Chargepipe not covered by CPO warranty?
08-12-2014, 09:28 AM | #1 |
Rep 370
My chargepipe cracked this weekend after getting new plugs and oil change. I got it towed to the dealer and they are telling me that a sensor on the chargepipe is unplugged, therefore they arent warrantying it because it looks like someone unplugged it. They also are telling me that chargepipes arent a warrantable item. Does this make sense? I though cracked CP's were warranty items. The only reason I even went to the dealer was because my c-clip is non-existant.
08-12-2014, 09:31 AM | #2 | |
Rep 10,120
08-12-2014, 10:37 AM | #3 |
Rep 370
thats pretty much what i said to my SA, they quoted $450 for the new CP Does anyone else have any experience with a cracked CP under warranty?
08-12-2014, 10:48 AM | #4 |
Rep 554
Drives: E92 335i 6MT
Call and ask to talk to a manager or go to another dealer, charge pipes are covered and their reason for denying it is weak at best.
08-12-2014, 10:49 AM | #5 |
Rep 409
my car was out of warranty when mine broke, but the sensor was unplugged when the pipe cracked, it broke the clip for the sensor... That's horse shit from the stealership. should absolutely be covered.
2009 E92 335i M-Sport - MHD Stage One - BMW Performance Exhaust - BMS Oil Catch Can - CDV Delete - K&N Panel Filter - Arc Angel H8 bulbs - Gloss Black Kidney Grills - Painted Reflectors - VRSF Charge Pipe
08-12-2014, 11:22 AM | #7 |
Rep 409
99% of the time it will be on your undertray somewhere. get an extendable magnet and a flashlight, they're really hard to come by if you cant find it. I don't have one
08-12-2014, 11:48 AM | #8 |
Rep 661
Is this the c clip? Just found it on ecs http://www.ecstuning.com/BMW-E92-335...ntake/ES39182/
08-12-2014, 11:50 AM | #9 |
Rep 370
I actually watched it shoot out the front of the car and bounce down the highway. Lucky shot i guess lol
08-12-2014, 11:52 AM | #10 |
Rep 1,040
The only sensor that attaches to the charge pipe is the MAP sensor... Wouldn't the car have some other issues if that wasn't plugged in?
At this point, I would just get a metal charge pipe and never worry about this problem again.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
08-12-2014, 12:10 PM | #11 |
Rep 370
yup thats the plan, i am just trying to get a free cp and c-clip from the dealer first, so i can swap the aftermarket one out when i take it in for service.
08-12-2014, 12:11 PM | #12 | |
Rep 409
08-12-2014, 12:13 PM | #13 |
Rep 409
Yes, the car would have other issues with the MAP sensor unplugged. its pretty common that when the charge pipe breaks and shifts as a result, the clip for the sensor breaks and it comes unplugged. Happened when my pipe broke, and got a MAP sensor code.
08-12-2014, 02:10 PM | #14 |
Rep 370
I talked to them again and they said its going to be covered under "goodwill" thankfully. Its just annoying having to argue with them over stuff like this.
08-12-2014, 02:11 PM | #15 | |
Rep 1,040
Ah, ok, that's what I was thinking, but it sounds as though the dealer is trying to blame the fact that its unplugged for the actual crack... Shifty stealers trying everything to avoid giving away a cheap flimsy pipe that takes minutes to swap.
08-12-2014, 02:40 PM | #16 | |
Rep 409
Op, glad they are covering it under goodwill. Doesn't make them right, but glad they are doing the work
08-12-2014, 03:04 PM | #17 |
3442
Rep 79,211
It's nice they covered it but it will still be prone to cracking again in the future. You should consider an upgrade like the VRSF CP with OEM connectors. For under $200 you really can't beat it for peace of mind.
Keep your new stock CP for a rainy day if you need to go back to dealer and want to remain stock, my .02. |
08-19-2014, 07:39 PM | #18 |
Rep 115
The same thing happened to me recently, and due to ridiculous OEM prices, I opted for the ER chargepipe with stock DV connection and haven't had a problem since. More durable too, especially if you're running a tune.
