TuningWerks "Flash tune" Unlocks hidden potential on the M235i & M135i |
10-29-2014, 05:03 PM | #1 |
Rep 536
Well folks the wait is finally over http://www.tuningwerk.de/ have finally unlocked the unlock-able encrypted M235i and M135i ECU !! Tuningwerks is the only company in the world at present to my knowledge that can actually flash tune the M135i and M235i and it only costs 1500 euro's to 360 HP.... but be warned peeps fuel pump upgrades are needed to reach this power level as well as a few other cooling bits potentially!! Several parameters in the factory ECU's calibration are optimised to my understanding and the Vmax is also removed as well .
After consulting Peter the owner and founder who I found extremely helpful and "pleasant" to deal with offers two tuning options for these models : 1. ECU is flashed via the OBD2 port at his facility 2. You can send in your ECU and he can bench flash TuningWerks also offer a same day turn around on tunes or ECU's sent to there factory in Munich which is amazing service .....! So folks the long wait is finally over the ECU has been cracked by Peter and his team at Tuningwerks !! Call them today or email Peter Reith @ preith@tuningwerk.de Everyone should get on this !! Last edited by chaddy74; 10-31-2014 at 07:25 AM.. |
10-29-2014, 05:59 PM | #2 |
Rep 3,429
Another week, another vaporware ECU flash out of a no-name tuner in Europe.
This will fade into oblivion like all the other threads once people realize there is no substance behind it all. However, I do hope I'm wrong. |
10-29-2014, 10:16 PM | #4 |
Rep 171
It really isn't that far fetched. All the tuners for VW/Audi do this. Only difference is the support, they have local dealer networks all over the US(APR, UNI, GIAC etc). There aren't any piggyback units on the gti's or B8 s4's for example and they have bosch ecu's. What they do is open them up, wipe them out then load their tune along with all the oem controls back on the ecu. From that point on you can be flashed obd because they change the encryption.
10-30-2014, 12:07 AM | #5 |
Rep 536
I can assure you this is no bull shit !! I actually pressed a few buttons with Peter and got completely hosed !!Im traveling to Germany next week for business and I will be loaded with my ECU in the suitcase and if Peter allows me to visit following my " I Dont believe comment" I will be returning to Australia with a flashed ECU to a mild safe spec tune !! Peter appears very knowledgeable but I now have some ground work to win back his trust following my comments and a semi argument with him !! I can assure you peeps tuningwerks can flash the ECU !!
10-30-2014, 11:50 AM | #6 |
Rep 4,526
Chaddy - look fwd to reading your views on tuningwerks offering, once you've had time to test it, in comparison with other products you have used. PD
10-31-2014, 10:30 AM | #7 |
Rep 10
Thats not what we doing or recommend. It´s correct that we are able to write (like some other too) the ECU´s from the M235i. The M135i after July 2013 too. But in both cases not with every iStep version. Some times we have to change the iStep before, which we can do only if we have the car
in our garage. Just with the ECU we need a diag print from a BMW dealer with the installed iStep because not every iStep is comaptible with othe CU´s with a other software step. Writing a ECU without testing the car after remap is also not our favorite. So maybe we lose some money if i write this here, but it will be not fair if i don't tell the hole story. Also we are not the heros nor we are the only company which is able to write F-Series BMW´s. Also we didn´t have cracked the BMW software! I´m sure that the large tuning software company´s like Flashtec, AlienTech, TechTec and so on will provide in the near future their new releases, that all local tuners can do the same. Next is, that we never recommend any power steps over 360hp with this N55B30A engines. A other thing is, that a remap is maybe better then a tuning box, but please don´t forget that a remap can be overwritten by BMW if your car was there for service. I agree that a track tool should be written, but a street legal car if you are not close to our company means sending the ECU again even if we have time and do it at the same day, the customer will lose time. Also someone should dismount the ECU before and re fit it after we was sending it back. I don´t want to be suggestive that we are not happy about orders from international customers, but in this case customers should think about twice. Sorry for my bad English! Thanks Peter |
10-31-2014, 10:56 AM | #8 |
Rep 117
Peter, what is Tuningwerk's experience with the N55 motor when pushing it over the 360HP level? Are there just piston/rod issues that need to be addressed?
10-31-2014, 04:33 PM | #9 | |
Rep 536
Thanks Peter for you honest reply. I have a few questions if i may ...What parameters are and can be altered with your tuning option ? Do you feel the three companies you have listed above will be far away ? Local support is something which is important for many i guess .
11-04-2014, 07:53 AM | #10 |
Rep 809
Looks like you were right FC... this thread ended as fast as it started but I do admire the Pete's honesty, that's how all tuner companies should act.
11-04-2014, 10:19 AM | #11 | |
Rep 3,429
Don't worry...tomorrow there will be another tuner no one has ever heard of who has cracked the ECU who will make a major announcement in two weeks. |
11-04-2014, 11:59 AM | #12 | |
Rep 10
the direct way via password. This will not work or better it will cause a high computing time. The better way is, remove the ECU, open it, do a reset of the system time (it must be under 10hrs), here you can use available tools, than unlock it and switch it to kind of developer mode. Than change the password retrieval to existing system pswd is not valid, instead the pswd in same bit length is set to valid. Than you are able to read bin file out. Use a tool like Map3d or WinOLS for the remapping after that calculate the checksum. Write it back, switch back to the default mode, re fit the ECU. Have fun! |
11-04-2014, 01:01 PM | #13 | ||
Rep 1,349
Drives: BMW F80 M3
11-04-2014, 02:24 PM | #14 | |
Rep 536
Tuningwerks Can Tune The Ecu ~!
Thanks Peter !! you have been very professional through my enquiry and for that i respect you greatly...... now for the individuals that dont believe ! ! I have spent hours on the phone with Peter discussing and toying with my options but decided not to proceed at this stage and this is why !
1. The cost of shipping if something was to become an issue 2. The intake manifold has to be removed and parts replaced on reinstallation 3. Peter hadn't done a RHD car -But I was reassured this would not be an issue 4. Time and downtime of the Car if the ecu had to be sent back and forth It has been explained so many times that the ECU once unlocked and reset can be tuned in the first 10 hours in development mode , what more can I say ! Quote:
11-04-2014, 02:27 PM | #15 |
Rep 536
11-04-2014, 02:30 PM | #16 |
Rep 1,349
Drives: BMW F80 M3
11-04-2014, 02:44 PM | #17 | |
Rep 809
And if you read again @FC4 first response, even he questioned the fact that this could be or not real, he did actually said "However, I do hope I'm wrong". |
11-04-2014, 02:54 PM | #18 | |
Rep 536
Ok sorry you would be happy now I deleted my text you are right !! I have no time for people that dont listen tho ! This wasnt about a recommendation was it ? it was about can it be done and the answer is clearly yes !!
11-04-2014, 03:11 PM | #19 | |
Rep 809
cheers. |
11-04-2014, 04:44 PM | #20 | |
Rep 536
Yeah it was a bit early , I should have waited until i arrived at the office and had a coffee before i replied
11-05-2014, 04:50 PM | #21 | |
Rep 926
FC's always right, hahaha. but yea, this seems like another fanboy thread like the dinan one back in the days... :P |
11-05-2014, 05:22 PM | #22 |
Rep 536
Thanks Kermit .. just looking for an ecu flash solution so i can run my bigger turbo and target correct afr mixtures and boost settings on the ewg car
