Emission Readiness... WTF...
11-19-2014, 04:54 PM | #1 |
Rep 3,251
Trying to get the car ready for OBD emission check that is due in a few weeks.
Installed dp fix a few weeks back and reactivated catalytic checks in BMS backend pump backend flash through turner pro (can't find flash back to my stock flash for some reason, the ecu keeps going into recovery mode). So I did the drive cycle last night (http://www.europeantransmissions.com...0Procedure.pdf), got 29f4 code. So I turned up the dpfix 1/8 (from 5 o'clock position), redid the drive cycle. That seems to do the trick, as I got all monitors in "yes" (except for evap, which takes a little longer) according to INPA (see my attached picture). So I drove the car the testing station this morning. Throw 2C7E (lambda probe, bank 1, trimming control), 2C7F (lambda probe, bank 2, trimming control), and 2C6B (lambda probe, system check) and along with a SES light. No big deal, been having these codes popping up every now and then for the past month. But just as I was going to pull into the station, I got a "reduce engine power" warming. Checked the codes with JB4 and it shows 29F4, 29F5 .................... INPA shows that the catalyst readiness as "no"...... With all the traffic around Chicago during the day, I just cant do a proper drive cycle at the moment. Plan now is to redo the drive cycle this evening after I turn up the dpfix another notch to 3 o'clock position. But I am wondering, are the 2C7E, 2C7F, and 2C6B codes affecting the emission readiness? What the hell are these codes anyway?
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
11-19-2014, 04:56 PM | #2 |
Rep 3,251
Here are the codes btw.
11-19-2014, 05:09 PM | #3 |
Rep 6,478
Read the thread I had on my DPfix saga, it's not the exact same codes, but it's a very similar scenario.
You are on the clock, put simply. On the one hand, as you can see your monitors are all being set properly. But once that happens, for whatever reason, you have a limited amount of time until one of the trimming codes throws an in-dash SES. When that happens, your goose is cooked. It's a PITA, but I cleared everything to start from scratch, putzed around on the highway and some city driving. Watched my OBD scanner like a hawk and once the monitors were all ready, I went straight to the emissions testing. Sparknotes: Forget the codes, what matters is an in-dash SES and monitor readiness. I passed with codes up the wazoo.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
11-19-2014, 05:13 PM | #4 |
Rep 4,764
You turned off the auto-clearing of the cat codes in the JB4? You can have a dp fix, and not turn off the code clearing in the JB4 and it will clear codes and readiness at the same time. You will not have readiness for long. Is that possibility eliminated?
On procede it is called canclear. you have to disable canclear and have the dp fix (built in to procede called the o2 modifier setting, or use an external dp fix) on. If you forget to turn canclear off, you get the symptoms you are describing. I don't know what the name of the o2 modifier equivalent functionality is called for the JB4. |
11-19-2014, 05:26 PM | #5 |
Rep 3,251
JB4 auto clear is off. I made sure of that every time I go do a drive cycle.
125Pats, guess I might just have to do a drive cycle right before the emission test. INPA is a pain to use, since I have to lug my laptop around. What portable OBD scanner did you use to check your emission readiness?
11-19-2014, 07:02 PM | #7 | |
Rep 3,251
Speaking of which, I probably should have just went to get the emission test done with the bms flash. All my monitors were ready, except for the one for catalyst... As far as I know, Illinois allow one of the monitors to be in "not ready" state. But now I am stuck with two (evap and catalyst), and who knows how long it will take for the evap to come back. I did manage to get all but the evap monitor ready last night, as I stated in my 1st post. But my guess is that the dp fix wasn't set in a strong enough setting to keep the cat. inefficiency code out (29f4 29f5) during the dead cold start this morning on my way to the station. Gonna redo the damn drive cycle tonight again, once the traffic dies down. Going to reset the O2 adaption too. See how that works out. Still no idea why I keep on getting those 2c7e, 2c7f, 2c7b codes. Those only started after a track day about a month ago.
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization Last edited by Cloud9blue; 11-19-2014 at 07:11 PM.. |
11-19-2014, 07:20 PM | #8 |
Rep 3,251
btw, found the obd reader that can check emission readiness: http://www.amazon.com/gp/product/B001LHVOVK
The only windows laptop I have is a chunky Thinkpad and INPA doesn't play very nicely with it (keeps on throwing error messages). This should be much easier to use for checking emission status.
11-19-2014, 07:51 PM | #10 | |
Rep 6,478
11-19-2014, 09:15 PM | #11 |
Rep 3,251
Easier said then done... I already tried force writing the files countless times. And living in a condo doesn't help either, I have no outlet near my parking space. Only get a few tries each times before the voltage on my battery start to drop. I rather not risk bricking the damn ecu just get the car passed emission.
11-21-2014, 10:16 AM | #12 |
Rep 3,251
Alright, seems like the DP fix is going out of wack. Already at the 3pm position, but still getting the 29f4 and 29f5 codes this morning while I doing my 234,892,875th drive cycle. It looks like the downpipe codes only show up while I slow down from 50-55mph in D from a drive cycle. I always drive in manual mode in normal street driving and somewhat aggressive with the throttle most of the time, so the ECU never show these codes otherwise.
Going to re-flash the car later tonight and reset everything. And then have the car sit overnight and redo another drive cycle tomorrow morning right before the testing center opens at 8am. Wish me luck... Perhaps it is some weird adaptation issue, since the dp fix worked for the first drive cycle right after I re-flash the car at only 5pm position.
11-21-2014, 10:37 AM | #13 | |
Rep 6,478
I didn't have to do this since all my monitors reported "ready", but I do wonder what would happen if you yank the DPfix, flash to a stg1 map, then do some drive cycles. I *think* every monitor would set ready except catalyst, which if you can fail one set of monitors would not cause you to fail. Again, the key here is balancing it against the in-dash light, which is the kiss of death. It's a completely PITA, I got so frustrated with it. You'll get it to work, that OBD scanner is your best friend.
11-21-2014, 11:49 AM | #14 | |
Rep 3,251
Worst comes to worst, if I can get it ready in the next week or so, I might just throw on my stock down pipe... |
11-21-2014, 11:55 AM | #15 | ||
Rep 624
Drives: 09 Spc Grey Met e90 335i
11-21-2014, 02:08 PM | #17 |
Rep 3,251
Yeah, tell me about it. At this point, paying $150 to reinstall my stock downpipe doesn't look so bad
11-21-2014, 02:13 PM | #18 | |
Rep 3,251
Have to say, BMW DME is a complete pain in the ass to deal with. My bike, also a BMW, has some weird stalling issue from time to time when the DME switches between open and close loop lambda control. I kind of just learn to live it by now...
11-21-2014, 02:27 PM | #19 |
3442
Rep 79,211
I've paid even more then that in the past just to pay off the inspection station. I wasn't about to remove headers, supercharger and nitrous haha. (different platform obviously)
11-21-2014, 02:46 PM | #20 | ||
Rep 624
Tempting to put xx xxx on without JB4 in to see if it's the JB4/xx xxx combo. But PIA to uninstall everything. I ordered the lil Autel also. |
11-21-2014, 03:11 PM | #21 | |
Rep 3,251
11-22-2014, 01:14 AM | #22 |
Rep 3,251
Alright. I gave up. I cleared and reset everything and re flash the ecu. Turned up the wedge's dp fix all the way to 1 o'clock setting. Still getting the damn 29f4/5 codes and half engine light. Funny thing is that these are now shadow codes now, so I can't see them from JB4. Have to actually use the BT cable to read them.
At this pointing I just gonna call my shop next week and have them throw the stock doe pipe back on for the winter. Gonna pull off the dp fix and test out the resistance myself to see if I got a faulty unit or something. Already wasted a full tank of gas doing these awful drive cycles and not gonna deal with any more of these bullshit.
