11-11-2014, 11:52 AM | #1 |
Rep 215
High Performance All Seasons
So I have an M235i xdrive on order! The intent of this car is to provide performance like my 370Z but with the ability to drive all year round. During the test drive on a sweeping curve I did notice the stock all seasons seem a bit under-tired, especially compared to the Bridgestone S-04's on my Z. I'm working through my options, but am drawn to just getting a more high performance all season tire as a reasonable compromise.
Currently looking at the popular Conti ExtremeContact DWS. Even though it is a very high performance tire, it is well known to have a softer sidewall. Does anyone here have experience with this tire specifically against the stock Pirelli all seasons? During the test drive I did not notice much sidewell flex, and don't want to compromise the tight, nimble feel I was so impressed by. Also looking at Goodyear Eagle F1 Asymmetric All Season or Hankook Ventus S1 Noble2 as *maybe* a stiffer sidewall, but giving up some snow traction. Thoughts? |
11-11-2014, 12:10 PM | #2 |
Rep 347
I just bought a set of Nokian WRG3, which you might consider.
Available at A&J Tire Factory in Denver. http://www.tirefactory.com/aj/Product-Details/NT428631
F22 * (N55 + 6MT) ÷ PSS = FUN
11-11-2014, 08:36 PM | #4 |
Rep 347
It's a winter-rated "all weather" tire. Designed to be driven year-round but much better performance in snow than an "all season" tire.
11-11-2014, 08:42 PM | #5 |
Rep 215
I would say I'm looking for a high performance tire with at least adequate snow capability (not gonna get me killed like Michelin PSS's would in the snow)
11-11-2014, 08:58 PM | #6 | |
Rep 1,053
I owned the DWS and I would never buy it again. I do not have experience with the Pirellis but have owned many other brands. In my opinion, the soft sidewall and lack of cornering stability was enough for me to sell them off well before they became worn. It had kind of a floaty feel to it which made the steering feedback even worse. The only positive I'd give it is that it was quiet and cushy. Never again. |
11-11-2014, 10:11 PM | #7 | |
Rep 765
- Softer sidewall (than OEM Pirellis) (makes for quieter ride, sucks for track fun) - Lateral grip is the first to go. The DWS is designed to wear out in order: Snow -> Wet - > Dry. They are good for about 1 winter, then 'just enough' for a second winter. By a third winter, don't bet on the snow capability. I have heard other review recommending the Conti DW tires (no S). The S was never that impressive and the DW version has a longer life. That said, if you are traveling deeper than 2-3" of snow, you need studless snow tires. Even all-seasons are not optimal for deep freeze/snow conditions - they are meant to just get by, not perform. Noticing you are up in Denver, not sure how many days are spent under the white stuff. A true winter set may be a better investment and change out the OEM all-seasons for PSS when they become too worn.
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
11-11-2014, 10:23 PM | #8 |
Rep 215
Thing is this is a lease, so I'm not keen on buying two sets of tires. I'm leaning towards the Goodyear Eagle F1 Asymmetric All Season now. Sounds more responsive in the dry, and step down in the snow from good to ok. We get some snow here, but I'm not convinced I need winter tires to be safe - the Michelin LTX MS on my old Dakota are fantastic in the snow, and they are just all seasons. Albeit top-of-the-line all seasons.
11-11-2014, 10:31 PM | #9 | |
Rep 765
11-12-2014, 08:21 AM | #10 |
Rep 215
Let me restate: I am NOT looking for snow tire. I'm looking for a performance tire that is better than the all seasons, but with adequate snow capability that won't get me killed like max performance summer tires would.
11-12-2014, 09:44 AM | #11 |
Rep 5,580
I'm thinking about the Michelin Sport A/S 3 for my rwd 235. Been considering this tire for a long time and this months BMW CCA magazine article review was positive, they did a comparison test with the Michelin PSS.
I just wanted a tire for coating of ice conditions. |
11-12-2014, 10:00 AM | #12 | |
Rep 215
11-12-2014, 10:04 AM | #13 |
Rep 215
Also looking at going with 235/40's on the factory wheel (7.5"?). 8" is listed as the minimum wheel size, but I'm not sure .5" makes much difference, Tirerack even mentions BMW doing just that combo in the past.
11-12-2014, 10:06 AM | #14 | |
Rep 4,531
Just letting you know. |
11-12-2014, 10:57 AM | #15 |
Rep 215
11-12-2014, 11:35 AM | #16 | |
Rep 4,531
Even with an AWD car, you need tires to grip to brake, or turn. All-season tires (or AWD) don't help you with stopping a car. |
11-12-2014, 11:37 AM | #17 | |
Higher than you
9
Rep 294
Current: '15 M235iX | '15 Macan S | '00 Honda S2000 Notable Previous: '12 E92 335is | '10 STi | '88 E30 325iX |
11-12-2014, 11:57 AM | #18 |
Rep 8,942
Maybe a dumb question but if you're leasing you'll probably have to replace tires before turn in anyway. Why not just get the best summer tire and the best max performance winter tire and have 2 sets? Seems like you're trying to get a compromise tire 12 months out of the year when for the same cost you could have ideal tires all year long.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
11-12-2014, 04:27 PM | #19 | |
Rep 215
11-12-2014, 04:39 PM | #20 | ||
Rep 8,942
2022 Macan S
11-12-2014, 06:20 PM | #21 | |
Rep 845
Also, you should be aware that the size difference will effect your speedo accuracy - you will be traveling approximately 1% faster than your speedo reads due to increased tire diameter. Normally, anything within 3% is fine, so you should be okay. |
11-12-2014, 09:49 PM | #22 | |
Rep 765
I know our brake rotors can cause clearance issues, so I plan to try on new (used) shoes before buying :P
