Jack positioning in a single-car garage
10-17-2014, 09:11 AM | #1 |
Rep 965
Drives: '14 328xi sport line
Garage List 1981 Fiat 124 Spider [0.00]
2014 F30 BMW 328xi [0.00] 2006 E90 BMW 325i ( ... [0.00] 1988 Audi 90 Quattr ... [0.00] |
I actually posted this in a random thread, but it didn't get much visibility.. it might actually be a dumb question, but here goes anyway:
Does it matter what angle the jack/handle is at? I have a single garage, and it's hard to use the jack when the jack/handle is positioned horizontal to the car. If it was on an angle, it might be easier to get the full jack pump motion.. but worried that the jack position might not be ideal, compared to being horizontal from the car. Attached is a hilariously crude drawing I did in a minute to sort of illustrate my point. After looking at the drawing, I'm not even entirely sure the jack will be usable in that position. |
10-17-2014, 09:19 AM | #2 |
Rep 202
It won't really matter. If you have a jack with good casters/ wheels then it should move into the correct position as the car is being lifted up (so that you don't get any weird forces that would make the vehicle fall off the jack). Just take it slowly on the way up, most of the time you'll hear/ see the signs of something going wrong before it actually happens.
10-17-2014, 09:22 AM | #3 |
Rep 1,681
I live in a loft so have to park in a deck. I have 2 spaces, but I can't move my other car every time I want to work on something since there's no other place to park it. I can't just back it up like if I had a driveway (I'd have to pull out and go across the street). So I jack up my cars the vast majority of the time with the jack angled like your 2nd picture. I've never had an issue yet. This is for both my 335 and my Infiniti FX which is a larger heavier vehicle.
10-17-2014, 10:24 AM | #5 | |
Rep 965
http://www.canadiantire.ca/en/pdp/mo...-0090021p.html I'll see how much room I can make one side to jack at a better angle. |
10-17-2014, 10:39 AM | #6 |
Rep 1,025
If your jack has a 2-piece handle, you can remove the second piece. Much harder to jack, but it can fit in much smaller spaces.
Also, if there's room front and rear, you can use the central jacking points without needing any side clearance. I have jacked cars up like you illustrated, and its not ideal, and probably dangerous. The jack needs to move with the car as it rotates, and if its not perpendicular, then the wheels on the front of the jack have to partially slide sideways to stay with the car. Sometimes it slides well, and sometimes it sticks then "jumps" to the car's position, which is not good.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
10-17-2014, 10:52 AM | #7 |
Rep 202
You should have an issue with bending unless the car shifts an/or the ground lets go underneath you. If you're doing it on concrete or pavement you'll be fine.
A few years ago I bent a steel jack lifting a car. This was my winter beater and I was jacking it up higher on a gravel driveway. Luckily there was no damage to the car though. |
10-18-2014, 04:46 AM | #8 |
Rep 18,825
Why don't you just jack the car up correctly with the front and rear center jack points and set it on stands? Since the jack sit so far under the front and rear, I doubt you'd have clearance issues with the jack handle.
10-18-2014, 07:09 AM | #9 |
Rep 211
Drives: 2007 335i TiAg MT
Good call, listed in the features of the link he posted - Aluminum 2 piece long handle provides ease of pumping in tight areas when second handle is removed
10-19-2014, 06:10 AM | #10 |
Rep 2,015
Dassub Canadian tire also sells Trolly Jacks.
I wanted the racing jacks also, and was about to buy it. Went to Canadian Tire. That day, they had it all assembled and when I saw it..... Ohhh shit. Just like you, I have walls on each side..... No way I could jack it. Even at an angle, risk of hitting black car was tooo high. I Gota the $25 Trolly Jack. I still jack horizontal. But the pole has a 90 degree pivot on it..... Its a slower jack but it does the job. DN |
10-19-2014, 09:32 AM | #11 | |
Rep 965
10-19-2014, 09:37 AM | #12 |
Is it the shoes!?
3885
Rep 5,112
OP I had the same conundrum. I lifted the front at an angle like you showed, no problems whatsoever. It's a good question to ask: not many people ask this question!
From my experience, it should lift just fine. The jack is designed to pivot around, so any pivoting that will occur, the jack will handle it. Use me as one data point. I may be entirely wrong. If someone knows as to why this could be dangerous, I'm all ears. Out of all the jacking tutorials I've read and watched, I haven't seen anyone specifically mention jack positioning regarding the central jack point. |
10-19-2014, 01:58 PM | #14 |
Rep 823
Drives: 2008 335i Coupe TIAG
op you'll be fine with using your jack at any angles. but depends on certain angle, it may not lift your car as high. No matter what you do...please use a jack stand if you need to get under your car.
10-19-2014, 03:00 PM | #15 |
Leeeroy Jankins
31
Rep 423
I just did my water pump and when I lift car I use floor jack at an angle like you described on back lift location to the point where I can set a jack stand on the front lift spot same side as floor jack. Then lower and move floor jack to very front so that I can now reach front center lift spot high enough to slide other stand on opposite side at front !
e90 LCI w/ -= VRSF 7" FMIC =-
-= Cobb: Stg1 +FMIC Aggressive ST =- Last Install: BMS DCI + Caliper/Drum Paint "If you're not 1st, you're last" -Ricky Bobby |
