Square Setup
12-20-2007, 03:46 PM | #1 |
Rep 2,904
Drives: Canada's first and only 323xi
Square Setup
For next season's track days, I would love a 17" all square setup. Probably 245/40/17's on all four corners. Ideally, all four rims would have the same offset so I can rotate them front and back, but is this possible? If not, I would prefer to have a proper offset on each front and rear pairs of rims instead of using spacers.
Can you guys give me some specs of your setup if you run an all-square setup? TIA. |
12-20-2007, 03:59 PM | #2 |
Rep 4,380
Drives: 2014 Audi A4 / 91 Track Miata
I have 18X8.5" with 235-40-18 R compounds for my track set up...my daily driving set up is 19X8.5F and 19X9.5R with 235/35/19 F and 265/30/19 R.
The wheels are SSR CS-Rs from Tirerack.
Car is now gone .... :-( |
12-20-2007, 05:54 PM | #3 |
Rep 2,904
12-20-2007, 10:40 PM | #6 |
Rep 4,380
Not sure..I gotta check..but remember I am also sporting 18X8.5" wheels..not 17s.
12-22-2007, 08:51 PM | #7 |
Rep 2,904
I think those are pretty much the same wheel specs as my SSR GT7's. The rears look way too tucked in though... how does yours look?
12-22-2007, 08:53 PM | #8 |
Rep 2,904
The 18" figure has no bearing to how far it's pushed out toward the wheel well methinks. Wouldn't a 18x8.5 with the same offset as a 17x8.5 be the same distance toward the wheel well?
12-22-2007, 09:08 PM | #9 |
Rep 4,838
12-23-2007, 06:46 AM | #10 |
Rep 2,904
12-24-2007, 04:13 PM | #11 |
Rep 119
Track is for go, not for show
335i coupe, pss9s, F1 GD3 C5 Z06 |
03-19-2008, 04:25 PM | #14 |
Rep 2,904
What about BBS rims in 8.5 with 35 offset? According to the calculator, that would result in a wider track up front than stock and each rear would retract 2mm from the fender and 2mm closer to the strut.
03-19-2008, 05:04 PM | #15 |
Rep 4,726
Can you fit 4 of those in the car BTW?
03-19-2008, 05:19 PM | #16 |
Rep 4,380
Easy..I have the tirerace tire totes..and the tires line up in the rear seat..side by side...with extra room. No problem whatsoever. I put my jack, tools, helmet, cooler, and suitcase in the trunk. All the other stuff is in the back seat. I can take one other passenger in the front.
03-19-2008, 05:58 PM | #17 | |
Rep 4,726
03-19-2008, 06:29 PM | #18 |
Rep 4,380
Nah...I put down a moving blanket on the seat surface itself.
03-19-2008, 08:44 PM | #19 |
Rep 2,904
03-20-2008, 12:49 AM | #20 |
Rep 4,380
Gosh..I wish I knew...they dont tell you when you order them...let me try to do some research.
03-24-2008, 02:49 AM | #21 |
Supreme Allied Commander
3885
Rep 54,494
Drives: F80 M3
