11-19-2014, 09:18 AM | #1 |
Rep 2,386
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Low Tire Pressure Mode Lockout
So interestingly enough it's currently like between 40-50 degrees here in Florida so yesterday my car started showing low tire pressure for all my tires and then I noticed I had lost the ability to change driving modes. So now I'm locked to comfort I would imagine until I refill the tires a bit. Anyone else experience this.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
11-19-2014, 10:57 AM | #2 |
What goes here?
454
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Yes, this is quite common.. air up accordingly and you'll be fine.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
11-19-2014, 12:49 PM | #4 |
Rep 1,040
This is why the Canadian version doesn't use in wheel TPMS. Instead the Audi like "indirect method" that uses tire rotation speed and computer tables that estimate tire pressure loss. You don't get the typical pressure loss signal light like the "in the wheel" system does when temps fall hard. My Honda was horrible when the temps change 30 degrees or more when cooler overnight even though the real pressure was okay.
11-19-2014, 12:49 PM | #5 | |
Rep 2,386
Follow my builds:
11-19-2014, 02:48 PM | #6 |
Rep 25,988
This just happened to me the other day. Once I filled up and reset the TPMS, everything was back to normal.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
11-19-2014, 03:23 PM | #7 | |
Rep 1,115
11-19-2014, 04:08 PM | #8 |
Rep 347
Was it imported from a US dealer? We should have only the Flat Tire Monitor (FTM).
F22 * (N55 + 6MT) ÷ PSS = FUN
11-19-2014, 05:51 PM | #9 |
Rep 775
Lets see a photo of your psi...
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com Current: 2015 Cayman S on HRE P101 |
11-19-2014, 11:25 PM | #11 | |
Rep 2,386
Follow my builds:
11-19-2014, 11:54 PM | #12 |
Rep 140
This actually happened to me on the drive home after taking delivery of my car. Added air and all was fine. My pressure has dropped in the past few days as the temps have plummeted here in NY. Somehow I haven't had the issue yet. It's an annoyance...
11-21-2014, 07:55 AM | #14 | |
Rep 1,115
Have my winters on right now. If it was FTM it would reset instead of the light being on constantly. I wonder if it has to do with initial tire choice, mine came with RFT not PSS. |
11-21-2014, 02:19 PM | #15 |
Rep 347
I had to manually reset the FTM after installing the winter wheels a couple of days ago. The pressure was fine. My PSS and the winter tires are both non-rft.
