Can a slow leaking run flat be fixed?
09-15-2014, 08:48 PM | #1 |
Rep 622
So overnight my run flat tire seems to be losing about 8 PSI, it has a medium/slow leak.
Can it even be fixed or should I just plan to replace it? |
09-15-2014, 09:11 PM | #4 |
Rep 425
Depends. If its like a leaky valve stem, nail, leak from the bead etc. Can be fixed with a new valve stem, plug, bead seal etc. Personally I plugged my run flat on my F10 535xi it lasted 4K+ miles no problem (before selling it). However you should not repair it if the puncture is near the sidewall. You can take it to any tire shop and let them spray it with soapy water to determine where the leak is from then go from there.
09-16-2014, 04:05 AM | #5 |
Rep 6,149
Most big corporation tire companies will not repair run flats. I would imagine a small mom and pop company would do it.
Just a way for tire companies to sell tires saying they cannot repair run flats.
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
09-16-2014, 11:12 AM | #6 |
Rep 1,951
+1 to everyone. I caught a nut of some kind in my tread, but it was far enough from the sidewall that it wasn't a problem at all. A tire shop near me did a proper plug and patch and it's been fine for the last 10k miles.
09-16-2014, 11:16 AM | #8 |
Rep 1,951
And the worst part is that they'll upsell you to a full new set of 4 so that they're wear-matched. Fuck that noise.
09-16-2014, 11:21 AM | #9 |
Rep 1,995
Last time I tried to get a tire plugged. They took me under the car and was like we can't do it. Then when I was like let me research tires at home they wouldn't plug it so I could not leave.
