
Mods: JB4 + MHD BEF, RB Twos Plus, Phoenix PI Manifold, Dual Walbro 450 LPFP's, DCI, VRSF DP's, VRSF 7.5" FMIC, VRSF CP + TiAL BOV, VRSF inlets & aluminum outlets, TC Kline SA, M3 F/R control arms, M3 subframe bushings |
08-08-2014, 01:14 PM | #6 |
Rep 719
Higher boost can make your car more susceptible to knock so for my car I choose to run the 1 step colder NGK's... High mixtures of e85 can cause "hiccups" first thing in the morning though !
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
08-08-2014, 01:15 PM | #7 |
Rep 84
If you want to push the car for more performance, you need to get NGK 5992 and gap it to .022. I used both. The OEM plugs does last long. The OEM plugs only lasted for 10k miles before they start to missfire.
08-08-2014, 03:24 PM | #8 | |
Rep 719
08-08-2014, 04:40 PM | #9 |
Rep 1,465
Drives: 2009 BMW 335xi
Stock
08-09-2014, 09:14 PM | #11 | |
Modify the N54
17
Rep 366
I think it was .22 that did the trick for me! |
08-11-2014, 12:17 PM | #13 |
Rep 1,465
08-11-2014, 12:38 PM | #14 | |
3442
Rep 79,211
It's really a matter of budget and laziness. Bosch are a little more money. NGK are a little cheaper but you need to gap the NGK where as the Bosch come pre-gapped. Supposedly the Bosch last a little longer then NGK. |
