2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding best new car spec for coding
      08-27-2014, 05:11 AM   #1
absolute47
Drives: white saloon
Just a thought...
what would be the lowest spec car you could buy, that when you coded would give you the best spec...?
or to say another way, what options open up the most coding availabilities?
cheers
Dunc
      08-27-2014, 07:48 AM   #2
JesseIan
JesseIan's Avatar
Drives: 535i M-Sport, G37X, Tesla MS
Really depends what you want from options, a friend has made a list for something else but I figured I would post the list here in case you aren't sure exactly what options are out there that would interest you. Not all apply to F10 and there may be more out there, but this is a decent sized list to get an idea!
Convenience & Operational Options
☐ Close windows/sunroof with key fob
☐ Fold/unfold mirrors with key fob
☐ Open/Close liftgate with key fob/in-cabin button
☐ Auto unlock doors on key eject or engine off
☐ Set wipers to complete cycle when shutting off the car
☐ Disable headlight washers
☐ Enable one-touch window operation with door open
☐ Disable seatbelt butler for driver and/or Passenger
☐ Set Auto Start/Stop to off by default - F series only
☐ Disable Active Sound Design (ASD) in M5/M6 - F series only
iDrive
☐ Disable iDrive "Accept" screen
☐ Disable iDrive camera disclaimers
☐ Add/Remove weatherband radio
☐ Enable DVD in Motion
☐ 8 shortcut buttons instead of 6 (uses Mode and AM/FM buttons)
☐ Enable Sport Display (horsepower and torque gauges) - F series only
☐ Enable PSI and Temperature in TPMS - F series only
☐ Increase address/message storage from 25 to 50 - F series only
☐ ///M startup splash screen - F series only
Lighting
☐ Disable corner led and ambers for parking lights/headlights
☐ Enable double blink hazards for hazard button
☐ Disable DRL tail lights
☐ Disable auto dimming mirrors
☐ Disable cornering lights (E92 or E70)
☐ Angel eyes as day time running lights (E90 3/2007+ build)
☐ Enable rear fogs under normal braking
☐ Enable GTS brake force display
Gauge Cluster
☐ Enable ///M Digital speedometer
☐ Enable real-time MPG
☐ Adjust fuel reserve warning from 1/4 to 1/8 (M Cars)
☐ Enable ///M Performance start up screen - F series only
☐ Disable key in ignition chime
☐ Disable seat belt chimes
Retrofit Options
☐ Aux input coding
☐ Disable EDC on M cars
☐ Disable RDC/TPMS for aftermarket wheels
☐ LCI lighting coding for front or rears
☐ Recaro or other race seat coding
☐ Alarm retrofit coding
5post
