BMS Chargepipe and Downpipe
11-10-2014, 05:58 AM | #1 |
Rep 462
I have N55 335i and just purchased and wondering if there is any coding required to fit both pipes ?
I see that the o2 sensor needs to be transferred from cat down pipe to BMS down pipe. Just thinking of getting local indy to do the swap. Thanks Marc |
11-13-2014, 03:00 PM | #2 |
Rep 2,621
Yes you'll get a check engine light. Most tunes available (JB4, Cobb, procede, remap) will cancel this..
Car: e91 330d with Viezu map
Gone but not forgotten: 2010 Jaguar XFR (Cat-back exhaust, pulley, intake mods and map), Highly Modified E90 335i LCI M Sport Manual (circa 480BHP/500lb ft) |
11-16-2014, 05:22 AM | #4 |
Rep 2,621
You won't get 30bhp from those mods alone. DP's maybe 10hp max - cp gives no extra power.
You can buy an O2 simulator (from BMS) which cancels the code. For not much more you could get a used JB4 and just block the code using that. If your going to fit a mod which causes problems (MOT failure and voids your warranty) you may as well get the full benefit (60-70hp)..
11-16-2014, 04:30 PM | #5 |
Rep 2,204
+1
Engine Mods: VF HEX Stage 2, ER Charge Pipes, VRSF Catless Downpipes, BMS Intakes and PCW Exhaust Mod
Running Gear Mods: HRE Flow Form F01, Yellow Stuff pads. Cosmetic: Performance Grill, Lip Spoiler, Splitters, Side Skirt Extensions, Diffuser and BMS Tips |
