Minor boost leak after IC install or normal behavior?
09-18-2014, 05:03 PM | #1 |
Rep 2,189
Looking at my logs it seems like it takes a little bit longer for boost to ramp up then it did with factory IC and also I seem to be about 1lb of boost under targets pretty much across the board.
Do I have a small boost leak after install or is this normal behavior when going from stock IC to 7" IC? |
09-18-2014, 06:06 PM | #2 |
Rep 1,264
check all your couplings just went through this issue myself, but I had a whine like a supercharger from the driver side intercooler coupling
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Walbro|VRSF 7"| 149.7mph NFZ AZ 1/2mi
1992|Pontiac Firebird|Mild 355ci|T56| -I will look on your treasures, gypsy. Is this understood?- |
09-18-2014, 06:19 PM | #3 |
Rep 2,189
09-18-2014, 06:22 PM | #4 |
Rep 1,264
Yep.
