10-16-2014, 04:09 PM | #1 |
Rep 10
How to Permanently Make Your Headlights Clear!!!
Hey guys,
So I have been working on a method to make your headlights permanently clear and here it is. There are many ways to make your headlights clear such as kits from the store (3M is pretty good), toothpaste, baking soda, brake fluid, bug spray, wet sand, etc. Some work great, others are bad for your lens, but no matter what, all of those methods are temporary. This video shows my method that is a permanent UV seal over the headlight lens so it wont fade. I experimented with different grit sandpaper, different sanding methods, different clear coats, and this is what I found to work best after all my testing. Let me know what you think! Hey guys, So I have been working on a method to make your headlights permanently clear and here it is. There are many ways to make your headlights clear such as kits from the store (3M is pretty good), toothpaste, baking soda, brake fluid, bug spray, wet sand, etc. Some work great, others are bad for your lens, but no matter what, all of those methods are temporary. This video shows my method that is a permanent UV seal over the headlight lens so it wont fade. I experimented with different grit sandpaper, different sanding methods, different clear coats, and this is what I found to work best after all my testing. Let me know what you think! |
10-18-2014, 01:43 PM | #2 | |
Rep 734
10-18-2014, 08:34 PM | #5 |
Rep 11,191
I have used the 3M kit which works amazing, especially since I just use my drill with it. Then I just add a coating, like the Sonax one.
10-19-2014, 10:39 AM | #6 |
Rep 12,446
This was great! Good voice for this stuff too.
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
Tags |
foggy, hazy, headlight restoration, headlights |
