08-18-2014, 06:08 AM | #1 |
Rep 319
deAuto LED Rear Turn Signal, Reverse, Brake Lights
So got a chance to try out deAutoKey's LED bulbs for F2x, F3x and have to say I am absolutely impressed.
The left side of the tail lights are the OSRAM LED and the right side is the newest CREE LED. Cree is evidently a little bit brighter but Osram have a more amber turn signal light (Cree's amber is a little bit mixed with red maybe due to housing). I'll update with pictures on the built quality but it is very high quality built. Also, brake lights had 3 bulbs and I only ordered 2 on each side so one of the middle bulb is actually oem stock. Well I'll let the pictures do the talking. As you can see in this one, the outer bulb is evidently brighter. The middle one is the stock oem. the inner one is LED as well but I think its just angling issue so you can't see it as bright. In the picture, both turn signal is about the same color but in reality, left (Osram) showed a lot more orange/amber than right (Cree). But you can tell that the right is a little bit brighter. Update: http://deautokey.com/product/bmw-f2x...e-turn-signals Now I have to mention that it did flash on engine start but not any other time. After reading some user on f30 using other led stating led flash when driving, I've decided to test it out further this weekend. Hopefully video will be posted. Meanwhile, if you enter my username, cbbplanet, at checkout, you will receive 10% off the purchase Last edited by cbbplanet; 08-20-2014 at 11:17 PM.. |
08-18-2014, 06:53 AM | #2 |
***** noob
1373
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Hmmm...i notice the oem reverse is not bright enough as I have tints, might need to upgrade
Looks good
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
08-18-2014, 08:35 PM | #4 |
Rep 25,989
Nice! Im going to have to look into doing this for my 2
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
08-18-2014, 10:13 PM | #5 |
Rep 319
So the vendor is setting up the web page but I'll have some discount code for you guys as well so please wait a bit! It'll definitely be cheaper than Bimmians LED.
If you're in socal area, I can install for you for a small fee. Install isn't hard but you do need some tools to remove the rear tail lights completely. I'll post up install thread later possibly but you have to remove the 2 washer screws underneath the black flap cover next to the taillights. |
08-19-2014, 02:35 PM | #7 |
"The Midas Touch"
521
Rep 1,055
Drives: F87 LBB ///M2
Any errors? Looking to install these on a E82 135i
08-19-2014, 10:41 PM | #9 |
Rep 319
08-20-2014, 11:16 PM | #10 |
Rep 319
Here's the link.
http://deautokey.com/product/bmw-f2x-f3x-and-x1-complete-taillight-led-kit-including-reverse-brake-turn-signals Now I have to mention that it did flash on engine start but not any other time. After reading some user on f30 using other led stating led flash when driving, I've decided to test it out further this weekend. Hopefully video will be posted. Meanwhile, if you enter my username, cbbplanet, at checkout, you will receive 10% off the led |
09-03-2014, 06:29 PM | #12 |
Rep 319
09-03-2014, 10:28 PM | #13 | |
Rep 809
Just one question, as far as I know, when you hit hard on the brakes, the brake lights do warning hyper flashing automatically. Have you checked if this still work with the LEDs installed? Thanks |
09-04-2014, 09:47 PM | #14 | |
Rep 28
Thanks in advance. And I agree with AlexGT - thanks very much for the discount code - Last edited by E46toF22; 09-05-2014 at 12:16 PM.. |
09-07-2014, 10:20 PM | #15 | ||
Rep 319
09-20-2014, 01:57 PM | #16 |
Rep 319
Update - so it looks like the Cree does throw an error by flickering. However, it's not consistent. I'm not sure what's the reason but I'm guessing it has to do with the total wattage. It started after I switched brig reverse lights to Cree. I'll play around with it some more and keep everyone updated.
The front turn signal result isn't great sot here communicating to manufacturing to produce something brighter. |
09-20-2014, 10:43 PM | #17 | |
Rep 809
09-23-2014, 04:45 PM | #19 |
Rep 319
09-23-2014, 04:49 PM | #20 |
Rep 809
So you think the OSRAMs will not flicker when I start the car? I've not yet installed the ones I purchased (6 OSRAMs bulbs for the stop lights only), to be honest I haven't done it yet due to the possible flickering at start up.
09-23-2014, 04:54 PM | #21 | |
Rep 319
Follow my instagram and you'll see the video of startup: cbb.chen |
09-23-2014, 06:09 PM | #22 |
Rep 809
Thanks Chris, I've just looked at the video, I see it flickers a lot during startup. For how many seconds do you think this flickering goes during startup?
