Spacer question
10-25-2014, 10:49 AM | #1 |
Rep 604
Spacer question
Sorry to ask. I see there are quite a few threads on spacers, but could not find an answer for my car.
I have an E92 pre-lci M Sport and 19 M Double-spoke style 225M alloys. What is max spacer I could use front and back to avoid any chance of rubbing? Thanks in advance. |
10-25-2014, 03:39 PM | #2 |
Rep 784
Drives: E90 325i m-sport
Google it . Its faster
11-16-2014, 07:07 AM | #3 |
Rep 604
OK googled and found this: www.trakplus.com
Its not that straightforward however as different driving conditions/ number of passengers make it hard to know for sure. As far as I can tell 15mm rear and 12mm front seem to be a safe option, but if anyone has experience and can confirm it would be much appreciated (hence why forums are better than google) I have an E92 MSport. Standard suspension and 19 M Double-spoke style 225M wheels. Thanks in advance! |
11-24-2014, 03:53 PM | #12 |
Rep 3,201
Drives: E92 325i MSport Coupe
Yes. Bolts must be longer than the originals by at least the thickness of the spacer
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
11-25-2014, 06:23 PM | #13 | ||
Bimmaaaa
23
Rep 635
Drives: E46 M3
Also OP one size up on the tyres fill the gap for an aggressive look.
InstaGram: Ajerthan |
