No boost running really rough
08-13-2014, 12:04 PM | #1 |
Rep 33
hi guys driving the other night map 5 on jb4 about 15 pounds of boost and had what i thought was a misfire jb4 cleared the code so i was reading zero codes.
Pulled all the plugs and replaced them cant get it to throw the ses light now but i have no boost and it runs very rough. Where to start?? Thanks Cody Did get it to throw a code misfire cylinder 4 29D0 and 1/2 engine light came on Last edited by cmotzner; 08-13-2014 at 02:51 PM.. Reason: added logs |
08-13-2014, 12:23 PM | #3 |
BimmerPost Supporting Vendor
24503
Rep 191,503
Please do couple logs from 3rd gear (2500 rpm to redline with pedal 100%)
08-13-2014, 01:11 PM | #6 |
Rep 719
If you have auto clear on I would start by shutting that off and then drive it a little to see if it will throw a code... Are you still running the original charge pipe? I'm on my phone so I can't see your mods..
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
08-13-2014, 03:27 PM | #8 | |
3442
Rep 79,211
Make sure you have the o ring in place as well as the clip seated correctly. Last but not least make sure the T bolt clamp is tight on the intercooler side. |
