E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Brake Pads reset
Reply
      10-20-2014, 06:07 AM   #1
Waspo
Waspo's Avatar
England
94
Drives: E90 330i M Sport, Silver
Brake Pads reset
Hi Guys,
On trying to reset my Service interval, which kept coming up, although the service is not due and was only done in June this year, i went through the reset procedure, Pressing small button on dash, service menu comes up select the one you want and press BC to reset......so on and so on!
In doing this somehow my rear brake pads are now coming up as REPLACE. I have tried the reset procedure on the pads and it goes through the reset procedure, (Clock spinning round) but still the warning is present and i can't reset it!
Before anyone asks i have checked rear pads and they are new in the last service (June) and there is loads of meat on them.
Can anyone please help as the annoying reminder everytime i start up or shut down and the Brake light is on constantly.
Thank you
Steve
Understeer is when you hit the wall with the front of the car, oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall and torque is how far you take the wall with you"
      10-20-2014, 09:31 AM   #2
IanS100
IanS100's Avatar
England
136
Drives: 520d F10 LCI M Sport
Originally Posted by Waspo View Post
Hi Guys,
Thank you
Steve
Were the wear sensors replaced along with the pads?
      10-20-2014, 10:09 AM   #3
Waspo
Waspo's Avatar
England
94
Not Sure these where done before i bought the car. Just seems funny as i was trying to reset service interval this morning, that still failed, but then up pops the Rear Disc warning error. It was not showing before i tried to reset service interval.
Now i have 2 warning in the iDrive, Brakes and Service due (Which i know not to be true, as service was done just before i bought the car).
      10-20-2014, 10:16 AM   #4
themanthatcan
Drives: 2008 E92 335i MSport
That would be my question as well. If the wear sensors are reporting that the pads are expired then that's what the system will believe.
335i gone - no longer a BMW owner
      10-20-2014, 11:02 AM   #5
Waspo
Waspo's Avatar
England
94
Hmmmmm, i'll get them checked out, but still seems strange that the Brake Pad warning came on when is was "Playing" with the service interval reset (Which also did not work!)
      10-20-2014, 01:58 PM   #6
makkan00
makkan00's Avatar
Drives: F83 and F36
Reset the service interval as that should not be a problem.
If you accidentally pressed or tried to reset the brakes, it will generate error.
Solution is new wear sensor. Get it fitted and then reset.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      10-20-2014, 02:10 PM   #7
Waspo
Waspo's Avatar
England
94
Hi Sam,
I did have my foot on the brake pedal as i was doing the reset? DOH!
      10-20-2014, 02:19 PM   #8
Sensible_
Drives: 2008 E90
Hi Sam,
Indeed no software will help you.
If you really want the warning to go without changing the sensor you can cut the sensor off the cable and join the 2 wires in the cable together. You can then reset via the on board computer.
But since the sensors are so cheap just replace it. 5 minutes job.
      10-20-2014, 02:22 PM   #9
Waspo
Waspo's Avatar
England
94
Yet another lesson learnt in the E90 World.
to Makkan and Sensible
      10-22-2014, 11:01 AM   #10
Waspo
Waspo's Avatar
England
94
Hmmmmm,
seems it was not the sensor, changed that, might as well change the pads whilst wheel and everything was off, so changed both rears. Still could not reset brake warning, so took to BMW indie.
He has just rang to say he has had to "Reset the Software" by disconnecting battery , resetting Service software, as the brake reset had reached too many changes????
Anyone comment on this repair.?
All alarms now gone but i have to gaps in the service menu. They are all ticked green and when i highlight one of the gaps and press the idrive to select it it just give me a read out that i should change is at next service date. It gives the date. So what am i missing? and why are they missing.
I have:
Brake Fluid OK
Engine oil OK
GAP OK
Vehicle Check OK
Front Brake Pads OK
Rear Brake Pads OK
GAP OK
Reply
e90post
