Pulled a Log on a 1/4 run
09-04-2014, 12:20 PM | #1 |
Rep 2,114
Haven't posted up a log in a long time but I figured I would try something different for a change. I'm running the E30 OTS map from Cobb right now and I pulled this log last night during my 13.2 1/4 run at Bandimere. DA was ~9300ft and the car felt really solid all night long. Just figured I would share, I haven't seen anything yet that's given me any cause for concern.
http://datazap.me/u/alpineswift/stg3...=0&data=1-6-21
E92 '08 335Xi 6AT - Cobb AP3 Tuned by MAC Autosport, Original Prototype Xi DOCRace 6266 Single Turbo Swap, VRSF CP w/Synapse BOV, VRSF 7" FMIC, BMS Cowl, H&R Coilovers, Renn Motorsport RS-51's, Stoptech Stage 2 Slotted, xHP Stage 3, Earl's Racing Oil Cooler, Turner Boost Gauge, M3 Lip Spoiler.
Standing Mile Record Holder for Xi over a mile high: 168.2MPH @ 5512'; The Colorado Mile hosted by The US Mile. |
09-04-2014, 12:35 PM | #2 |
Rep 277
Those are some high IAT's! You hit 150 degrees by the end of the run. Too bad.
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF Catless DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch |
09-04-2014, 12:38 PM | #3 |
Rep 2,114
It was 90* ambient and I was having a hard time getting the VRSF 7" cooler to chill the F out.
09-04-2014, 12:39 PM | #4 |
Rep 277
Time for a Meth setup, lol.
09-04-2014, 12:44 PM | #5 |
Rep 2,114
I've been thinking about it just to bring the charge temps down pre and post intercooler. I've never been a huge fan of Meth as I think it brings too many risk factors in especially for a street build like mine, but at this point its starting to look like it's unavoidable.
09-04-2014, 12:49 PM | #6 |
Rep 277
Yup. Good for controlling IAT's in the heat. More consistency.
09-04-2014, 12:52 PM | #7 |
Rep 2,114
That's what I was running last night was E30 blend. Waiting for PTF to finish their hardware release so I can get my hands on that new fuel bucket upgrade and go 100% E85. Still gonna need meth for IAT's though. Grrr.
09-04-2014, 01:00 PM | #9 |
Rep 277
Yes 9300ft as stated in original post.
09-04-2014, 01:01 PM | #10 |
Rep 2,114
Elevation at Bandimere is 5860ft. DA was 9300ft @ 84*F ambient around 6PM and this run was done at about 4:30PM. It's likely the DA was even higher given the fact that the temps were about 5-7 degree's hotter around 4 when I ran but since they weren't reporting on the time slips last night like they usually do I have no idea.
09-04-2014, 01:06 PM | #11 | |
Rep 6,478
And w E50 things will look better in-cylinder than the raw IAT will suggest. Ethanol does magic during the compression stroke.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
09-04-2014, 01:09 PM | #12 | |
Rep 2,114
09-04-2014, 01:17 PM | #13 | |
Rep 6,478
Back in the day I sprayed via a single AM jet tapped in the cold side end tank. Sold that kit (IDK why) and long story short, replaced it with an identical AM kit not that long ago. This time i'm spraying from a more "traditional" location right on the cold side charge pipe. Haven't tuned for it yet but once I get around to it, i'll be able to compare the temp deltas from last Summer (when I was spraying farther downstream).
09-04-2014, 01:20 PM | #14 |
Rep 6,478
The beauty of using meth as an IAT tool, rather than as your fuel, is that you don't have to be quite as obsessed with distribution between cylinders (which i'd be willing to be is pretty poor). Not to say it isn't important, but you aren't relying on it to sustain your boost and advance so if for whatever reason the system totally crashes, you won't be melting any expensive parts.
09-04-2014, 01:51 PM | #15 |
Rep 2,114
@135Pats
I would never run meth as an octane supplement. Too much that can go wrong with that. I think the best way to get proper atomization of the meth would be to port it in as far back on the cold side as possible. My thinking is putting the meth on the hot side would defeat the purpose of the intercooler and cause the meth to be wasted/collected in the intercooler rather than dispensed on the cold side with the charge air. That's my theory anyway. Lol
09-04-2014, 01:53 PM | #16 |
Rep 653
thats waaaay hot for having a 7'' IC. def want to add meth
2012 DCT 135i
PURE S2 JB4/mhd Fuel-It! direct port meth injection check out my youtube channel here |
09-04-2014, 02:52 PM | #17 | ||
3442
Rep 79,211
I saw DA. I was looking for real elevation numbers, thank you though.
In regards to your post about methanol and nozzle areas. You could spray one pre intercooler and post intercooler. Hell you could even spray pre turbo if you wanted but that typically comes at the cost of potential blade wear from any subsequent poor atomization. Quote:
09-04-2014, 03:06 PM | #18 |
Rep 277
[QUOTE=Jeff@TopGearSolutions;16579740]I saw DA. I was looking for real elevation numbers, thank you though.
QUOTE] Ah okay, no worries.
