Warm Wings
10-30-2014, 12:05 PM | #1 |
Rep 390
Warm Wings
Only just noticed recently after parking up the front wings seem warm to the touch.
The front section just behind the indicator. I assume its heat soak from a large engine? |
11-03-2014, 06:56 AM | #3 |
Rep 123
I would suggest that they just feel a different temperature (aka: warm) because they are made of plastic and not metal so hence feel warmer relative to any metal panels you touch
10-28-2015, 01:45 PM | #4 |
Rep 390
Maybe I should have titled this hot wings to get you KFC lovers.
Noticed this again today its definitely heat soak in wings feel approx. 40 degrees. Warmer than bonnet but I suppose that has insulation/sound deadening. |
10-28-2015, 05:19 PM | #6 |
Rep 2,445
Drives: 2018 630iGT sport
This.
10-29-2015, 07:27 AM | #10 |
Rep 2,445
Must admit, my e92 (2009) wasn't an LCI and had plastic wings. I thought it was common across the e9x board?
10-29-2015, 12:17 PM | #11 |
Rep 935
E90 has metal wings, E92 always plastic.
My E92 wings are also much warmer than the metal doors after a long run, I would assume due to engine heat as air from the engine bay can easily access the wings' underside.
10-29-2015, 03:07 PM | #12 |
Rep 2,010
Drives: F30 335d
E91 pre-LCI with plastic wings.
if I've helped - an Appreciate would be, er, very appreciated!
