long cranks and gauge sweeps
08-19-2014, 11:40 AM | #1 |
Rep 1,004
so i have a 2010 fbo 135. i have had the jb4 g5 since may, flashed the bms race file in july and a week and a half put a walbro 255 inline and flased the bms e85 mt file. saturday i drove around and when i stopped for an hour when i went to get back in and start it up it would just crank and the gauges would keep sweeping. when i would try again it would fire right up. it has done this every day at least once. as soon as i try again it starts right up, every time. always starts up first thing in the morning and i can start it 5 times in a row without it happening. only after i drive at some random time after being turned off for a while, tonight it was off for 20 minutes and it did it. i bought the jb4 brand new from a vendor on the other forum. no codes thrown when checking with the bms cable, haven't scanned it yet with the bt cable. just wondering if this has happened to anyone else? or any suggestions. jb4 went in in may and i have never played around or disconnected it.
thanks |
08-19-2014, 01:28 PM | #2 |
Rep 719
I would look at your fuel pump install.. Gauge sweep is an option on the JB4 so that is normal I believe.
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
08-19-2014, 03:06 PM | #4 | |
Out Boosting...
243
Rep 3,987
JB4 map guide on google top post will tell you what steering controls they are!
Alpine White M-Sport F30
08-19-2014, 05:50 PM | #5 |
Rep 719
Battery issue?? check your ground....
08-19-2014, 05:58 PM | #6 |
Rep 868
I occasionally get long cranks when cold, I have the Steve AZ inline 255 and run straight e85 most times. Usually I just let off the break and it starts up easy the 2nd try.
My logs are good per BMS, no pump issues. How much e8five you running? R Also the reason I mentioned SteveAZ cause his setup was one of the easiest installs ever....... He did a great job!!
JB4 G5 ISO , AR DP's, DO Meth kit Trunk Mount, ETS 5" Intercooler, M6 Rims, ER Charge Pipe, Fordged DV's, MMp relocated inlets, Ebay 4" chrome Tips, Lux Angel Eyes **********11.910 @ 117.09***1.851 60'********** |
08-19-2014, 06:59 PM | #7 |
Rep 277
Was going to say the same thing.
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF Catless DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch |
08-19-2014, 09:02 PM | #8 |
Rep 1,004
didn't do it tonight. i dont know how old the battery is, i bought the car in may with 50000 miles. i am running e60. i bought the kit from steve and its great. took me over an hour to get that damn green line of the stock pump, i didn't want to break it.
and what ground? the one from the battery in the trunk? i never remove that one, i always just remove the positive. |
08-19-2014, 09:09 PM | #10 | |
Rep 719
08-19-2014, 09:37 PM | #12 |
Rep 5,463
The gauge sweep command is sent when the jb4 sees power come on, so it could be a power issue or ground and could be at the jb4 also so would double check connections there also, but sounds like some connection is intermittent.
2025 X5 Msport
08-19-2014, 10:36 PM | #13 | |
Rep 209
