New clutch opinions..
09-22-2014, 05:31 AM | #1 |
Rep 298
Hello, i have a 2008 bmw 335 E93 with procede rev2 at 15-17psi, intercooler and no cats and i am looking for new clutch.
The oem clutch fried at 30.000kms with 13psi and after that i put the organic act. The act gave up after 35000kms with 16-17psi. Now i would like something better in mileage lasting. Should i go with Spec Stg 2+ with stock dual flywheel, or something else? My horsepower should be around 400hp, but the extra weight make the clutches not lasting a lot. |
09-22-2014, 07:45 AM | #2 |
Rep 823
http://www.ecstuning.com/BMW-E92-335...221/ES1897635/
if you aren't going to be upgrading your turbos get this and call it a day. 335is clutch and is considered an OEM upgrade. About the same price as the stock clutch, same feel. Won't need to buy a new flywheel either. |
09-22-2014, 07:46 AM | #3 |
Rep 718
A lot of people are using the Stock 335is/550i clutch. Apparently it holds find on tuned 550is putting out almost 500 ft/lbs of torque. I've read they hold well on FBO 335i's, but I don't know the longevity of them, maybe some one that has had one for awhile can chime in.
I just got one installed on my car, but haven't picked it up yet.
09-22-2014, 07:51 AM | #4 |
Rep 823
i have one on one of my FBO 335s and its held great grips quickly, but I don't have have any real long term use only 4k miles are so. I think some others have reported its held fine for them in the longer run.
09-22-2014, 08:42 AM | #5 |
Rep 8,339
Check how you're using your clutch too. Mines got 200,000 with a tune and still running strong on the one it was born with. Maybe you're holding it in at lights, etc. They should last a lot longer.
09-22-2014, 09:15 AM | #6 |
Rep 298
Does anyone have 335is clutch tested for a long period in miles? I consider for spec 2+ because many users have this kit installed. Does anyone know how many miles does it last?
09-22-2014, 09:58 AM | #7 |
Rep 1,643
I havnt seen any of the 'real' 335is cars that are FBO and tuned on here complain about their clutches going.
2007 E92 335i MT
09-22-2014, 11:32 AM | #9 | |||
Rep 823
direct fitment, don't need an aftermarket SMF or anything like that. Try to clean off the flywheel as best as you can and install it. Not sure on the part number too lazy to check |
09-23-2014, 02:05 AM | #10 |
Rep 298
To clean the flywheel, should it be taken off or can the mechanic clean it mounted?
Something else, i searched the real oem and only find this part in usa bmw 550i, not in the europe cars. Doesn't the european 550i came out with manual transmition? Also noticed that 550i flywheel partnumber is different from ours 335? Isn't that a problem for the clutch? If someone can veryfied the part number i would be very gratefull. Now i am between spec 2+ and 335is clutch.. |
09-23-2014, 08:39 AM | #11 | |
Rep 823
http://www.realoem.com/bmw/showparts...21&fg=05&hl=31 http://www.realoem.com/bmw/partxref.do?part=21207603248 |
09-23-2014, 10:14 AM | #14 |
Rep 1,040
Needing to replace a clutch at 30,000km probably means there needs to be a driving adjustment. I have 40,000 miles on mine (stock) making around 500ft-lbs at the wheels and I've never so much as slipped the clutch. I would guess either you launch your car or beat on your clutch a lot which at that point I would recommend at least a spec stage 2+/3 at your power levels if you want to continue to do that or you are riding your clutch like a newb. Another thing that may help out is getting a ported clutch delay valve which should help with longevity.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
09-23-2014, 10:25 AM | #15 |
Rep 823
thats true i didn't fully read through the op's post enough to see he's running through clutches abnormally fast.. if its because you are dumping the clutch all day from a dig you should probably opt for the spec 2+... otherwise there is a user error on your end.. 86k on the stock clutch with my mods and no slip..
09-23-2014, 11:15 AM | #16 |
Rep 277
335is clutch holds fine on our 335i up into the high 500whp range actually. My buddy is using it on his 335i with those whp numbers and 600wtq+. He's done about 15 track days on that too. He doesn't launch it on the street and he limits boost in his first two gears though. But nevertheless he's pushing a lot of power on this clutch for about 40,000km now.
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF Catless DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch |
09-23-2014, 11:27 AM | #17 |
3442
Rep 79,211
I've seen some guys smoke their clutches up before 20,000 miles. I attributed it mostly to driver error. I'm sure there is a fluke here and there but I've seen some pretty poor driving habits from manual drivers in my life time so nothing surprises me.
09-23-2014, 11:29 AM | #18 | |
Rep 277
09-23-2014, 01:16 PM | #19 | |
Rep 1,040
+1... BUT, its sounds a whole lot cooler if you tell people you need a new clutch every 30,000 kilometers (18,641 miles) because your car has way too much power than telling people you need a new clutch because you drive a manual like a 14 year old girl.
09-23-2014, 01:37 PM | #20 |
Rep 298
No bad driving guys, just to heavy car with much torque. I never floor it from dead stop, only with second gear, but i floor it many time with 4th-5th gear from 3000rpm. In downhill i always brake with the engine with rev match technic. Does the rev matching technic harm the clutch a lot?
Something else, when i installed the act clutch, i put a short shift uuc and noticed i have some vibration when i put my hand on the gear level. I always thought that it was from uuc short shift, but is it possible to be from the dual mass flywheel? I mean is it a way to know if the flywhell is damaged before i take off the clutch disk?. The spec stage 2+ or 335is clutch does it necessary needs another flywheel to combined or the old one i have should be ok? |
09-23-2014, 01:54 PM | #21 | |
Rep 1,040
What extra weight are you referring to? Also, many people on here are running stock clutches with FBO N54s with no problems. 18,641 miles would be a manufacturer defect or really abusive driving. From the looks of it, you just have a procede, intercooler and downpipes. Certainly with the right fuel, you could have over 400lb-ft of torque at the wheels, but that isn't enough to destroy a stock clutch that quickly without a lot of abuse. Also, flooring your car in 5th gear at low RPM is horrible for the clutch.
09-23-2014, 02:01 PM | #22 | |
Rep 823
